08-11-2006, 05:45 | #1 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Sun Age: 44
Member: 4021 Status: Offline Thanks Meter: 782 | problem unlocking cg300.... please help i tried unlocking cg300 but im having problem... each time i press unlock and press power on, im getting this error... PHONE NOT FOUND always appears... i already tried alot of cables... used unibox, adjusted baudrate.. made factory settings with the unit but still the same... please help me.. thanks!! br Last edited by ryumahon; 08-11-2006 at 06:03. |
08-11-2006, 08:16 | #2 (permalink) |
No Life Poster Join Date: Sep 2001 Location: GSM-TOOL Age: 52
Member: 6328 Status: Offline Thanks Meter: 3,595 | 1 - check cable and pinout When you want to connect phone, press ''Connect'', then insert the connector to the phone and press power on. Then, if you have select the correct port (check in device manager), it must work. More info: http://forum.gsmhosting.com/vbb/show...1&postcount=23 regards, Gobi |
08-17-2006, 10:10 | #6 (permalink) |
Member: 4021 Status: Offline Thanks Meter: 782 | 2nd cg300 that cannot be unlocked!! vygis team.. i think its not a cable problem or settings with my cables or box... the first cg300 is still here with me.. i thought there was a problem with the phone.. but this 2nd cg300 that just entered still cannot be unlocked!! having the same problem!!! mr gobi and mr vygism please help me... what must i do?!?!? is there a bug in the software?? i tried all the version up to the latest exe of lg software but still the same.. im using lg7050 ( 3 cables already tried ) but still no luck!! any advice please!!! thanks alot!!! br |
08-17-2006, 12:27 | #7 (permalink) |
No Life Poster Join Date: May 2001 Location: Lithuania
Member: 4458 Status: Offline Thanks Meter: 25,853 | Can you again post screenshot from software? Attach it to reply to this message.Also if you using sonork,would be fine to know your sonork number. Regards,Vygis |
08-19-2006, 07:52 | #8 (permalink) |
Member: 4021 Status: Offline Thanks Meter: 782 | thanks mr vygism for the reply.. i already solved the problem.. its not on the cable and its not a software bug.... proper timing is needed.... i unlocked the 2 cg300 successfully!!! br |
10-30-2006, 16:48 | #11 (permalink) |
Freak Poster Join Date: Dec 2005
Member: 213805 Status: Offline Thanks Meter: 1 | Procedure is as follows: 1) Open VPower and select CG300 as model 2) connect phone to cable without battery 3) Hit "Connect" Button 4) Attach battery.....progress bar will show 0%-100% 5) Hit "Direct Unlock" 6) Done |
01-22-2007, 20:11 | #12 (permalink) |
Freak Poster Join Date: Oct 2004 Location: Hidden in Gomez Cell Age: 62
Member: 86179 Status: Offline Sonork: 1615814 Thanks Meter: 10 | Cg300 Hi, I have the same problem with Vygis Toolbox and CG300 no way to connect "phone not respond:" is all i can get. Battery connect trick not working for me |
01-22-2007, 20:16 | #13 (permalink) |
Member: 86179 Status: Offline Sonork: 1615814 Thanks Meter: 10 | Cg300 Exactly the same problem with CG300 here Tried every possible way not working The problem seems to be in the Vygis USB port. I managed to unlock the CG300 using a same UNI-Box at com 1 Last edited by ToxieNL; 01-22-2007 at 21:03. |
12-22-2007, 21:18 | #14 (permalink) |
Crazy Poster Join Date: Jul 2005 Location: dominican republic Age: 48
Member: 160540 Status: Offline Thanks Meter: 75 | this is the solution hi brother i had the same problem and i resolve thats problem how ?? i select the phone model cg300 and select the other port for example com1 or com2 and select 115200 brauther and press connet nex to power key phone and connect and unlock suscefull. thanks and reagars to all |
Problem Unlocking U800 - Please Help | mobcreations | Ultimate-Sam | 18 | 06-18-2009 03:29 |
Problem unlock 6120c Please help UB End credit GONE | ServiceTEL | Universalbox | 2 | 03-13-2009 13:42 |
unlock fail w200 cid 52, log sent and requested,but problem for activate, please help | kaholukkk | Universalbox | 5 | 12-07-2007 02:36 |
Problem to unlock 3250 please help... | drag | MT-BOX | 3 | 08-10-2007 14:59 |
Problems Unlocking ZV10 Please Help | mbcommunication | NSPRO | 5 | 02-26-2006 23:28 |
