05-31-2011, 09:50 | #1 (permalink) |
Freak Poster Join Date: Jan 2011 Location: norfolk Age: 54
Member: 1486828 Status: Offline Sonork: pcs1234 Thanks Meter: 53 | LG S310 Problems (ANSWERED/SOLVED) Phone type selected : LG-S310 CPU type : MT6235B, E00 Phone IMEI A : 354142-04-357326-2 Software version : MAUI.09AW0944LGE_WISE_SP.W10.32 Hardware version : ROSEMARY_HW ---------------------------------------------------------- CPU type : 6235 CPU hardware ID : 8B00 CPU software ID : 8A01 ---------------------------------------------------------- Loading primary loader ... OK Loading secondary loader ... OK Executing loader ... OK Reading flash info ... OK Flash ID : 0002 Flash type : UNKNOWN Flash size : 0x00000020 Changing baudrate ... Can't change baudrate Operation failed ive tried 2 cables,also tried flash it with LG-S310_LGS310AT-00-V10d-460-XXX-JAN-11-2011_EN_CN_KOR_fw. i t the only flash i can get for it .Any one with a clever idea ,im all ears |
05-31-2011, 11:29 | #2 (permalink) |
No Life Poster Join Date: May 2001 Location: Lithuania
Member: 4458 Status: Offline Thanks Meter: 25,853 | I can advice only to use LGM_1_19SD and try other box like interface to phone, I mean if you have Infinity,Furiuos,Z3X or other FTDI based box-use it like interface-simply in LGM software select port on which this other box is.Also at supports exists more firmwares for this phone Regards, Vygis |
05-31-2011, 11:42 | #3 (permalink) |
Member: 1486828 Status: Offline Sonork: pcs1234 Thanks Meter: 53 | you are totally amazing ,i would have never thought to use another box while using the vygis software ,i used the z3x box and it reads codes and every thing ,But the flash file i have finishes in 30 seconds ,cant be the write one,can you be for specific where to get the flash file ,cheers |
05-31-2011, 11:54 | #5 (permalink) |
Member: 4458 Status: Offline Thanks Meter: 25,853 | All flashes are at support sites - "LG"-"LG software" - "Firmwares for lang.changing"-"LG-S310". Download anyone of them,extract from rar - use LGM_1_19SD - in it go to "Flasher" section and simply drag and drop extracted flash to flasher window.After this "Write files & Do Jobs" Regards, Vygis P.S.Flashing time is about 22 minutes-if can-charge battery |
05-31-2011, 13:29 | #8 (permalink) |
Member: 1486828 Status: Offline Sonork: pcs1234 Thanks Meter: 53 | sorted 100% sorted as above ,i pluged the vygis box in and run the software for the S310 ,then pluged the Z3x box in and selected the port in the vygis software for the Z3x box,and pluged the phone in the Z3x box and flashed the phone (took 22 mins),then unlocked it ,This has been bugging me for 2 weeks now ,SO PLEEEESED For connecting remove battery from phone, connect RJ45 cable to phone and put battery to it ... ---------------------------------------------------------- CPU type : 6235 CPU hardware ID : 8B00 CPU software ID : 8A01 ---------------------------------------------------------- Loading primary loader ... OK Loading secondary loader ... OK Executing loader ... OK Reading flash info ... OK Flash ID : ECB1 Flash type : SAMSUNG Flash size : 0x08000000 Changing baudrate ... OK ---------------------------------------------------------- Reading security area ... OK Decrypting security area ... OK Found next codes : NCK : 7870 9269 9961 6062 SPCK : 8941 0988 2366 7661 NSCK : 7431 3758 7991 3603 CCK : 8264 1963 1334 5091 SIM : 2645 5895 3591 2667 ======== Process completed ======== Operation time - 00:18 ---------------------------------------------------------- For operation finishing,do next : - power phone ON without SIM - type 2945#*310# to enter unlock menu - enter needed unlock code |
02-10-2012, 05:33 | #9 (permalink) |
Freak Poster Join Date: Jan 2011 Location: old post office road phagwara Age: 38
Member: 1500871 Status: Offline Thanks Meter: 137 | Reconnect battery and press power button now! S310 Codereader Started; Getting MCUID... Booting... You can release power key now! Project Name: MT6235B_S00 [!] Failed to detect RAM (Possible HW failure) NOR Detected : N/A NAND Detected : N/A Advanced detection information: BBCHIP: "MT6235B_S00", EXT_26M CODE(0x6235), VER(0x8B00), SW(0x8A00) NOR_ID: "NOR_UNKNOWN" NOR_ID: 0x0000, 0x0000, 0x0000, 0x0000 NAND_ID: "NAND_UNKNOWN" NAND_ID: 0x00EC, 0x00B1, 0x0000, 0x0055 Detection Done! ReadBack Failed:? |
03-31-2012, 17:07 | #10 (permalink) | |
Super Moderator Join Date: Aug 2005 Location: UK.... Age: 57
Member: 173077 Status: Offline Sonork: 100.1594293 Thanks Meter: 2,783 | Quote:
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
