Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Junior Member ![]() Join Date: Mar 2006
Member: 252045 Status: Offline Thanks: 1
| Vygis Box Driver Prolific Error! Hello, REN77! Vygis Box Drivers and installation I installed the new driver, but does not work, the Phone turns on when you start the boot! I checked the voltage communication RX, TX and found that the voltage level of the RX pin 3 is very low = 0,2VDC. And I did some tests on other adapters prolific, only works when the voltage level is normal (rx, tx = 3.2 VDC). I could only successfully using the adapter old (fight prolific cable-ic) RX, TX = 3.2VDC. I think a update firmware (vygis prolific) can solve the Problem. |
| | #2 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: May 2001
Member: 4566 Status: Offline Sonork: 100.112355 Thanks: 38
| Hi, As what have we talked on msn, you told that it works on other models but only that cable (KE550) has problems in booting / connecting to phones . So we advised to check this cable for possible solution. Br, Ren |
| | #3 (permalink) |
| These models use two different cables: ************************KE500,ME550 pinout for flashing*************************** keyboard up 18.............1 17 - RX (data to phone) 16 - TX (data from phone) 1,4,14,18 - GND For working with service functions -Read IMEI,Write IMEI, Phone Reset - use KG800 cable. ****************MG160,KG270,KG370,KG320,KG800 pinout****************************** keyboard up 18.............1 7 - RX (data to phone) 6 - TX (data from phone) 1,4,14,18 - GND Please check and post results. BR, Ren |
| | #5 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2006 Location: ATFCycloneMT-boxBestFenixHWK
Member: 276322 Status: Offline Thanks: 156
| PL2303_Prolific_DriverInstaller_v10518 PL-2303 USB to Serial Bridge (H, HX, X) Installshield Driver Setup Program Installer & Build date: 1.0.5.18 (20090723) Windows 98/ME Driver: v2.0.0.19 Windows 2000/XP/Server2003 (32 & 64-bit) WDM Driver: v2.0.9.122 Windows Vista/7/Server2008 (32 & 64-bit) WDF Driver: v3.3.5.122 NOTE: For Windows 7, please use RC build 7100 or RTM Final version. (Installer program will not run on early Windows 7 or Beta versions) Language Support: English (default), Chinese (Traditional), Chinese (Simplified), Japanese For Prolific USB VID_067B&PID_2303 Only Prolific recommends to purchase from following Cable Makers: (1) ATEN UC232A USB to Serial (2) I-O Data USB to RS232C (3) Belkin USB to Serial (4) Elecom USB to RS232C (5) BAFO USB to Serial Adapter http://www.prolific.com.tw/eng/downloads.asp?ID=31 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Vygis Tool Box Driver Installation problem | gsmstars | VygisToolbox | 7 | 01-16-2011 12:07 |
| Vygis Box Driver Prolific Error! | telecelula | VygisToolbox | 0 | 11-19-2009 13:19 |
| Vygis Tool Box Drivers | dil_PAKISTANI | VygisToolbox | 1 | 10-28-2007 16:55 |
| i need vygis box driver | ayaz ali | VygisToolbox | 1 | 05-21-2007 11:30 |
