Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > VygisToolbox
Old 08-12-2011, 04:54   #16 (permalink)
Member: 690160
Sonork: 100.1583287
all time vygis is top box for lg and now for anycall thanx team
Old 08-16-2011, 14:12   #17 (permalink)
tuban_gsm's Avatar
Member: 589534
SCH W770 unlock done..
Phone type selected : SCH-W770
IMEI : 353654-03-754177-5
Bluetooth Addr : E8:E56:C0:BDB
Phone version : SAMSUNG Electronics
Compilation info : Feb 05 201014:22:40Feb 05 201014:22:40SCH-W770
Phone code : 1111
Connecting ... OK
Connected in NORMAL MODE
Reseting phone ... OK
======== Process completed ========
Operation time - 00:00
thanks.
The Following User Says Thank You to tuban_gsm For This Useful Post:
Old 08-21-2011, 09:48   #18 (permalink)
shuric's Avatar
Member: 444532
Sonork: 100.1576960
SPH-W360 unlock done.
try with octopus can't unlock. with vygis unlock OK.
thanx vygis team.
21.08.2011 15:07:31 > Software version : SAM_1_13SD.exe
21.08.2011 15:07:31 > ----------------------------------------------------------
21.08.2011 15:12:02 > For phone connecting do next :
21.08.2011 15:12:02 > - enter "System info" menu by typing
21.08.2011 15:12:02 > "4433366368791" in dial window
21.08.2011 15:12:02 > - select "SIO MODE"
21.08.2011 15:12:02 > - select "Port Map" menu item
21.08.2011 15:12:02 > - set "Diag Monitor" to "USB CDC" value
21.08.2011 15:12:02 > - rest items in this menu set to "NULL DEV"
21.08.2011 15:12:46 > Port COM57 connected
21.08.2011 15:12:53 > Connecting ...
21.08.2011 15:12:53 > Connecting ... OK
21.08.2011 15:12:53 > Connected in NORMAL MODE
21.08.2011 15:12:55 > ----------------------------------------------------------
21.08.2011 15:12:55 > Phone type selected : SPH-W4200
21.08.2011 15:12:55 > IMEI : 004400-15-202514-2
21.08.2011 15:12:55 > Bluetooth Addr : 00:00:00:00:00:00
21.08.2011 15:12:55 > Phone version : M6280A-KLRZ-4.0.5060T
21.08.2011 15:12:55 > Compilation info : Jun 05 200811:27:11Oct 11
21.08.2011 15:12:55 > 200706:00:00SPH-W360
21.08.2011 15:12:55 > Phone code : 0000
21.08.2011 15:12:55 > Flash ID : 98CA
21.08.2011 15:12:55 > Flash type : toshiba_tya000bc
21.08.2011 15:12:55 > Flash size : 02600000
21.08.2011 15:12:55 > Flash pages count : 00004C00
21.08.2011 15:12:55 > Flash page size : 00000800
21.08.2011 15:12:55 > Flash block size : 00020000
21.08.2011 15:13:01 > ----------------------------------------------------------
21.08.2011 15:13:01 > Unlocking ...
21.08.2011 15:13:01 > Unlocking ... OK
21.08.2011 15:13:01 > Restarting phone ...
21.08.2011 15:13:02 > Restarting phone ... OK
21.08.2011 15:13:02 > ======== Process completed ========
21.08.2011 15:13:02 > Operation time - 00:00
21.08.2011 15:13:02 > Port COM57 disconnected
The Following User Says Thank You to shuric For This Useful Post:
Old 08-21-2011, 10:46   #19 (permalink)
shuric's Avatar
Member: 444532
Sonork: 100.1576960
SPH-W5310 unlock done.
thanx vygis team.
21.08.2011 17:21:51 > Software version : SAM_1_13SD.exe
21.08.2011 17:21:51 > ----------------------------------------------------------
21.08.2011 17:21:51 > For phone connecting do next :
21.08.2011 17:21:51 > - enter "System info" menu by typing
21.08.2011 17:21:51 > "4433366368791" in dial window
21.08.2011 17:21:51 > - select "SIO MODE"
21.08.2011 17:21:51 > - select "Port Map" menu item
21.08.2011 17:21:51 > - set "Diag Monitor" to "USB CDC" value
21.08.2011 17:21:51 > - rest items in this menu set to "NULL DEV"
21.08.2011 17:21:56 > Port COM57 connected
21.08.2011 17:21:59 > Connecting ...
21.08.2011 17:21:59 > Connecting ... OK
21.08.2011 17:21:59 > Connected in NORMAL MODE
21.08.2011 17:22:02 > ----------------------------------------------------------
21.08.2011 17:22:02 > Phone type selected : SPH-W4200
21.08.2011 17:22:02 > IMEI : 353792-02-306597-7
21.08.2011 17:22:02 > Bluetooth Addr : 00:00:00:00:00:00
21.08.2011 17:22:02 > Phone version : M6260A-KYRZ-2.5.1033T
21.08.2011 17:22:02 > Compilation info : Oct 22 200813:16:05Apr 30
21.08.2011 17:22:02 > 200814:00:00SPH-W531
21.08.2011 17:22:02 > Phone code : 0247
21.08.2011 17:22:02 > Flash ID : 98CA
21.08.2011 17:22:02 > Flash type : toshiba_tya000bc
21.08.2011 17:22:02 > Flash size : 02600000
21.08.2011 17:22:02 > Flash pages count : 00004C00
21.08.2011 17:22:02 > Flash page size : 00000800
21.08.2011 17:22:02 > Flash block size : 00020000
21.08.2011 17:22:18 > ----------------------------------------------------------
21.08.2011 17:22:18 > Unlocking ...
21.08.2011 17:22:18 > Unlocking ... OK
21.08.2011 17:22:18 > Restarting phone ...
21.08.2011 17:22:18 > Restarting phone ... OK
21.08.2011 17:22:18 > ======== Process completed ========
21.08.2011 17:22:18 > Operation time - 00:00
21.08.2011 17:22:19 > Port COM57 disconnected
The Following 2 Users Say Thank You to shuric For This Useful Post:
Old 09-26-2011, 13:12   #20 (permalink)
Member: 758627
9/26/2011 6:34:50 PM > Software version : SAM_1_14SD.exe
9/26/2011 6:34:50 PM > ----------------------------------------------------------
9/26/2011 6:34:50 PM > For phone connecting do next :
9/26/2011 6:34:50 PM > - enter "System info" menu in next way :
9/26/2011 6:34:50 PM > - enter to phone menu
9/26/2011 6:34:50 PM > - long press "0" till password window will appear
9/26/2011 6:34:50 PM > - enter password "6725"
9/26/2011 6:34:50 PM > - select "SIO MODE"
9/26/2011 6:34:50 PM > - select "Port Map" menu item
9/26/2011 6:34:50 PM > - set "Diag Monitor" to "USB CDC" value
9/26/2011 6:34:50 PM > - rest items in this menu set to "NULL DEV"
9/26/2011 6:39:26 PM > For phone connecting do next :
9/26/2011 6:39:26 PM > - enter "System info" menu in next way :
9/26/2011 6:39:26 PM > - enter to phone menu
9/26/2011 6:39:26 PM > - long press "0" till password window will appear
9/26/2011 6:39:26 PM > - enter password "0821"
9/26/2011 6:39:26 PM > - select "SIO MODE"
9/26/2011 6:39:26 PM > - select "Port Map" menu item
9/26/2011 6:39:26 PM > - set "Diag Monitor" to "USB CDC" value
9/26/2011 6:39:26 PM > - rest items in this menu set to "NULL DEV"
9/26/2011 6:41:26 PM > Port COM29 connected
9/26/2011 6:41:27 PM > Connecting ...
9/26/2011 6:41:27 PM > Connecting ... OK
9/26/2011 6:41:27 PM > Connected in NORMAL MODE
9/26/2011 6:41:27 PM > ----------------------------------------------------------
9/26/2011 6:41:27 PM > Phone type selected : SPH-W5310
9/26/2011 6:41:27 PM > IMEI : 353792-02-113982-4
9/26/2011 6:41:27 PM > Bluetooth Addr : 00:24:90:02:58:23
9/26/2011 6:41:27 PM > Phone version : M6260A-KYRZ-2.5.1033T
9/26/2011 6:41:27 PM > Compilation info : Oct 22 200812:34:15Apr 30
9/26/2011 6:41:27 PM > 200814:00:00SPH-W531
9/26/2011 6:41:27 PM > Phone code : 3692
9/26/2011 6:41:27 PM > Flash ID : 98CA
9/26/2011 6:41:27 PM > Flash type : toshiba_tya000bc
9/26/2011 6:41:27 PM > Flash size : 02600000
9/26/2011 6:41:27 PM > Flash pages count : 00004C00
9/26/2011 6:41:27 PM > Flash page size : 00000800
9/26/2011 6:41:27 PM > Flash block size : 00020000
9/26/2011 6:41:34 PM > ----------------------------------------------------------
9/26/2011 6:41:34 PM > Unlocking ...
9/26/2011 6:41:34 PM > Unlocking ... OK
9/26/2011 6:41:34 PM > Restarting phone ...
9/26/2011 6:41:34 PM > Restarting phone ... OK
9/26/2011 6:41:34 PM > ======== Process completed ========
The Following User Says Thank You to cuong87 For This Useful Post:
Old 09-26-2011, 15:03   #21 (permalink)
GsmSolution.'s Avatar
Member: 1388679
Sonork: 1597516:GsmSolution
SCH-W9000 unlock done
vygis really rocks
br
Old 09-28-2011, 07:11   #22 (permalink)
Member: 19020
samsung anycall w550 phonelock and unlock by vygis.
this is the logs and procedure.
1. flashing
2. unlocking
this is the phone after flashing, unlocking and entering the phone lock.
For reference to all VYGIS user.
Thanks VYGIS for the nice update.
THANKS to you LORD!!!
Old 09-28-2011, 09:24   #23 (permalink)
Member: 19020
samsung anycall show w2900ml unlock done with VYGIS.
here is the logs.
first flashing.
second unlocking.
finish product.
Thanks VYGIS team.
Old 09-29-2011, 08:55   #24 (permalink)
gsmbacgiang's Avatar
Member: 1518666
Sonork: 100.1608201
SPH-W8300 Unlock done !
Connecting ... OK
Unlocking ...
Switching to DL Mode ... OK
Reading security area 1 ... OK
Writing security area 1 ... OK
Operation time - 00:07
Old 10-01-2011, 07:55   #25 (permalink)
Member: 501129
Phone type selected : SPH-W8300
IMEI : 354521-03-011751-6
Bluetooth Addr : 00:26:5F:11:21:7C
Phone version : M6260A-KYRZ-2.5.1040T
Compilation info : Aug 07 200911:32:00Jan 22 200905:00:00SPH-W830
Phone code : 0902
Connecting ... OK
Unlocking ...
Operation time - 00:12
Old 10-02-2011, 11:01   #26 (permalink)
Member: 1575434
Sonork: 100.1575103
SHW-A130K unlock OK
SHW-A130K unlock OK
LOG HERE
10/2/2011 12:04:44 PM > ----------------------------------------------------------
10/2/2011 12:04:44 PM > Phone type selected : SHW-A130K
10/2/2011 12:04:44 PM > IMEI : 359656-03-073412-9
10/2/2011 12:04:44 PM > Bluetooth Addr : D4:E8:B2:7C:54:E1
10/2/2011 12:04:44 PM > Phone version : SAMSUNG Electronics
10/2/2011 12:04:44 PM > Compilation info : Jun 14 201022:25:21Sep 08
10/2/2011 12:04:44 PM > 200914:00:00SHW-A130
10/2/2011 12:04:44 PM > Phone code : 1211
10/2/2011 12:04:47 PM > ----------------------------------------------------------
10/2/2011 12:04:47 PM > Unlocking ...
10/2/2011 12:04:47 PM > Switching to DL Mode ...
10/2/2011 12:04:55 PM > Switching to DL Mode ... OK
10/2/2011 12:04:55 PM > Reading security area 1 ...
10/2/2011 12:04:59 PM > Reading security area 1 ... OK
10/2/2011 12:04:59 PM > Reading security area 2 ...
10/2/2011 12:05:06 PM > Reading security area 2 ... OK
10/2/2011 12:05:06 PM > Restarting phone ...
10/2/2011 12:05:06 PM > Restarting phone ... OK
10/2/2011 12:05:06 PM > Seeking phone, please wait ...
10/2/2011 12:05:41 PM > Seeking phone, please wait ... OK
10/2/2011 12:05:41 PM > Switching to DL Mode ...
10/2/2011 12:05:49 PM > Switching to DL Mode ... OK
10/2/2011 12:05:49 PM > Writing security area 1 ...
10/2/2011 12:05:50 PM > Writing security area 1 ... OK
10/2/2011 12:05:51 PM > Writing security area 2 ...
10/2/2011 12:05:52 PM > Writing security area 2 ... OK
10/2/2011 12:05:52 PM > Restarting phone ...
10/2/2011 12:05:52 PM > Restarting phone ... OK
10/2/2011 12:05:52 PM > ======== Process completed ========
tks Vigys TEAM
B.R
LinhNC
Old 10-03-2011, 19:12   #27 (permalink)
Member: 523840
SPH-W360 unlock done..................
I try with octopus Box but can't unlock.............
Now with vygis unlock OK. :
thanx to gr8 team
10/2/2011 8:20:43 PM > Software version : SAM_1_14SD.exe
10/2/2011 8:20:43 PM > ----------------------------------------------------------
10/2/2011 8:20:43 PM > For phone connecting do next :
10/2/2011 8:20:43 PM > - enter "System info" menu in next way :
10/2/2011 8:20:43 PM > - enter to phone menu
10/2/2011 8:20:43 PM > - long press "0" till password window will appear
10/2/2011 8:20:43 PM > - enter password "0821"
10/2/2011 8:20:43 PM > - select "SIO MODE"
10/2/2011 8:20:43 PM > - select "Port Map" menu item
10/2/2011 8:20:43 PM > - set "Diag Monitor" to "USB CDC" value
10/2/2011 8:20:43 PM > - rest items in this menu set to "NULL DEV"
10/2/2011 8:23:21 PM > Port COM96 connected
10/2/2011 8:23:24 PM > Connecting ...
10/2/2011 8:23:24 PM > Connecting ... OK
10/2/2011 8:23:24 PM > Connected in NORMAL MODE
10/2/2011 8:23:26 PM > ----------------------------------------------------------
10/2/2011 8:23:26 PM > Phone type selected : SCH-W360
10/2/2011 8:23:26 PM > IMEI : 358122-01-212834-4
10/2/2011 8:23:26 PM > Bluetooth Addr : 00:23:3A:22:18:41
10/2/2011 8:23:26 PM > Phone version : SAMSUNG Electronics
10/2/2011 8:23:26 PM > Compilation info : Sep 05 200809:18:54Aug 21
10/2/2011 8:23:26 PM > 200707:00:00SCH-W360
10/2/2011 8:23:26 PM > Phone code : 1478
10/2/2011 8:23:26 PM > Flash ID : 98CA
10/2/2011 8:23:26 PM > Flash type : toshiba_tya000bc
10/2/2011 8:23:26 PM > Flash size : 00800000
10/2/2011 8:23:26 PM > Flash pages count : 00001000
10/2/2011 8:23:26 PM > Flash page size : 00000800
10/2/2011 8:23:26 PM > Flash block size : 00020000
10/2/2011 8:23:29 PM > ----------------------------------------------------------
10/2/2011 8:23:29 PM > Unlocking ...
10/2/2011 8:23:29 PM > Unlocking ... OK
10/2/2011 8:23:29 PM > Restarting phone ...
10/2/2011 8:23:29 PM > Restarting phone ... OK
10/2/2011 8:23:29 PM > ======== Process completed ========
Old 10-05-2011, 09:59   #28 (permalink)
Risan Fassy's Avatar
Member: 617198
Sonork: 100.1606436
Sch-w330
9/19/2011 1:08:53 PM > Phone type selected : SCH-W330
9/19/2011 1:08:53 PM > IMEI : 356935-01-XXXXXXX
9/19/2011 1:08:53 PM > Bluetooth Addr : 00:1E:E1:F3:AE:0D
9/19/2011 1:08:53 PM > Phone version : M6260A-KYRZ-2.1.302415
9/19/2011 1:08:53 PM > Compilation info : Jan 07 200815:36:54Nov 27
9/19/2011 1:08:53 PM > 200703:00:00SCH-W330
9/19/2011 1:08:53 PM > Phone code : 0000
9/19/2011 1:08:53 PM > Flash ID : 2079
9/19/2011 1:08:53 PM > Flash type : st_1gw3a2b
9/19/2011 1:08:53 PM > Flash size : 00E00000
9/19/2011 1:08:53 PM > Flash pages count : 00007000
9/19/2011 1:08:53 PM > Flash page size : 00000200
9/19/2011 1:08:53 PM > Flash block size : 00004000
9/19/2011 1:09:09 PM > ----------------------------------------------------------
9/19/2011 1:09:09 PM > Reading NVM ...
9/19/2011 1:21:41 PM > Reading NVM ... OK
9/19/2011 1:21:41 PM > Flash saved to file :
9/19/2011 1:21:41 PM > NV_SCH-W330_356935-01-XXXXXXX_2011_9_1
9/19/2011 1:21:41 PM > 9_13_9.nv2
9/19/2011 1:21:41 PM > ======== Process completed ========
9/19/2011 1:21:41 PM > Operation time - 12:32
9/19/2011 1:22:23 PM > ----------------------------------------------------------
9/19/2011 1:22:23 PM > Unlocking ...
9/19/2011 1:22:23 PM > Unlocking ... OK
9/19/2011 1:22:23 PM > Restarting phone ...
9/19/2011 1:22:23 PM > Restarting phone ... OK
9/19/2011 1:22:23 PM > ======== Process completed ========
9/19/2011 1:22:23 PM > Operation time - 00:00
9/19/2011 1:22:23 PM > Port COM53 disconnected
Old 10-08-2011, 02:18   #29 (permalink)
Member: 1518666
Sonork: 100.1608201
Samsung Anycall SCH-W830 Unlock done !
Old 10-09-2011, 19:47   #30 (permalink)
pititi1974's Avatar
Member: 43253
Phone type : SPH-W8400
Connecting ... OK
Connected in EMERGENCY MODE
Unlocking ...
Operation time - 00:40
Connect phone in emergency mode
Press and hold "4"+"Power ON" keys
The Following User Says Thank You to pititi1974 For This Useful Post:
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 16 02-01-2012 05:18
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-18-2011 11:00
Upload & Download Eprom Lousangeles Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 8 09-16-2011 13:43
vBulletin Optimisation provided by vB Optimise v2.5.2 (Lite) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. ()
Page generated in 0.59112 seconds with 12 queries
