Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > VygisToolbox
Old 12-16-2004, 15:37   #1 (permalink)
Member: 36051
Exclamation UFS-3 + Vygis = vygUF-4 ?!
Our client purchased Vygis Tool Box. install it without any problem... after this, he connected its UFS-3 box.. but ufs software request activation string
We connect this UFS-3 to other PC, windows found the new device, see...
origial ufs drivers not install, approach only "Vygisoft VSD2XX New Drivers". install.
run ufs sofftware, but we see same error - reguest activation string......
How repair it UFS-3?
Thx, Yura
Old 12-16-2004, 16:04   #2 (permalink)
mr_x4you's Avatar
Member: 4989
Had same problem, you programmed Vygis box to Universal box, but this programs also all FTDI pluged in. If you want to program Vygis box to Universal box and viceversa, unplug rest of the boxes.
Old 12-16-2004, 16:27   #3 (permalink)
KhOliO's Avatar
Member: 21732
Sonork: 100.75816
dear try to used one by one
Ex:
u want to used UFS restart ur computer & connect ur Box
===========Vyges============================
u cant used 2 Boxes in one USB u mast change it
or u can used 2 windows in computer
i have in my computer 4 USB connector
& setup ur mother board device USB
this work with me
Old 12-16-2004, 18:17   #4 (permalink)
GSM Brothers's Avatar
Member: 2203
to all use vygis
if u want make vygisbox to unibox remove all another boxes from USB !!!
Yestarday i destroy my twister with this
Old 12-16-2004, 18:42   #5 (permalink)
Member: 36051
..but Vygis TEAM don't write about this problem in its documentation !!!
OK..
HOW REPAIR THIS ERROR IN UFS-3?
Old 12-16-2004, 19:56   #6 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
now you have to contact UFS Team
Thx for the Information
Now i'll use my Vygis on another PC & UFS on other
Old 12-16-2004, 20:00   #7 (permalink)
Gobi's Avatar
Member: 6328
Hello
That Tornado was not becomming Vygisbox only by starting the software.
The customer has used the Vygis Bos <-> USBbox programmer and forgot the Tornadobox also connected.
And in Vygistoolbox section where he has downloaded the programmer software it is written:
" This is all you need to program the Vygistoolbos to USBox and back. It is 100% tested.
The manual is complete, but however if you don't need to do this, and you don't feel that drivers installing /uninstalling is your strength - then don't play with this "
[glow=red]Especially when you use a '' USB Programming software" on a PC, then DISCONNECT ANY USB device you don't need there -- this is GENERAL rule.[/glow]
I sayed here also that it is recommended to disconnect any dongle-box from the PC when you don't use it, because you never know what software can give you an unexpected result with the one or other connected device :
Can LPT dongle be plugged in all the time?
Of course the VygisBox <-> USB box programmer SOFTWARE has ''programmed'' also the eeprom of the Tornado/Twister , and of course it will program most of FTDI based devices/cables that are connected to the PC
- Best and safest way to repair now the Twister/Tornado is to find a way to send it to the Manufacturer for reprogramming.
Also: [glow=red] You can use Tornadobox and Vygis on the same PC (BETTER NOT SIMULTANEOUS BUT) without any problem. Just do NOT CONNECT THEM BOTH at the same time and then also try to Program ...[/glow]
regards,
Gobi
Old 12-16-2004, 20:07   #8 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Gobi
Plz Check you PVT message
I just PM you
Thx
Old 02-19-2005, 22:42   #9 (permalink)
Member: 11460
if anybody need the killed UFS/Tornado repair solution I'l post it here. It is very simple.
Old 02-20-2005, 06:38   #10 (permalink)
hakima's Avatar
Member: 33804
Yes,we need it!
Could you please post your solution (Certainly in the right place ) ?
Thanks in advance!!!
WBR
Old 02-20-2005, 10:00   #11 (permalink)
Member: 36051
http://gsm-shop.com.ua/ufs-3/UFS_Repair_Solution.zip
Old 02-20-2005, 12:45   #12 (permalink)
Mobileman_hu's Avatar
Member: 3097
Thanks, really good solution!
regards: Mobileman_hu
Old 04-02-2005, 19:53   #13 (permalink)
rico1's Avatar
Member: 5397
Hi Friends!
Thanks!!
Good working!
Repaired for n-box.
br
Rico
Old 04-15-2005, 20:26   #14 (permalink)
Member: 27166
Hi guys ive just downloaded this soft and will only next week, Does it Work?
Old 04-15-2005, 22:27   #15 (permalink)
Gobi's Avatar
Member: 6328
YES, soft is tested and working (at least the software i have downloaded from the upper link some weeks before)..
regards,
Gobi
UFS-3 Tornado + HWK by Sarasoft vs UFS-4 Tornado babaki UFS2 + UFS3-Tornadoflasher 17 05-15-2013 14:05
hwk ufs 3 ufs 4 modul hwk helpp raskal ceptel Twisterflasher 0 05-28-2006 17:17
Stupid problem in compability of Vygis RS232 converter and UFS-3 :) Alkapone UFS2 + UFS3-Tornadoflasher 3 05-17-2005 12:21
Moto Tools 4 UFS-3 Cloud UFS2 + UFS3-Tornadoflasher 1 05-11-2005 01:17
UFS Boxes w/3 LED and 4 LED? Spike UFS2 + UFS3-Tornadoflasher 8 05-21-2004 17:34
Page generated in 0.66333 seconds with 11 queries
