GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   n-Box (https://forum.gsmhosting.com/vbb/f284/)
-   -   06-11-2011 Hwk Minor Suite v2.2.0.3 (https://forum.gsmhosting.com/vbb/f284/06-11-2011-hwk-minor-suite-v2-2-0-3-a-398305/)
MicrostarGSM® 05-01-2007 06:22
Release Date: 30/04/2007
The Official release will be ready in our download area :: N-box.org - Home :: & GTS-Box.org
You can download from here, until the support site can be updated:-
Or Download it here Mirror Link
WWW.GTS-BOX.ORG is the site for HWK
Note: For those which have HWK with activation code stick on the hwk module can activate their account at GTS-Box.org
(example: HWK-xxxxxxxxxx)
WARNING !!!
If the HWK is a "TRIAL" or affected by 3rd party tools, this software may not work properly, so use at your own risk.
NOTE: IF YOU HAVE UPGRADED YOUR UFS + HWK SUCESSFUL WITH SUITE V3.0.4 - V3.0.4.2, THERE IS NO NEED TO USE THE CLIENT AGAIN IN THIS VERSION
DCTxBB5 v2.0.5.0
1. New BB5 products: RM-101,RM-188,RM-208,RM-260 (N92-2,6086,E65-1,6086b)
2. New DCT4 products: RH-94,RH-95,RH-97,RH-98,RM-225.RM-229
(1112,1112i,6060v,6061,6030b,6030)
3. New CDMA products: RH-71,RH-77,RH-89,RM-121(2125,2126i,2118,2115i,2355)
4. New CDMA TIKU products:
RM-41,RM59,RM-60,RM61,RM-66,RM-124,RM-125,RM-154,RM-193
(3155,3155i,6155,6235,6236i,3152,6265,6265i,2855,6 165,6275,2865)
5. Support of new Flash update pack 7.4.13.26017, new Flash chips added.
6. Improved F-Bus polling, fixed "Bad Resp UFSx" after fatal error.
7. Improved diagnostics of "Dead APE" and not recognized Flash chips.
8. Fixed "Patch" option bug.
9. UDA(CP) flashing for RM84,RM99 (N70-1,N70-5)
10.Self Tests monitor introduced.
11.Unlock of DCT4+ (BB4.1 ASIC 2 & 11) phones.
12.Certificates backup for BB5 phones introduced ("Rd Cert"and"Bk.308"for SL_Data)
13.BB5 File System Format introduced.
14.Windows Vista(tm) 32bit OS support.
LG_GSM v2.0.5.0
1. KG110, KG320 support fixed.
2. Added new models.
3. Windows Vista(tm) 32bit OS support.
SAMs v2.0.5.0
COMMON
Cut Power option (Restart - power on mobile)
TRIDENT
C140,C216,C240,C250,C260,C266,C268,C308,P310,P318, X166,X636 added.
MSL1 bypass, allows direct unlock.
OM635x
E635 added.
SWIFT
E256,E376,E480,E488,E736,E750,E758 added.
E25x direct unlock.
Full TFS Read, TFS editor.
Option to exclude E2P part from MCU read.
All other modules have been updated to include Windows Vista(tm) 32bit OS support.
GTS-Box.org
MicrostarGSM® 05-10-2007 10:24
HWK Release 10/05/2007 N-box & GTS-box.org
Release Date: 10/05/2007
The Official release will be ready in our download area www.n-box.org & www.gts-box.org
Note: For those which have HWK with activation code stick on the hwk module can activate their account at www.gts-box.org/support.php
WARNING !!!
DCTxBB5 v2.0.5.1
1. Revised "Init SimLocks" function, now allows direct unlock of
1600(RH-64,RH-65)and other models.
www.n-box.org
www.gts-box.org
MicrostarGSM® 05-15-2007 05:47
HWK Release 14/05/2007 N-box & GTS-box.org
Release Date: 14/05/2007
WARNING !!!
DCTxBB5 v2.0.5.2
1. Added BB5 files integrity check, while flashing.
2. Fixed some minor bugs in "Init SimLocks".
3. Added Dejan solution for BB5 ("Locks") 6630,6680,6681,n70,n90 etc... Test others on your OWN risk!
www.n-box.org
www.gts-box.org
MicrostarGSM® 05-23-2007 12:51
HWK Release 23/05/2007 N-box & GTS-box.org
Release Date: 23/05/2007
Download HERE
WARNING !!!
DCTxBB5 v2.0.5.3
1. Modified BB5 codes enter, to allow unlock "Counter Expired".
www.n-box.org
www.gts-box.org
MicrostarGSM® 05-29-2007 13:55
HWK Release 29/05/2007 N-box & GTS-box.org
Release Date: 29/05/2007
WARNING !!!
SAMs V 2.0.5.4
TRIDENT
U600,U608 added.
"Test Mode" enter improved.
Warning about Battery usage, during UI operations.
Corrected Reserved Regions for some models(D83x,D84x,E90x,P31x,X82x)
Added MSL calculation, allows direct unlock and show correct
codes for new models(D83x,E570,E90x,P31x,U60x,X5xx,X63x,X68x,X8x x,.)
IMEI challenger implemented, allows rebuild IMEI for new models.
www.n-box.org
www.gts-box.org
MicrostarGSM® 08-05-2007 17:58
Release Date: 04/08/2007
NEW Product-:) GTS-PRO build in (N-Box,HWK,Griffin,SE-Tools,iPmartUnibox)
WARNING !!!
LG_GSM V 2.0.5.5
1. Fixed support of Spansion MirrorBit Flash chips.
2. Infineon SuperGold2 models added (KE850,KE970, ...)
3. Infineon EgoldVoice models added (KG270,KG271,...)
Warning Infineon models works with battery only !
4. Mediatek models added (C2500, C2600, ...)
SAMs V 2.0.5.5
TRIDENT
E840,F300,F308,U100,U108 added.
Full Reset(*2767*3855#)is mandatory after flashing !
If make Asia<>EU change, use *2767*3855# before flashing.
SWIFT
D900i,D908i,E200,E208,E390,E398,E590,E740,E830,E83 8 added.
www.n-box.org
www.gts-box.org
MicrostarGSM® 08-20-2007 10:18
Release Date: 18/08/2007
WARNING !!!
New Support Area Access - All you need is an Original HWK who's HID is in the master database (can be updated with update client), no username, no password, no waiting for activation. - We hope you will all enjoy this small gift and it will make ours and our customers lifes easier
LG_GSM V 2.0.5.6
1. API Updated to allow support access (No user update)
SAMs V 2.0.5.6
SeDBx V 1.0.5.6
1. Initial Public Release - This module will be updated over the next few weeks to become inline with the rest of the HWK Suite of Modules.
www.n-box.org
www.gts-box.org
MicrostarGSM® 09-13-2007 15:34
Release Date: 13/09/2007
WARNING !!!
LG_GSM V 2.0.5.7
1. Infineon SuperGold2 models unlock (KE850,KE970, ...)
2. KE970GO added (KE970G)
SAMs V 2.0.5.7
TRIDENT
C520,M300,M600,X526 added.
SeDBx V 1.0.5.7
1. DB2020 User Lock code reset to 0000.
2. GDFS Info (Displays User Lock code for non DB2020 models)
www.n-box.org
www.gts-box.org
MicrostarGSM® 10-29-2007 06:16
Release Date: 28/10/2007
The Official release is ready in our download area http://sarunasoftware.com/cardmain.php?dir=HWK_SW/
Please run the upgrade client after you have installed the software, follow the instructions careful.
The Update Client is launched after install, if you cancel without making the update, you can run the Update Client again, by selecting the shortcut on the Start Menu:-
Programs\SarasSoft\UFS\Utilities\Update Client
WARNING !!!
New Users or users who un-installed the old version, should download and install the HWK Support Suite and run the client, before trying to install the full HWK Suite
UFS_DCTxBB5 v2.0.6
1. Dual Line flashing for BB5 introduced (Required UFS firmware V2.8 2007)
2. All avalaible phones supported (including RAPIDO v1.12, v1.13)
3. "Verify" function for BB5 added.
4. Latest Flash Update pack (7.40.35.29728) supported.
5. Support of Muxed Nand.
Do not use external VPP adapter with RX2 enabled cables, since this will put VPP direct to RX2 and its possible to KILL the phone. This has always been the case with 7 pin cables, but from this release 7 pin cables are supported by UFS+HWK.
UFS_LG_GSM v2.0.6
1. KG290 support added.
2. "Support" button, to access support site.
UFS_SAMs v2.0.6
COMMON
Remade user interface.
TRIDENT
E950,F200,J600,J600E,J608,U300,U308,X830N added.
Read Codes for J600,J600E,J608
SWIFT
E598,E768,G600 added.
Unlock Codes on Info for D820,D900,E250,E740,G600.
UFS_SeDBx v2.0.6
1. "Skip Info Checking" allows reflash dead phones.
www.n-box.org
www.gts-box.org
MicrostarGSM® 02-20-2009 07:02
WARNING !!!
HWK_Support_Suite_Setup_v02.08.000
HWK_Setup_Suite_v02.08.000
HWK_Suite_Minor_v02.08.001
HWK_Suite_Minor_v02.08.002
UFS_DCTxBB5 v2.0.8.2
1. Flash Update Pack problems Fixed.
2. New BB5 products:
RM-247,RM-297,RM-333,RM-334,RM-335,RM-348,RM-349,RM-350,RM-356,
RM-398,RM-399,RM-415,RM-427,RM-428,RM-429,RM-437,RM-449,RM-450,
RM-472,RM-493,RM-494
(N96-1,N96-5,N85-1,N85-3,N85-5,N79-1,N79-3,N79-5,5800d-1,7510a,7510a-b,
6600s,5800,5800,3610a,E63-1,E63-2,E63-3,N96-3,E71-5,E66-5)
3. DC4 Flash Chip 0020883C Fixed.
4. New DCT4 products:
RH-111,RH-112,RH-113,RM-438,RM-439,RM-490,RM-500
(1202-2,1202-2b,7100s-2,7100s-2b,1680c-2b,2680s-2b)
5. New DCT4+ UNL versions support:
1200(RH-99 v5.71,v5.80) 1202(RH-112 v2.80) 1208(RH-105 v5.71,v5.80)
1650(RM-305 v5.71,v5.80)
6. User interface localisation.
LG_GSM V 2.0.8.2
1. Infineon GB100,GB105,GB106,KG285,KG288,KP100,KP105,KP106,KP 107
support added. (BIN bundle files open as FLS)
2. Read/Write for Infineon EGOLD Voice added.
3. Auto Backup for Infineon EGOLD Voice added.
4. ADI KF240, KF300
support added. (BIN bundle files open as Code)
Cable as for KP130,KP210,KP260
5. QualComm models introduced.
SAMs V 2.0.8.2
TRIDENT
B270 added (DUNL,IM,FL)
TRIDENT VISION
J610 MSL corrected (DUNL,IM)
E215L,M320L added (CUNL,FL)
(Use [Reset MMI] if phone ask for password)
OM(SYSOL)
M140 added (DUNL,IM,FL,SECT)
SWIFT
J706,L708E added (DUNL,IM,FL,SECT)
SWIFT-AEROFONE
B130,B130S,B130T fixed flashing for HW 0.600
QUALCOMM
ENUMERATION NOT EXIST: 20 bug fixed (up to COM256 supported)
Fixed flashing for OEMSBL V5.32 and higher (M7500,M8800)
UNLOCK and UNFREEZE added for these models:
F480F,M7500(******),M8800(Pixon),U700,U700B,U708,U 800,U800F
(Use [QCDI Info] button to readout keys)
S7220,S7350 added.
Samsung / Qualcomm USB Drivers can be downloaded here:-
http://rapidshare.com/files/20024852...SB_Drivers.zip
www.n-box.org
www.gts-box.org
MicrostarGSM® 04-01-2009 10:45
WARNING !!!
HWK_Suite_Minor_v02.08.003
ATRz v2.0.8.3
1. Fixed clipboard issue on Vista.
UFS_DCTxBB5 v2.0.8.3
1. New BB5 products: RM-495,RM-496 (5130c-2,5130c-2b)
2. New DCT4+ products: RH-121,RH-122 (1661-2b,1661-2)
3. New DCT4+ UNL versions support:
1202-2,1202-2b (RH-111,RH-112 v3.00, v3.10)
1661-2 (RH-122 v3.10)
2610,2610b (RH-86,RH-87 v7.11)
2680s-2,2680s-2b (RM-392,RM-393 v4.56, v4.91)
5000d-2,5000d-2b (RH-362,RH-363 v3.50, v3.54)
7070d-2 (RH-116 v6.20)
4. Simlock status detail info for DCT4 and BB5 models added.
5. Fixed clipboard issue on Vista.
LG_GSM V 2.0.8.3
1. BIN (TotalBin) files support added for ADI models.
2. ADI KP260, KP265 UNLOCK and REBUILD fixed.
3. ADI KP170, KP175 added, cable as for KP130,KP210,KP260
4. LGMDP NV2 format files support for QC NVM Write.
5. User interface localisation.
6. Fixed clipboard issue on Vista.
SAMs V 2.0.8.3
TRIDENT
C275L,C500L,C506,C510L,C516,E570L,U106 added (DUNL,IM,FL)
TRIDENT VISION
B520B,M310L added (CUNL,FL)
OM(SYSOL)
C145,C161,C168B,M140L added (DUNL,IM,FL,SECT)
SWIFT
C3610C,E200B,E230L,E251L,F270L,F275L,F480L,J700L,P 906,U900L
SWIFT-AEROFONE
B130L,E1110(Euro and Asia),E1110C,E1117,E1117L
Increased flashing speed.
QUALCOMM
G400L,M8800B,V820L added.
G400,G400F,G400L,Z150
COMMON
www.n-box.org
www.gts-box.org
MicrostarGSM® 04-07-2009 06:50
WARNING !!!
HWK_Suite_Minor_v02.08.004
UFS_DCTxBB5 v2.0.8.4
1. Added info about flashed Certificates for BB5.
2. Corrected DCT4+ unlock error messages.
3. Find Product settings by VPL files.
4. New BB5 product RM-458 (6208c)
SAMs V 2.0.8.4
TRIDENT
B100M added (DUNL,IM,FL)
TRIDENT VISION
B310R added (CUNL,FL)
SWIFT-AEROFONE
E1070,E1100T,E1125 added (DUNL,IM,FL)
QUALCOMM
Increased Comms speed on RJ45 interface.
L810,L811
N-Box Old Software UFS Suite
Download Here
www.n-box.org
www.gts-box.org
MicrostarGSM® 06-09-2009 09:03
WARNING !!!
HWK_Suite_Minor_v02.08.005
UFS_DCTxBB5 v2.0.8.5
1. New BB5 products: RM-412,RM-413,RM-443,RM-505,RM-506,RM-507,RM-570
(E75-1,E75-2,6303c,N97-1,N97-5,N97-3,6600i-1)
2. Introducing RAPU-YAMA ASIC: RM-368,RM-431,RM-432,RM-470
(6260s-1,5630d-1,5630d-1b,6700c-1) support added.
3. New DCT4+ products: RH-512,RH-513,RH-514,RH-515,RH524,RH-525,RH-543
(2330c-2,2330c-2b,2320c-2,2320c-2b,5030c-2,5030c-2b,2323c-2)
4. New DCT4+ UNL versions support:
RH-99 v5.91, RH-100 v5.80, RH-105 v5.91, RH-106 v5.80, RM-305 v5.91
(1200, 1200b, 1208, 1208b, 1650)
5. Certificates write error in DL mode fixed.
6. Check is ASIC supported by firmware for DCT4 and WD2 products.
7. Read UEM IMEI or ESN for DCT-4/WD2 ASIC 2,5,6,11 when Rd UEM.
8. Added backup of PM 120 block when make Bk.308 (if exists)
9. Added [Skip Erase] option for BB5 products (for Experts Use Only)
10.Added [1331] option, to switch on/off NU48Fxxx Intel Chips Solution.
LG GSM V 2.0.8.5
1. MTK KG195,KP199,KP220 support added.
2. PCS files support added for MTK models.
3. Cable type indicator.
SAMs V 2.0.8.5
TRIDENT
B100K,C140i added (DUNL,IM,FL)
TRIDENT VISION
C3010,C3050,C3060R,C3110,C3110C,S3500 added (CUNL,IM,FL)
M120,M128,E1040,S3030 added (DUNL,IM,FL)
B520 Vodafone support added.
(use B520B-V model, not mix with B520, filenames are similar)
(Use [Reset MMI] if phone ask for password without SIM)
New MSL bypass algo introduced (B220,..,C3050,E1410,S3500...)
allows direct codes reading, unlock and IMEI repair.
MSL Repair introduced, allows to repair or use alien E2P
(Repair of "User Fault on Illegal Trial !!" and restore IMEI)
OM(SYSOL)
C160G added (DUNL,IM,FL,SECT)
SWIFT
B2100,C5212,E250i,F265L,F270,J700i,M158,P250,U800E ,X576
SWIFT-AEROFONE
B100i,B210 added (DUNL,IM,FL,SECT)
C270,E1100,E1120,E1125W,E1125-SEA,E1210M,E1210S,E1310B,
E1310M,E1310S,E1360B,E1360M,E2100,E2210 added (DUNL,IM,FL)
(Do not mix B-C-M-L-S-T-EUR-SEA models! More info on support)
B130S,B130T flashing fixed (blinking or frozen phone)
(Must select target firmware as model, e.g. model is B130 and
want to flash B130S, select B130S as the model.)
SWIFT-3G
P270 added (DUNL,FL,SECT,BT)
QUALCOMM
A777,M7600,M7603,M8800C,M8800L,S5600,S5603,S8300N added.
[Write E2P] (NVM) added.
UNLOCK and UNFREEZE added for these models: A411,A777,S7220,
S7330,S8300,S8300C,Z230 (Use [QCDI Info] button to read keys)
Old models UNLOCK and UNFREEZE: Z300,Z500,..,ZM60,..
(these are not in models list, select any model. Use
[Mobile Info] button to read keys & [Unlock] to direct unlock)
Download Here
www.n-box.org
www.gts-box.org
MicrostarGSM® 08-19-2009 07:08
Release Date 18/08/2009
WARNING !!!
Please make sure you un-install all old versions, first HWK Suite, then HWK Support Suite, you can then install the new software, first HWK Support Suite and then HWK Suite.
You MUST update your HWK using client 2.0.9.0, old client versions will no longer work.
You MUST be running HWK software 2.0.9.0 to access support.
UFS_DCTxBB5 v2.0.9.0
1. New BB5 products: RM-424,RM-465,RM-469,RM-481,RM-482,RM-483,
RM-491,RM-504,RM-518,RM-547,RM-555,RM-561,RM-564,RM-566,RM-602
(6720c-1,5730s-1,E52-1,E52-2,E55-1,E55-2,6710s-1,5530c-2,3720c-2,
6730c-1VF,N97-4,2700c-2,6720c-1b,6730c-1,5800d)
2. New DCT4+ products: RM-519,RM-520 (2720a-2,2720a-2b)
3. New Samsung Flash Chip: 00EC2606 (K8S3215ETF)
4. Corrected VPL parsing for some models (N97)
5. Only NU48F256 left in [1331] option and moved to BB5 Tab.
6. SX4 bypass introduced using temporary NPC certificate erase.
7. [One Boot] option introduced (RAPx based One MCU products)
8. Enabled Files Multiselect, when Writing Certificates.
9. Erase Option for BB5 (for Experts Use Only !)
LG GSM V 2.0.9.0
1. Unlock Codes Display for Infineon EGOLD Voice added
(Boot and See NCK Code for Instructions Press UNLOCK)
SAMs V 2.0.9.0
TRIDENT
T539 added (DUNL,IM,FL)
TRIDENT VISION
Fixed MSL algorithm for some models (C3050,...)
SWIFT
D606,D900E,E260,M2310,P220,S366,S5050,S5200 added(DUNL,IM,FL,SECT)
SWIFT-AEROFONE
B270i,C276,C276L,E1070M,E1070T,E1075,E1075L,E1105T ,E2100B,
E2210B added (DUNL,IM,FL)
QUALCOMM
Manual Port Selection Added
(Use Refresh, After Each Phone Reboot or Reconnect)
(Untic QualComm Mode, Before Flashing)
F480R,i6210,U900W added.
A736,A737,F490,G800,G800L,M7600,S5600,U900W,Z400,Z 540
HWK_Support_Suite_Setup_v02.09.000
HWK_Suite_Setup_v02.09.000
Download Here
Get You own RapidShare Account
www.n-box.org
www.gts-box.org
MicrostarGSM® 03-24-2010 06:40
HWK Release 23-03-2010 HWK Suite Setup v2.0.10.0
WARNING !!!
You MUST update your HWK using client 2.0.10.0, old client versions will no longer work.
You MUST be running HWK software 2.0.10.0 to access support.
UFS_DCTxBB5 v2.0.10.0
RM-381,RM-455,RM-468,RM-492,RM-529,RM-530,RM-570,RM-573,RM578,RM-579,RM-584,RM-599,RM-600,RM-635
(6750-1,6350-1b,5730s-2,6790s-1b,E72-2,E72-1,3208c,6760s-1,2730c-1,2730c-1b,E72-5,6790s-1c,E63-5,2690)
2. New DCT4+ products: RM-590,RM-591 (2220s-2,2220s-2b)
3. More DCT4+ added for unlock (ASIC 3168) see corresponding list.
4. McuSw tag fixed in vpl parser.
5. Fixed time-out bug for some RAPU models.
6. [Det.Log] CheckBox now active, can auto create LOG file.
7. [Info] Shows Camera DCC settings and Status (for both Cameras)
8. [PM Edit] Revised: Read/Write DCC, Simlock Data, Parallel Model.
9. Increased PM read default margins, to have DCC in read PM for DCT4+
10.[Check Ask/Rpl] to Check Ask/Rpl files contents (Asic 2,5,6,7)
11.Fixed [Format] bug for new BB5 Symbian products.
12.ENO File flashing support (E63,E66,..,N97,..)
13.[Locks] for BB5 remade, now calculate codes for SLPA and SL20
14.[Check] Shows PASUBTOC SL related contents.
LG GSM V 2.0.10.0
1. MTK GB160,GB165,GB170,GB175,GB190,GB195,KG198 added.
2. Infineon GB101,GB109,GB110,GB125,GB130,KE858,KP108 added.
3. Infineon New Flash Chip SV7E3204UTA support.
4. ADI KG129,KG248,KG298 added.
5. " Cannot open file " Bug Fixed.
SAMs V 2.0.10.0
TRIDENT
C158,C158B,C188L,C240L,C258,C260B,C260L,C260M,C300 B,E576,E758,
X138,X180,X468P,X478,X568 added (DUNL,IM,FL)
USB flashing introduced for HPE models (U600,.. Approx. 2x faster)
TRIDENT VISION
B3210,B3310,B3313,C3010S,C3050C,C3053,C3060,C3110H ,M620N,
S3030C,S3500C,S3500H,S3500i,S3501C,S5150,S5150C added (CUNL,IM,FL)
MSL3 bypass introduced (B3210,B3310,B3313,C3060,C3060R,...)
USB UI functions introduced, allows to unlock USB only phones.
USB flashing introduced (Approx. 5x faster)
(Cannot use USB flashing of dead phones which have UL erased or damaged.
RJ45 flashing can be used to recover from erased UL situation)
SWIFT
A177,A226,A227,A237,A257,B3410,B5702,B5712C,B5722, B5722C,C3212,
C3510,C3518,C6112,C6112C,D980F,E200E,E208B,E250L,E 848i,F118,
F278,J150B,M2710,M2710C,M2710L,M3510C,S3100,S3110, S3110C,
S3600C,S3600H,S5200C,T219,T329,T729 added(UNL,IM,FL)
Added ENG flashing for DUOS FOTA models (D988,B5712C,..)
Auth. Boot and Firmware Sign. for Secure models (B5722,C3510,C6112,S3100)
B5702,D988,F265L,S5050 (SECT) bug fixed.
CSC Area format added.
SWIFT-AEROFONE
A137,CC01i,E1070C,E1100C,E1101C,E1107,E1113C,E1120 C,E1210,
E1310C,E1310E,E1360,E1360C,E1360S,E2100C,E2210C,E2 210H added (DUNL,IM,FL)
E1080,E1080C,E1080T,E1085,E1085L,E1085T,E1088C,E11 00H,E1150,
E1150C,E1160,E2120,E2120B,E2120C,E2130 added (CUNL,FL)
SWIFT-3G
C5110,C5130,C5130S,C5130U,J800R added (CUNL,FL,SECT,BT)
P270 (CUNL,SECT) bug fixed.
E2P Write is supported only for C5130,C5130S and C5130U.
QUALCOMM
A551,A561,A637,A746,A747,A766,A767,A811,A821,A827, A836,A837,
A867,C5220,C5510H,C5510U,G508,G508E,M7600B,M7600H, S5350,
S5600B,S5600L,S5608U,S5510,S7120U,S7350C,S7350E,S7 350F,
S7350H,S7350i,S7520U,S8300H,T469,T659,T749,T919,T9 29,U808 added.
Fixed flashing of non page size aligned files (rc1,rc2,ffs)
Added flashing support for QSC62xx models.
A551,A637,A767,A827,A837,C5220,F400,S5510,S7350,S7 350C,
S7350F,S7350i,T639,Z170,Z240E,Z360,Z720,ZV40
BROADCOM
QC Legacy BroadCom models introduced:
i6220,S3650,S3650C,S3650M,S3650W,S3653,S3653W,S523 0,S5230G,
S5230H,S5230M,S5230W,S5233A,S5233S,S5233T,S5233W,S 5560,S5560C,
S7070 (CUNL,FL) To read codes use:
[Mobile Info] button using USB Cable (Phone Switched-ON)
and after [QCDI Info] button, using RJ45 Cable (Phone-OFF)
QC Legacy BroadCom models Full Flashing (with BOOT Change)
[BOOT Repair] for QC Legacy BroadCom models added.
Boot Repair and Codes Read is possible only for phones with
NM_20 pin USB/RJ45 connector !
COMMON
Log to file added.
CLONE error message fixed.
HWK_Support_Suite_Setup_v02.0.10.000
HWK_Suite_Setup_v02.0.10.000
Download Here
GTS-Box.org
Page generated in 0.31879 seconds with 6 queries
