10-19-2012, 19:35 | #1 (permalink) |
No Life Poster Join Date: Jan 2009
Member: 936896 Status: Offline Thanks Meter: 14 | Vygis Tool Box - Protection card not found I am having trouble installing thy vygis tool box on my new laptop. I have a windows 7 64bit OS and after installing all the drivers inside the id_reader folder I have then executed the program; when I try to read the id, it says protection card not found. I don't understand what could be the issues as I have reinstalled everything and restarted the computer a few times but no luck. any help would be appreciated. Thank you |
10-19-2012, 19:50 | #2 (permalink) |
No Life Poster Join Date: Jan 2009 Location: SPAIN
Member: 938547 Status: Offline Sonork: 100.1591926 Thanks Meter: 481 | you have other smart card installed in your pc? if yes just remove all smart card dirvers and reinstalll all again and will be work you have us dc-unlokcer uninstaler to romve drivers from you laptop |
10-19-2012, 19:57 | #3 (permalink) |
Member: 936896 Status: Offline Thanks Meter: 14 | I'm sorry but I am a bit confused now. What smart cards are you exactly talking about? I have other boxes installed on my laptop, which are working perfectly. All the boxes work fine on my other laptop with windows xp on it. I have two entries in device manager, called "smart card filter" and "smart card readers" each containing 4 sub entries - is this what I have to uninstall? |
10-20-2012, 14:10 | #10 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Europe
Member: 46350 Status: Offline Thanks Meter: 885 | Card reader of Vygis card is old ...remove from it and put on new omnikey reader and try . Or for Vygis try to update with eGate drivers. http://setool.net/support/SETool2/eGate_Driver.zip BR. |
10-20-2012, 14:18 | #11 (permalink) |
No Life Poster Join Date: Feb 2008 Location: KABUPATEN SLEMAN
Member: 714648 Status: Offline Sonork: 1609640 Thanks Meter: 931 | if u want to lauch vygis software u cannt connect other dongle like best,pbtool,ect disconnect all dongle smart card, just connect vygis BR, |
10-20-2012, 14:40 | #12 (permalink) | |
Member: 936896 Status: Offline Thanks Meter: 14 | Quote:
the part of having the drivers updates makes sense and I'll try that in a bit but I don't understand the logic behing changing the card reader. can you explain me why vygis works on the other laptop and not on this one and how this can mean that is the card reader? how much would it cost for the new omny key reader etc? | |
10-20-2012, 19:43 | #13 (permalink) | |
Member: 46350 Status: Offline Thanks Meter: 885 | Quote:
That mean YOU DO NOT install correct drivers. you will try it : Remove one cards from card reader ...for example infinity BB5 Best,or setool .... and put Vygis card on new laptop and run Vygis program. It will work Ok. Note.Different cards reader need different drivers. BR. | |
11-01-2012, 21:12 | #14 (permalink) |
Member: 936896 Status: Offline Thanks Meter: 14 | Tried the new e-gate drivers that were suggested but still not working Anyone knows what to do? I believe the problem is that the new laptop is a windos 7 64bit so does anyone have any experience on how to make these programs work on it? microbox and universal box work perfectly only vygis and nspro aren't working. |
12-21-2012, 21:27 | #15 (permalink) |
Freak Poster Join Date: May 2009 Location: LV426
Member: 1039010 Status: Offline Thanks Meter: 14 | Having the same problem as CPU2007 Protection Card error. Removed all other drivers but still this problem. No problems with microbox, zx3, GbKey, etc etc. Please some support here... |
