03-29-2012, 12:39 | #108 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Uzbekistan Age: 45
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | 28.03.2012 12:17:31 > Software version : SAM_1_18SD.exe 28.03.2012 12:17:31 > ---------------------------------------------------------- 28.03.2012 12:17:31 > For phone connecting do next : 28.03.2012 12:17:31 > - enter "System info" menu in next way : 28.03.2012 12:17:31 > - enter to phone menu 28.03.2012 12:17:31 > - long press "0" till password window will appear 28.03.2012 12:17:31 > - enter password "0821" 28.03.2012 12:17:31 > - select "SIO MODE" 28.03.2012 12:17:31 > - select "Port Map" menu item 28.03.2012 12:17:31 > - set "Diag Monitor" to "USB CDC" value 28.03.2012 12:17:31 > - rest items in this menu set to "NULL DEV" 28.03.2012 12:17:52 > If you can't connect using USB cable you 28.03.2012 12:17:52 > will need to use KH4500 COMBO cable 28.03.2012 12:18:42 > If you can't connect using USB cable you 28.03.2012 12:18:42 > will need to use KH4500 COMBO cable 28.03.2012 12:18:53 > If you can't connect using USB cable you 28.03.2012 12:18:53 > will need to use KH4500 COMBO cable 28.03.2012 12:19:07 > If you can't connect using USB cable you 28.03.2012 12:19:07 > will need to use KH4500 COMBO cable 28.03.2012 12:25:19 > Port COM95 connected 28.03.2012 12:25:20 > Connecting ... 28.03.2012 12:25:20 > Connecting ... OK 28.03.2012 12:25:20 > Connected in NORMAL MODE 28.03.2012 12:25:20 > ---------------------------------------------------------- 28.03.2012 12:25:20 > Phone type selected : SKY-IM-S350 28.03.2012 12:25:20 > IMEI : 355334-02-105189-5 28.03.2012 12:25:20 > Phone version : M6281A-KLRZ-4.0.9530T 28.03.2012 12:25:20 > Compilation info : Nov 06 200820:16:57Jan 07 28.03.2012 12:25:20 > 200819:00:00S0175153 28.03.2012 12:25:20 > Phone code : 0442 28.03.2012 12:25:22 > ---------------------------------------------------------- 28.03.2012 12:25:22 > Unlocking ... 28.03.2012 12:25:22 > Reading NVM backup ... 28.03.2012 12:25:28 > Reading NVM backup ... OK 28.03.2012 12:25:28 > Continue unlocking ... 28.03.2012 12:25:29 > Continue unlocking ... OK 28.03.2012 12:25:29 > Restarting phone ... 28.03.2012 12:25:29 > Restarting phone ... OK 28.03.2012 12:25:29 > ======== Process completed ======== 28.03.2012 12:25:29 > Operation time - 00:07 28.03.2012 12:25:29 > Port COM95 disconnected |
03-29-2012, 12:40 | #109 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | 29.03.2012 16:31:33 > Software version : SAM_1_18SD.exe 29.03.2012 16:31:33 > ---------------------------------------------------------- 29.03.2012 16:31:33 > If you can't connect using USB cable you 29.03.2012 16:31:33 > will need to use KH4500 COMBO cable 29.03.2012 16:31:40 > If you can't connect using USB cable do next : 29.03.2012 16:31:40 > - enter "DEBUG MENU" in next way : 29.03.2012 16:31:40 > - type ##000000# in dial window 29.03.2012 16:31:40 > - enter like password phone code 29.03.2012 16:31:40 > - default is "0000" 29.03.2012 16:31:40 > - select "COMM.ENVIRONMENT" 29.03.2012 16:31:40 > - set "DM Port" to USB 29.03.2012 16:31:40 > - if you see baudrate - set it to 115200 29.03.2012 16:31:40 > - set "DS Port" to USB 29.03.2012 16:31:40 > - if you see baudrate - set it to 115200 29.03.2012 16:31:56 > Port COM57 connected 29.03.2012 16:31:57 > Connecting ... 29.03.2012 16:31:57 > Connecting ... OK 29.03.2012 16:31:57 > Connected in NORMAL MODE 29.03.2012 16:31:57 > ---------------------------------------------------------- 29.03.2012 16:31:57 > Phone type selected : SKY-IM-R520S 29.03.2012 16:31:57 > IMEI : 357129-03-126344-1 29.03.2012 16:31:57 > Bluetooth Addr : 00:153:7F:86:21 29.03.2012 16:31:57 > Phone version : M76XX-SDOBAAZM-3555 29.03.2012 16:31:57 > Compilation info : Mar 15 201019:04:44Sep 09 29.03.2012 16:31:57 > 200900:00:00S0187142 29.03.2012 16:31:58 > ---------------------------------------------------------- 29.03.2012 16:31:58 > Unlocking ... 29.03.2012 16:31:58 > Reading NVM backup ... 29.03.2012 16:32:02 > Reading NVM backup ... OK 29.03.2012 16:32:02 > Continue unlocking ... 29.03.2012 16:32:03 > Continue unlocking ... OK 29.03.2012 16:32:03 > Restarting phone ... 29.03.2012 16:32:03 > Restarting phone ... OK 29.03.2012 16:32:03 > ======== Process completed ======== 29.03.2012 16:32:03 > Operation time - 00:05 29.03.2012 16:32:03 > Port COM57 disconnected |
03-29-2012, 12:40 | #110 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | 29.03.2012 17:20:02 > Software version : SAM_1_18SD.exe 29.03.2012 17:20:02 > ---------------------------------------------------------- 29.03.2012 17:20:02 > If you can't connect using USB cable do next : 29.03.2012 17:20:02 > - enter "DEBUG MENU" in next way : 29.03.2012 17:20:02 > - type ##000000# in dial window 29.03.2012 17:20:02 > - enter like password phone code 29.03.2012 17:20:02 > - default is "0000" 29.03.2012 17:20:02 > - select "COMM.ENVIRONMENT" 29.03.2012 17:20:02 > - set "DM Port" to USB 29.03.2012 17:20:02 > - if you see baudrate - set it to 115200 29.03.2012 17:20:02 > - set "DS Port" to USB 29.03.2012 17:20:02 > - if you see baudrate - set it to 115200 29.03.2012 17:20:08 > For phone connecting do next : 29.03.2012 17:20:08 > - enter "System info" menu by typing 29.03.2012 17:20:08 > "4433366368791" in dial window 29.03.2012 17:20:08 > - select "SIO MODE" 29.03.2012 17:20:08 > - select "Port Map" menu item 29.03.2012 17:20:08 > - set "Diag Monitor" to "USB CDC" value 29.03.2012 17:20:08 > - rest items in this menu set to "NULL DEV" 29.03.2012 17:20:10 > Port COM92 connected 29.03.2012 17:20:21 > Connecting ... 29.03.2012 17:20:21 > Connecting ... OK 29.03.2012 17:20:21 > Connected in NORMAL MODE 29.03.2012 17:20:22 > ---------------------------------------------------------- 29.03.2012 17:20:22 > Phone type selected : SPH-W8500 29.03.2012 17:20:22 > IMEI : 353117-03-114367-5 29.03.2012 17:20:22 > Bluetooth Addr : 00:26:5D:9F:0D:B5 29.03.2012 17:20:22 > Phone version : M76XX-SDOBOAZM-3555 29.03.2012 17:20:22 > Compilation info : Jun 11 201020:13:55Nov 18 29.03.2012 17:20:22 > 200824:00:00SPH-W850 29.03.2012 17:20:22 > Phone code : 3816 |
03-30-2012, 15:53 | #111 (permalink) |
No Life Poster Join Date: Sep 2005 Location: West Africa Ghana Age: 15
Member: 180675 Status: Offline Sonork: 100.111161 Thanks Meter: 411 | Phone type selected : SCH-W360 IMEI : 358122-01-036093-1 Bluetooth Addr : 00:1E:E2:81:0A:C1 Phone version : SAMSUNG Electronics Compilation info : Dec 19 200704.00.47Aug 21 200707:00:00SCH-W360 mujeeb Ibrahim: Connected in NORMAL MODE Flash ID : 98CA Flash type : toshiba_tya000bc Flash size : 00800000 Flash pages count : 00001000 Flash page size : 00000800 Flash block size : 00020000 ---------------------------------------------------------- Unlocking ... OK Restarting phone ... OK ======== Process completed ======== v804 samsung cable ..................... good job |
04-02-2012, 11:55 | #112 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | 02.04.2012 12:53:30 > Software version : SAM_1_24SD.exe 02.04.2012 12:53:30 > ---------------------------------------------------------- 02.04.2012 12:53:30 > If you can't connect using USB cable you 02.04.2012 12:53:30 > will need to use KH4500 COMBO cable 02.04.2012 12:54:22 > If you can't connect using USB cable you 02.04.2012 12:54:22 > will need to use KH4500 COMBO cable 02.04.2012 12:56:03 > Port COM9 connected 02.04.2012 12:56:05 > Connecting ... 02.04.2012 12:56:05 > Connecting ... OK 02.04.2012 12:56:05 > Connected in NORMAL MODE 02.04.2012 12:56:05 > ---------------------------------------------------------- 02.04.2012 12:56:05 > Phone type selected : SKY-IM-U440S 02.04.2012 12:56:05 > IMEI : 352557-03-119728-1 02.04.2012 12:56:05 > Phone version : M6290A-KPRZL-1.2.0045T 02.04.2012 12:56:05 > Compilation info : Jul 15 201013:11:15Aug 15 02.04.2012 12:56:05 > 200803:00:00S0182145 02.04.2012 12:56:05 > Phone code : 0000 02.04.2012 12:56:07 > ---------------------------------------------------------- 02.04.2012 12:56:07 > Unlocking ... 02.04.2012 12:56:07 > Reading NVM backup ... 02.04.2012 12:56:10 > Reading NVM backup ... OK 02.04.2012 12:56:10 > Continue unlocking ... 02.04.2012 12:56:11 > Continue unlocking ... OK 02.04.2012 12:56:11 > Restarting phone ... 02.04.2012 12:56:11 > Restarting phone ... OK 02.04.2012 12:56:11 > ======== Process completed ======== 02.04.2012 12:56:11 > Operation time - 00:03 02.04.2012 12:56:11 > Port COM9 disconnected |
04-02-2012, 11:56 | #113 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | 02.04.2012 13:43:28 > Software version : SAM_1_24SD.exe 02.04.2012 13:43:28 > ---------------------------------------------------------- 02.04.2012 13:45:01 > Port COM9 connected 02.04.2012 13:45:06 > Connecting ... 02.04.2012 13:45:06 > Connecting ... OK 02.04.2012 13:45:06 > Connected in NORMAL MODE 02.04.2012 13:45:06 > ---------------------------------------------------------- 02.04.2012 13:45:06 > Phone type selected : SKY-IM-A600S 02.04.2012 13:45:06 > IMEI : 359670-03-168872-1 02.04.2012 13:45:06 > Bluetooth Addr : 00:153:9B:1E:BA 02.04.2012 13:45:06 > Phone version : 8650B-SDCAOLYM-4075 02.04.2012 13:45:06 > Compilation info : Aug 11 201012:16:17Mar 29 02.04.2012 13:45:06 > 201013:00:00S0201124 02.04.2012 13:45:07 > ---------------------------------------------------------- 02.04.2012 13:45:07 > Unlocking ... 02.04.2012 13:45:07 > Reading NVM backup ... 02.04.2012 13:45:09 > Reading NVM backup ... OK 02.04.2012 13:45:09 > Continue unlocking ... 02.04.2012 13:45:10 > Continue unlocking ... OK 02.04.2012 13:45:10 > Restarting phone ... 02.04.2012 13:45:10 > Restarting phone ... OK 02.04.2012 13:45:10 > ======== Process completed ======== 02.04.2012 13:45:10 > Operation time - 00:03 02.04.2012 13:45:10 > Port COM9 disconnected |
04-03-2012, 22:56 | #115 (permalink) |
Insane Poster Join Date: Aug 2007 Location: MXBOX TEAM
Member: 559439 Status: Offline Thanks Meter: 7 | SPH-W8500 unlock ok after 15 minutes 4/2/2012 10:57:43 AM > Software version : SAM_1_24SD.exe 4/2/2012 10:57:43 AM > ---------------------------------------------------------- 4/2/2012 10:57:43 AM > For phone connecting do next : 4/2/2012 10:57:43 AM > - enter "System info" menu by typing 4/2/2012 10:57:43 AM > "4433366368791" in dial window 4/2/2012 10:57:43 AM > - select "SIO MODE" 4/2/2012 10:57:43 AM > - select "Port Map" menu item 4/2/2012 10:57:43 AM > - set "Diag Monitor" to "USB CDC" value 4/2/2012 10:57:43 AM > - rest items in this menu set to "NULL DEV" 4/2/2012 11:02:49 AM > Port COM11 connected 4/2/2012 11:02:51 AM > Connecting ... 4/2/2012 11:02:51 AM > Connecting ... OK 4/2/2012 11:02:51 AM > ---------------------------------------------------------- 4/2/2012 11:02:51 AM > Phone type : SPH-W8500 4/2/2012 11:02:51 AM > Connected in EMERGENCY MODE 4/2/2012 11:04:06 AM > ---------------------------------------------------------- 4/2/2012 11:04:06 AM > Writing flash from file : 4/2/2012 11:04:06 AM > SPH-W8500_DF11u_EN_KOR.crc 4/2/2012 11:04:06 AM > Extracting flash files ... 4/2/2012 11:04:15 AM > Extracting flash files ... OK 4/2/2012 11:04:15 AM > ---------------------------------------------------------- 4/2/2012 11:04:15 AM > Writing BOOT flash file ... 4/2/2012 11:04:15 AM > Checking flash file ... 4/2/2012 11:04:15 AM > Checking flash file ... OK 4/2/2012 11:04:15 AM > Continue file writing ... 4/2/2012 11:04:20 AM > Continue file writing ... OK 4/2/2012 11:04:20 AM > ---------------------------------------------------------- 4/2/2012 11:04:20 AM > Writing CODE MAIN flash file ... 4/2/2012 11:04:20 AM > Checking flash file ... 4/2/2012 11:04:21 AM > Checking flash file ... OK 4/2/2012 11:04:21 AM > Continue file writing ... 4/2/2012 11:04:53 AM > Continue file writing ... OK 4/2/2012 11:04:53 AM > ---------------------------------------------------------- 4/2/2012 11:04:53 AM > Writing CODE ADDITIONAL flash file ... 4/2/2012 11:04:53 AM > Checking flash file ... 4/2/2012 11:05:00 AM > Checking flash file ... OK 4/2/2012 11:05:00 AM > Continue file writing ... 4/2/2012 11:06:16 AM > Continue file writing ... OK 4/2/2012 11:06:16 AM > ---------------------------------------------------------- 4/2/2012 11:06:16 AM > Writing FONT flash file ... 4/2/2012 11:06:16 AM > Checking flash file ... 4/2/2012 11:06:52 AM > Checking flash file ... OK 4/2/2012 11:06:52 AM > Continue file writing ... 4/2/2012 11:12:09 AM > Continue file writing ... OK 4/2/2012 11:12:09 AM > ---------------------------------------------------------- 4/2/2012 11:12:09 AM > Writing DATA flash file ... 4/2/2012 11:12:09 AM > Checking flash file ... 4/2/2012 11:12:16 AM > Checking flash file ... OK 4/2/2012 11:12:16 AM > Continue file writing ... 4/2/2012 11:13:16 AM > Continue file writing ... OK 4/2/2012 11:13:16 AM > Restarting phone ... 4/2/2012 11:13:16 AM > Restarting phone ... OK 4/2/2012 11:13:16 AM > ======== Process completed ======== 4/2/2012 11:13:16 AM > Operation time - 09:10 4/2/2012 11:13:16 AM > Port COM11 disconnected |
04-05-2012, 11:09 | #117 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Mongolia
Member: 444532 Status: Offline Sonork: 100.1576960 Thanks Meter: 214 | EVER EV-W470 unlock done. thanks vygis team 05.04.2012 17:21:22 > Software version : SAM_1_25SD.exe 05.04.2012 17:21:22 > ---------------------------------------------------------- 05.04.2012 17:32:35 > Port COM52 connected 05.04.2012 17:32:38 > Connecting ... 05.04.2012 17:32:38 > Connecting ... OK 05.04.2012 17:32:38 > Connected in NORMAL MODE 05.04.2012 17:32:39 > ---------------------------------------------------------- 05.04.2012 17:32:39 > Phone type selected : EV-W470 05.04.2012 17:32:39 > Bluetooth Addr : 00:00:00:00:00:00 05.04.2012 17:32:39 > Phone version : EV-W470_W470.327.0 05.04.2012 17:32:39 > Compilation info : Apr 29 200913:45:14Apr 29 05.04.2012 17:32:39 > 200912:00:00DP1 05.04.2012 17:32:39 > Phone code : 3333 05.04.2012 17:32:46 > ---------------------------------------------------------- 05.04.2012 17:32:46 > Unlocking ... 05.04.2012 17:32:50 > Operation failed 05.04.2012 17:32:51 > Restarting phone ... 05.04.2012 17:32:51 > Restarting phone ... OK 05.04.2012 17:32:51 > ======== Process completed ======== 05.04.2012 17:32:51 > Operation time - 00:04 05.04.2012 17:32:51 > Port COM52 disconnected 05.04.2012 17:33:28 > Port COM52 connected 05.04.2012 17:33:32 > Connecting ... 05.04.2012 17:33:32 > Connecting ... OK 05.04.2012 17:33:32 > Connected in NORMAL MODE 05.04.2012 17:33:32 > ---------------------------------------------------------- 05.04.2012 17:33:32 > Phone type selected : EV-W470 05.04.2012 17:33:32 > Bluetooth Addr : 00:00:00:00:00:00 05.04.2012 17:33:32 > Phone version : EV-W470_W470.327.0 05.04.2012 17:33:32 > Compilation info : Apr 29 200913:45:14Apr 29 05.04.2012 17:33:32 > 200912:00:00DP1 05.04.2012 17:33:32 > Phone code : 3333 05.04.2012 17:33:36 > ---------------------------------------------------------- 05.04.2012 17:33:36 > Unlocking ... 05.04.2012 17:33:36 > Entering DL mode ... 05.04.2012 17:33:38 > Entering DL mode ... OK 05.04.2012 17:33:38 > Loading main loader ... 05.04.2012 17:33:39 > Loading main loader ... OK 05.04.2012 17:33:39 > Executing loader, please wait ... 05.04.2012 17:33:43 > Executing loader, please wait ... OK 05.04.2012 17:33:43 > Authorizating loader ... 05.04.2012 17:33:43 > Authorizating loader ... OK 05.04.2012 17:33:43 > Initialing NAND ... 05.04.2012 17:33:43 > Initialing NAND ... OK 05.04.2012 17:33:43 > Continue operation ... 05.04.2012 17:33:44 > Reading security area 1 ... 05.04.2012 17:33:49 > Reading security area 1 ... OK 05.04.2012 17:33:49 > Writing security area 1 ... 05.04.2012 17:33:51 > Writing security area 1 ... OK 05.04.2012 17:33:51 > Restarting phone ... 05.04.2012 17:33:52 > Restarting phone ... OK 05.04.2012 17:33:52 > ======== Process completed ======== 05.04.2012 17:33:52 > Operation time - 00:15 05.04.2012 17:33:52 > Port COM52 disconnected |
04-10-2012, 04:28 | #118 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | 07.04.2012 9:26:18 > Software version : SAM_1_24SD.exe 07.04.2012 9:26:18 > ---------------------------------------------------------- 07.04.2012 9:26:18 > For phone connecting do next : 07.04.2012 9:26:18 > - enter "System info" menu by typing 07.04.2012 9:26:18 > "4433366368791" in dial window 07.04.2012 9:26:18 > - select "SIO MODE" 07.04.2012 9:26:18 > - select "Port Map" menu item 07.04.2012 9:26:18 > - set "Diag Monitor" to "USB CDC" value 07.04.2012 9:26:18 > - rest items in this menu set to "NULL DEV" 07.04.2012 9:28:39 > Port COM40 connected 07.04.2012 9:28:41 > Connecting ... 07.04.2012 9:28:41 > Connecting ... OK 07.04.2012 9:28:41 > ---------------------------------------------------------- 07.04.2012 9:28:41 > Phone type : SCH-W780 07.04.2012 9:28:41 > Connected in EMERGENCY MODE 07.04.2012 9:28:46 > ---------------------------------------------------------- 07.04.2012 9:28:46 > Writing flash from file : 07.04.2012 9:28:46 > SCH-W780_DA04_EN_KOR.crc 07.04.2012 9:28:46 > Extracting flash files ... 07.04.2012 9:28:52 > Extracting flash files ... OK 07.04.2012 9:28:52 > ---------------------------------------------------------- 07.04.2012 9:28:52 > Writing CODE flash file ... 07.04.2012 9:28:52 > Checking flash file ... 07.04.2012 9:28:54 > Checking flash file ... OK 07.04.2012 9:28:54 > Continue file writing ... 07.04.2012 9:30:24 > Continue file writing ... OK 07.04.2012 9:30:24 > ---------------------------------------------------------- 07.04.2012 9:30:24 > Writing FONT flash file ... 07.04.2012 9:30:24 > Checking flash file ... 07.04.2012 9:30:32 > Checking flash file ... OK 07.04.2012 9:30:32 > Continue file writing ... 07.04.2012 9:38:49 > Continue file writing ... OK 07.04.2012 9:38:49 > ---------------------------------------------------------- 07.04.2012 9:38:49 > Writing DATA flash file ... 07.04.2012 9:38:49 > Checking flash file ... 07.04.2012 9:38:52 > Checking flash file ... OK 07.04.2012 9:38:52 > Continue file writing ... 07.04.2012 9:42:16 > Continue file writing ... OK 07.04.2012 9:42:16 > Restarting phone ... 07.04.2012 9:42:16 > Restarting phone ... OK 07.04.2012 9:42:16 > ======== Process completed ======== 07.04.2012 9:42:16 > Operation time - 13:30 07.04.2012 9:42:16 > Port COM40 disconnected |
04-10-2012, 04:28 | #119 (permalink) |
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | 09.04.2012 15:16:11 > Software version : SAM_1_25SD.exe 09.04.2012 15:16:11 > ---------------------------------------------------------- 09.04.2012 15:16:11 > For phone connecting do next : 09.04.2012 15:16:11 > - enter "System info" menu by typing 09.04.2012 15:16:11 > "4433366368791" in dial window 09.04.2012 15:16:11 > - select "SIO MODE" 09.04.2012 15:16:11 > - select "Port Map" menu item 09.04.2012 15:16:11 > - set "Diag Monitor" to "USB CDC" value 09.04.2012 15:16:11 > - rest items in this menu set to "NULL DEV" 09.04.2012 15:16:41 > Port COM55 connected 09.04.2012 15:16:42 > Connecting ... 09.04.2012 15:16:42 > Connecting ... OK 09.04.2012 15:16:42 > Connected in NORMAL MODE 09.04.2012 15:16:43 > ---------------------------------------------------------- 09.04.2012 15:16:43 > Phone type selected : EV-F500 09.04.2012 15:16:43 > Bluetooth Addr : 2C:6A:40:C3:17:00 09.04.2012 15:16:43 > Phone version : EV-F500_F500.331.0 09.04.2012 15:16:43 > Compilation info : Sep 10 201012:00:00Sep 10 09.04.2012 15:16:43 > 201012:00:00TF2 09.04.2012 15:16:44 > ---------------------------------------------------------- 09.04.2012 15:16:44 > Unlocking ... 09.04.2012 15:16:44 > Entering DL mode ... 09.04.2012 15:16:50 > Entering DL mode ... OK 09.04.2012 15:16:50 > Loading main loader ... 09.04.2012 15:16:51 > Loading main loader ... OK 09.04.2012 15:16:51 > Executing loader, please wait ... 09.04.2012 15:16:52 > Executing loader, please wait ... OK 09.04.2012 15:16:52 > Authorizating loader ... 09.04.2012 15:16:53 > Authorizating loader ... OK 09.04.2012 15:16:53 > Initialing NAND ... 09.04.2012 15:16:53 > Initialing NAND ... OK 09.04.2012 15:16:53 > Continue operation ... 09.04.2012 15:16:53 > Reading security area 1 ... 09.04.2012 15:16:56 > Reading security area 1 ... OK 09.04.2012 15:16:56 > Writing security area 1 ... 09.04.2012 15:16:56 > Writing security area 1 ... OK 09.04.2012 15:16:56 > Restarting phone ... 09.04.2012 15:16:57 > Restarting phone ... OK 09.04.2012 15:16:57 > ======== Process completed ======== 09.04.2012 15:16:57 > Operation time - 00:12 09.04.2012 15:16:57 > Port COM57 disconnected |
04-10-2012, 07:02 | #120 (permalink) |
Registered User Join Date: Sep 2006 Location: viet nam
Member: 350201 Status: Offline Thanks Meter: 52 | EVER - W530 Unlock Done ! Code: 4/10/2012 12:44:10 PM > Software version : SAM_1_25SD.exe 4/10/2012 12:44:10 PM > ---------------------------------------------------------- 4/10/2012 12:51:28 PM > Port COM204 connected 4/10/2012 12:51:29 PM > Connecting ... 4/10/2012 12:51:30 PM > Connecting ... OK 4/10/2012 12:51:30 PM > Connected in NORMAL MODE 4/10/2012 12:51:30 PM > ---------------------------------------------------------- 4/10/2012 12:51:30 PM > Phone type selected : EV-W530 4/10/2012 12:51:30 PM > Bluetooth Addr : 00:00:00:00:00:00 4/10/2012 12:51:30 PM > Phone version : EV-W530_W530.318.0 4/10/2012 12:51:30 PM > Compilation info : Jul 09 200913:07:23Jul 09 4/10/2012 12:51:30 PM > 200912:00:01FA1 4/10/2012 12:51:30 PM > Phone code : 0000 4/10/2012 12:51:32 PM > ---------------------------------------------------------- 4/10/2012 12:51:32 PM > Unlocking ... 4/10/2012 12:51:32 PM > Entering DL mode ... 4/10/2012 12:51:34 PM > Entering DL mode ... OK 4/10/2012 12:51:34 PM > Loading main loader ... 4/10/2012 12:51:35 PM > Loading main loader ... OK 4/10/2012 12:51:35 PM > Executing loader, please wait ... 4/10/2012 12:51:37 PM > Executing loader, please wait ... OK 4/10/2012 12:51:37 PM > Authorizating loader ... 4/10/2012 12:51:37 PM > Authorizating loader ... OK 4/10/2012 12:51:37 PM > Initialing NAND ... 4/10/2012 12:51:37 PM > Initialing NAND ... OK 4/10/2012 12:51:37 PM > Continue operation ... 4/10/2012 12:51:38 PM > Reading security area 1 ... 4/10/2012 12:51:41 PM > Reading security area 1 ... OK 4/10/2012 12:51:41 PM > Writing security area 1 ... 4/10/2012 12:51:43 PM > Writing security area 1 ... OK 4/10/2012 12:51:43 PM > Restarting phone ... 4/10/2012 12:51:44 PM > Restarting phone ... OK 4/10/2012 12:51:44 PM > ======== Process completed ======== 4/10/2012 12:51:44 PM > Operation time - 00:11 4/10/2012 12:51:44 PM > Port COM204 disconnected |
Upload & Download Eprom | Lousangeles | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-24-1999 05:45 |
