08-09-2013, 01:07 | #33 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Canada
Member: 219362 Status: Offline Thanks Meter: 31 | Can't connect to server to update I can't update to the new version because I keep getting this error??!!!! "ERROR Reading Server Info Be Sure Internet Connection is Working Fine" My internet is working perfect, so how can I get download?? |
08-13-2013, 00:28 | #37 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: Free Palestine
Member: 330579 Status: Offline Thanks Meter: 67,515 | Quote:
Server work Fine. Download Vygis SC Dongle ID Reader -Supporter 1.7 and you download File in 5 Minutes. See Picture. Regards | |
08-14-2013, 23:09 | #38 (permalink) |
No Life Poster Join Date: Apr 2004 Location: srilanka
Member: 61595 Status: Offline Sonork: 100.1610188 Thanks Meter: 97 | yes I can connect server & download through Vygis SC Dongle ID Reader -Supporter 1.7 . but my problem is I cant to update software through shell(VS2) . when I press "check update" getting this error "ERROR Reading Server Info Be Sure Internet Connection is Working Fine" please any idea to solve this problum |
08-15-2013, 20:05 | #39 (permalink) |
Insane Poster Join Date: Jan 2004 Location: The Nedherlads Age: 55
Member: 49443 Status: Offline Thanks Meter: 5 | Same problem here, I can't check for updates by shell because it's giving an error about a connection problem (check your internet connection). |
08-23-2013, 21:31 | #42 (permalink) |
No Life Poster Join Date: Oct 2005 Location: white house 2
Member: 194936 Status: Offline Sonork: 100.1616223 Thanks Meter: 484 | just bought vygis tool and after install shell(VS2) always same error i got lg reg.date file from resseler using with SC Dongle ID Reader and login on web server successfully read my box id and show activated but if i run shell its showing box sn 00000000 if load same lgreg file error if click go error cant update via shell how fix can help us support ? |
08-26-2013, 21:29 | #45 (permalink) |
Major Poster Join Date: Jul 2008
Member: 814444 Status: Offline Thanks Meter: 4 | Same problem here, I can't check for updates by shell because it's giving an error about a connection problem (check your internet connection). mismo problema aca josedavido no puedo darle en update sale el mismo mensaje con la nueva version del shell alguna solucion que sucede gracias |
