Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > VygisToolbox
Old 07-05-2009, 10:46   #1 (permalink)
Member: 1065550
Sonork: gsmstar
Thanks Meter: 12
Vygis Tool Box Driver Installation problem
Hi,
I bought Vygis Tool box yesterday and sent ID to retailer for actvation.
While I downloaded the drivers from www.support.vygis.net . Installed "Vygis Dongle Drivers Win XP.exe" but still not able to install vygis tool box as it asked for the driver when I connect the box. and I browse it to "C:\Program Files\VygisTools Drivers for Win XP\E-gate Drivers" it still not picking up and driver remains uninstall.
There is another folder named "USB cable drivers". I tried that but it gives the error
"Error, file not found
C:\WINDOWS\system32\VSD2XXUN.INI
Press Finish to exit."
Is that something with the activation as it is still not activated?
If there is any manual with all these details plz send me that.
Thanks,
Old 07-05-2009, 12:18   #2 (permalink)
bestncheap's Avatar
Member: 19785
Thanks Meter: 1,242
Vygis Driver
Read Dongle ID
VYGIS INSTALER 2.0
LG3G_1_26SC
LG_1_99SC
LGI_1_51SC
LGQ_1_37SC
BnC
The Following User Says Thank You to bestncheap For This Useful Post:
Old 07-08-2009, 19:47   #3 (permalink)
Member: 1065550
Sonork: gsmstar
Thanks Meter: 12
unable to connect USB through RS232 by Vygisoft
Thanks for help.
Vygis tool box is connected.
But still I m unable to connect phones through USB - RS232 by Vygisoft.
As option is not available in the comport list.
where it is available but still got problem while connecting.
Thanks,
Old 07-08-2009, 22:14   #4 (permalink)
Member: 4458
Thanks Meter: 25,853
Go to :
http://support.vygis.net and download "USB cable drivers".Use "VPower box drivers for Win XP".Uninstall previous drivers using VSD2XXUn.exe.
Regards,Vygis
One more thing-"USB to RS232 by Vygisoft" you won't find in "Ports"-as it is USB device,you need to look for it in "USB".Anyway mentioned above drivers allow at same time to have USB port and Virtual COM Port-you can select one of them when connecting phone-btw,Virtual Port is even a little faster than "USB to RS232 by Vygisoft".Number of Virtual Port you can find in "Device Manager"-"Ports"-"USB serial port by Vygisoft".At software select this port number and connect phone using this port.
Old 07-09-2009, 14:05   #5 (permalink)
Member: 1065550
Sonork: gsmstar
Thanks Meter: 12
Vygis driver installation problem
Thanks for reply,
I m unable to use "VSD2XXUn.exe". for uninstalltion of previous drivers as messege appears
(Checked with an other PC and got same messege)
I unistalled two drivers manually from Device manager related to Vygis.
1 e-gate USB smart card
2 Vygis tool box (com)
Than I tried drivers for "VPower box drivers for Win XP" but it still unable to pickup driver and following messege appears (see attachment).
Therefore I've to directed it from "Vygis prolific drivers" (given by the retailer).
I m still unble to connect phone through RJ45.
Hope to solve it soon with your help.
Thanks,
Old 07-09-2009, 14:27   #6 (permalink)
Member: 1065550
Sonork: gsmstar
Thanks Meter: 12
continue from last messege
Sorry Attachment is not unloading.
I m writing down the description of messege.
Than I tried drivers for "VPower box drivers for Win XP" but it still unable to pickup driver and following messege appears.
"The file 'ser2pl.sys' on vygis tool box professional instllation is needed.
Type the path where the file is located and press OK"
Thanks,
Old 01-13-2011, 22:53   #7 (permalink)
Mustansar's Avatar
Member: 1081067
Thanks Meter: 107
i m having the same problem and don,t find solution thts y refreshing this post me 2 tried on many computers but C:\WINDOWS\system32\VSD2XXUN.INI not found error
Old 01-16-2011, 13:07   #8 (permalink)
Mustansar's Avatar
Member: 1081067
Thanks Meter: 107
refreshing posts to get any answer
Help to install LG Vygis Tool Box. LEE-MOBILE VygisToolbox 17 05-12-2011 12:43
vygis tool box instal problem DEMA125 VygisToolbox 1 10-17-2009 21:28
Vygis Tool Box Problem. 3GCELL LG 0 01-03-2008 13:15
Vygis Tool Box Drivers dil_PAKISTANI VygisToolbox 1 10-28-2007 16:55
Vygis tool box in germany eddiŽ Wanted Products 0 11-19-2004 09:16
Page generated in 0.26074 seconds with 9 queries
