01-07-2012, 12:23 | #80 (permalink) | |
No Life Poster Join Date: Nov 2003 Location: near you ...
Member: 43036 Status: Offline Sonork: 100.62160 Thanks Meter: 2,386 | Send to me your SN dongle en Private Message please . to solve the problem . Quote:
http://www.mediafire.com/download.php?6tamt53wmc26j6r BR,Douhal Last edited by DOUHAL; 01-07-2012 at 12:35. | |
The Following User Says Thank You to DOUHAL For This Useful Post: |
01-11-2012, 12:10 | #82 (permalink) |
Freak Poster Join Date: Jul 2010 Location: BANGLADESH Age: 35
Member: 1348472 Status: Offline Sonork: 100.1587907 Thanks Meter: 17 | Succesfully Unlocked Samsung_AnyCall , SCH-W460 done!! Phone type selected : SCH-W460 IMEI : 355066-02-485816-1 Bluetooth Addr : 00:25:66:2B:73:26 Phone version : M6260A-KYRZ-2.5.1033T Compilation info : Mar 26 200913:33:44Nov 27 200703:00:00SCH-W460 -------------------------------------------------------------------- Flash size : 00F00000 Flash pages count : 00007800 Flash page size : 00000200 Flash block size : 00004000 ---------------------------------------------------------- Unlocking ... Switching to DL Mode ... OK Reading security area 1 ... OK Writing security area 1 ... OK Restarting phone ... OK ======== Process completed ======== Operation time - 00:06 br, john ibrahim |
01-15-2012, 10:39 | #83 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Uzbekistan Age: 45
Member: 1293050 Status: Offline Sonork: 100.1625975 Thanks Meter: 668 | 15.01.2012 11:08:20 > Software version : SAM_1_18SD.exe 15.01.2012 11:08:20 > ---------------------------------------------------------- 15.01.2012 11:08:20 > For phone connecting do next : 15.01.2012 11:08:20 > - go to dial window 15.01.2012 11:08:20 > - enter "*#9090#" number 15.01.2012 11:08:20 > - open numerical keyboard and press "1" 15.01.2012 11:08:20 > - "UART_HFK USB_Diag Change complete" 15.01.2012 11:08:20 > message must appear 15.01.2012 11:08:20 > - press "END" softbutton 15.01.2012 11:08:20 > - go to "MENU" - "SETTINGS" 15.01.2012 11:08:20 > - in upper menu select symbol with arrows 15.01.2012 11:08:20 > - in oppened connections menu select "USB" 15.01.2012 11:08:20 > - if "Active Sync" is checked dissable it 15.01.2012 11:08:20 > - check "Phone" and press left lower softbutton 15.01.2012 11:08:20 > - restart phone 15.01.2012 11:08:27 > For phone connecting do next : 15.01.2012 11:08:27 > - enter "System info" menu by typing 15.01.2012 11:08:27 > "4433366368791" in dial window 15.01.2012 11:08:27 > - select "SIO MODE" 15.01.2012 11:08:27 > - select "Port Map" menu item 15.01.2012 11:08:27 > - set "Diag Monitor" to "USB CDC" value 15.01.2012 11:08:27 > - rest items in this menu set to "NULL DEV" 15.01.2012 11:09:44 > Port COM24 connected 15.01.2012 11:19:37 > Connecting ... 15.01.2012 11:19:37 > Connecting ... OK 15.01.2012 11:19:37 > Connected in NORMAL MODE 15.01.2012 11:19:37 > ---------------------------------------------------------- 15.01.2012 11:19:37 > Phone type selected : SPH-W9000 15.01.2012 11:19:37 > IMEI : 356463-03-121692-2 15.01.2012 11:19:37 > Bluetooth Addr : A8:F2:74:C3:7C:97 15.01.2012 11:19:37 > Phone version : SAMSUNG Electronics 15.01.2012 11:19:37 > Compilation info : Feb 02 201011:39:51Feb 02 15.01.2012 11:19:37 > 201011:39:51SPH-W900 15.01.2012 11:19:37 > Phone code : 2580 15.01.2012 11:21:02 > ---------------------------------------------------------- 15.01.2012 11:21:02 > Writing flash from file : 15.01.2012 11:21:02 > SPH-W9000_DB02_EN_KOR.crc 15.01.2012 11:21:02 > Switching to DL Mode ... 15.01.2012 11:21:06 > Switching to DL Mode ... OK 15.01.2012 11:21:06 > Extracting flash files ... 15.01.2012 11:21:13 > Extracting flash files ... OK 15.01.2012 11:21:13 > ---------------------------------------------------------- 15.01.2012 11:21:13 > Writing CODE flash file ... 15.01.2012 11:21:13 > Checking flash file ... 15.01.2012 11:21:15 > Checking flash file ... OK 15.01.2012 11:21:15 > Continue file writing ... 15.01.2012 11:22:37 > Continue file writing ... OK 15.01.2012 11:22:37 > ---------------------------------------------------------- 15.01.2012 11:22:37 > Writing FONT flash file ... 15.01.2012 11:22:37 > Checking flash file ... 15.01.2012 11:22:43 > Checking flash file ... OK 15.01.2012 11:22:43 > Continue file writing ... 15.01.2012 11:26:35 > Continue file writing ... OK 15.01.2012 11:26:35 > ---------------------------------------------------------- 15.01.2012 11:26:35 > Writing DATA flash file ... 15.01.2012 11:26:35 > Checking flash file ... 15.01.2012 11:26:38 > Checking flash file ... OK 15.01.2012 11:26:38 > Continue file writing ... 15.01.2012 11:27:43 > Continue file writing ... OK 15.01.2012 11:27:43 > Restarting phone ... 15.01.2012 11:27:43 > Restarting phone ... OK 15.01.2012 11:27:43 > ======== Process completed ======== 15.01.2012 11:27:43 > Operation time - 06:41 15.01.2012 11:27:43 > Port COM25 disconnected 15.01.2012 11:28:31 > Port COM24 connected 15.01.2012 11:28:32 > Connecting ... 15.01.2012 11:28:32 > Connecting ... OK 15.01.2012 11:28:32 > Connected in NORMAL MODE 15.01.2012 11:28:32 > ---------------------------------------------------------- 15.01.2012 11:28:32 > Phone type selected : SPH-W9000 15.01.2012 11:28:32 > IMEI : 356463-03-121692-2 15.01.2012 11:28:32 > Bluetooth Addr : A8:F2:74:C3:7C:97 15.01.2012 11:28:32 > Phone version : SAMSUNG Electronics 15.01.2012 11:28:32 > Compilation info : Feb 02 201011:39:51Feb 02 15.01.2012 11:28:32 > 201011:39:51SPH-W900 15.01.2012 11:28:32 > Phone code : 2580 15.01.2012 11:28:36 > ---------------------------------------------------------- 15.01.2012 11:28:36 > Unlocking ... 15.01.2012 11:28:36 > Switching to DL Mode ... 15.01.2012 11:28:41 > Switching to DL Mode ... OK 15.01.2012 11:28:41 > Reading security area 1 ... 15.01.2012 11:28:41 > Reading security area 1 ... OK 15.01.2012 11:28:41 > Writing security area 1 ... 15.01.2012 11:28:42 > Writing security area 1 ... OK 15.01.2012 11:28:42 > Restarting phone ... 15.01.2012 11:28:42 > Restarting phone ... OK 15.01.2012 11:28:42 > ======== Process completed ======== 15.01.2012 11:28:42 > Operation time - 00:06 15.01.2012 11:28:42 > Port COM25 disconnected |
01-17-2012, 11:26 | #84 (permalink) |
Registered User Join Date: Feb 2009 Location: Craiova(Romania) Age: 18
Member: 972420 Status: Offline Sonork: manole Thanks Meter: 134 | w450 anycall samsung done unlock by vygis...... procedure: cable:v840 first select model correct then install driver anycall info read nvm then tick direct unlock done po..... thanks *** kahabol rin unlock anycall........ |
01-18-2012, 18:19 | #85 (permalink) |
No Life Poster Join Date: Nov 2003 Location: kjhjk Age: 50
Member: 43253 Status: Offline Thanks Meter: 157 | LG HB620 Phone type selected : HB620 IMEI : 35405002-------- Bluetooth Addr : 00:1F:6B:91:3A:6E Phone version : HB620-MSM6280-V10a-MAY-02-2008-H3G-IT Compilation info : May 02 200820:43:21May 02 200818:00:00HB620 Flash ID : 98CA Flash type : toshiba_tya000bc00bogg Flash size : 0CDC0000 Flash pages count : 00019B80 Flash page size : 00000800 Flash block size : 00020000 ---------------------------------------------------------- Unlocking ... Loading preloader... OK Preparing main loader,please wait ... OK Loading main loader ... OK Initialing NAND ... OK Making backup file ... OK Decrypting security zone ... OK Checking security ... OK Writing lock blocks ... OK Writing info blocks ... OK Unlocking NVM ... OK Reseting phone ... OK ======== Process completed ======== Operation time - 00:08 |
01-26-2012, 12:28 | #86 (permalink) |
Major Poster Join Date: Jun 2007
Member: 522732 Status: Offline Thanks Meter: 3 | sky im-s350 unlock done procedure on cp menu go to settings long press 0 password 000000 select comm.env. select dm port select usb ds port select usb then press save on pc open SAM_1_16SD press cennect port press connect phone press direct unlock and wait for payment logs Phone type selected : SKY-IM-S350 IMEI : 355334-**-******-* Phone version : M6281A-KLRZ-4.0.9530T Compilation info : Nov 06 200820:16:57Jan 07 200819:00:00S0175153 Phone code : **** Connecting ... OK Connected in NORMAL MODE ---------------------------------------------------------- Unlocking ... Reading NVM backup ... OK Continue unlocking ... OK Restarting phone ... OK ======== Process completed ======== Operation time - 00:04 screen shot |
The Following User Says Thank You to marzl For This Useful Post: |
01-27-2012, 10:54 | #87 (permalink) |
No Life Poster Join Date: Dec 2006 Location: P A K I S T A N
Member: 416286 Status: Offline Sonork: 100.1622339 Thanks Meter: 759 | Hello Vygis support i try to download SPH-W9600_DC24u_EN_KOR.rar 3 times or more but when i extract i get error like this means file on support is corrupted plz check it and from other support i get error on 30% every time while downloading plz fix it and can you please upload it on mediafire that i can download it now... i need it urgent |
02-01-2012, 10:55 | #89 (permalink) |
No Life Poster Join Date: May 2009 Location: pattaya
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | SPH-W7700 unlock ok Phone type selected : SPH-W7700 IMEI : 353630-03-499862-2 Bluetooth Addr : 54:92:BE:F0:AF:6A Phone version : M6281A-KLRZ-4.0.9565T Compilation info : Sep 03 200922:13:55May 05 200808:00:00SPH-W770 Phone code : 4308 Connecting ... OK Connected in NORMAL MODE ---------------------------------------------------------- Unlocking ... Switching to DL Mode ... OK Reading security area 1 ... OK Writing security area 1 ... OK Restarting phone ... OK ======== Process completed ======== Operation time - 00:11 |
The Following User Says Thank You to wsmobile For This Useful Post: |
02-18-2012, 07:41 | #90 (permalink) |
Member deceased !! Join Date: Jan 2008 Location: DreamSunlock Canada,TH,CN,BD Age: 36
Member: 670820 Status: Offline Sonork: 100.1583728 Thanks Meter: 1,348 | Anycall w390 unlock done ANYCALL W390 UNLOCK DONE Connecting ... OK Connected in NORMAL MODE Flash ID : EC79 Flash type : samsung_k5d1g13dcm Flash size : 00E00000 Flash pages count : 00007000 Flash page size : 00000200 Flash block size : 00004000 ---------------------------------------------------------- Unlocking ... OK Restarting phone ... OK ======== Process completed ======== Operation time - 00:00 |
The Following 4 Users Say Thank You to [email protected] For This Useful Post: |
Upload & Download Eprom | Lousangeles | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-24-1999 05:45 |
