Vygis Problem on Windows7 ? [ANSWERED] My vygis works on Windows XP but it did not work on Windows 7. http://i256.photobucket.com/albums/h...1968/vygis.jpg what is missing and what should i do? please help |
I also followed this instuction. Quote:
At first check if you using software with "SD" in name-these softwares works with all cards.For second-only one software can be started,if you have few softwares,which use smartcard dongle started-you can have this error Regards, Vygis |
vygis team, you need to make it more easy to install rhis box. realy i have multiple boxes, and all off them i installed without any problem in windows 7 and windows xp, not a difference. but the vygis, great box but too complicated to install it. many and many people have problems with the install. i know many different boxes are around, but has to be possible make just 1 driver set for this box |
Actually all installing is 6 time to start DP_inst.exe.What is hard with this? Regards, Vygis |
1 Attachment(s) Quote:
SmartCard driver can be ignored if you use Windows 7.Looks here,that your smart card has bad contact with it's connector.Solution is to open box and clean contacts Regards, Vygis |
Problem Solved after REFORMAT my Laptop... br, |
1 Attachment(s) see the error i get which i guess is the date of my re3g file activation.... what do i do to use in win7? |
