09-16-2010, 08:09 | #1 (permalink) |
Freak Poster Join Date: Jun 2006 Location: Las vegas nevada
Member: 291404 Status: Offline Thanks Meter: 58 | e2120 hang done by ufs micro hwk Samsung e2120 hang sa logo toolz: ufs micro hwk e210 cable by dits reprogram: Code: MCU File: E2120XFIK1.cla CRC32: 9A3FF307 TFS File: E2120XFIK1.tfs CRC32: 7196BB17 CFG File: E2120XFIK1.cfg 15563 byte(s) Connect Cable to Switched Off Mobile (with battery) Preloader Ok 08, 921600 Baud Flashloader Ok FLASH Id: SEC, K5N5629ATA [NOR 256Mb] Erase Done, 120 sector(s), Time: 00:43 MCU MSL Patched Ok, Time: 00:03 File CRC: 0x5B9581C7 MCU Write Done, 15692060 byte(s), Time: 05:50 File CRC: 0x7196BB17 TFS Version : TFS4.0_CORONA_01 Directories : 78 Max_Files : 176 Directory : /customer Directory : /customer/nvmgr Directory : /dir_vfp_temp Directory : /drm Directory : /drm/temp Directory : /fm Directory : /fm/Images Directory : /fm/Music Directory : /fm/Music/FM radio clips Directory : /fm/Other files Directory : /fm/Sounds Directory : /fm/Sounds/Voice clips Directory : /fm/temp Directory : /fm/Videos Directory : /images Directory : /images/fm Directory : /images/fm/unified player Directory : /images/idle Directory : /images/idle/menu Directory : /images/keyvolume Directory : /images/LargeClock Directory : /images/menu Directory : /images/message Directory : /images/org Directory : /images/org/set01 Directory : /images/org/set02 Directory : /images/power Directory : /images/streaming Directory : /images/streaming/UCS Directory : /images/UCS Directory : /images/UCS/Default Directory : /images/UCS/Default/Cfg Directory : /images/UCS/Default/Thumb Directory : /images/voice Directory : /images/wap Directory : /images/widget Directory : /images/widget/IdleTime Directory : /java Directory : /java/java_Appl Directory : /java/java_Down Directory : /java/java_Embd Directory : /mms Directory : /mms/camera Directory : /mms/camera/image Directory : /mms/camera/thumb Directory : /mms/draft Directory : /mms/inbox Directory : /mms/myfaves Directory : /mms/myfolder Directory : /mms/myfolder2 Directory : /mms/outbox Directory : /mms/owtest Directory : /mms/sentbox Directory : /mms/temp Directory : /mms/template Directory : /mms/updwload Directory : /multimedia Directory : /multimedia/binary Directory : /multimedia/mp Directory : /multimedia/mp/mpa Directory : /multimedia/playlist Directory : /multimedia/temp Directory : /multimedia/test_mp3 Directory : /netinfoset Directory : /sms Directory : /snsf Directory : /sounds Directory : /sounds/default Directory : /sounds/function Directory : /sounds/keypad Directory : /sounds/keytone Directory : /test Directory : /user Directory : /user/images Directory : /user/sounds Directory : /vobject Directory : /vobject/temp Directory : /vobject/vnote Files_Count: 176/176 File: /customer/nvmgr/NvData.dat, Size: 12939 File: /customer/nvmgr/NvInit.dat, Size: 12939 File: /customer/nvmgr/NvOrig.dat, Size: 12939 File: /customer/nvmgr/nvSize.dbg, Size: 426 File: /customer/nvmgr/VariantVersion.dat, Size: 2 File: /fm/Music/Beyond Samsung.mp3, Size: 412165 File: /images/14_side_down.ifg, Size: 134 File: /images/14_side_up.ifg, Size: 116 File: /images/15_bt_print_frame_off_preview_bg_horizontal.ifg, Size: 1866 File: /images/15_bt_print_frame_off_preview_bg_vertical.ifg, Size: 2194 File: /images/22_print_preview_bg_horizontal.ifg, Size: 1862 File: /images/22_print_preview_bg_vertical.ifg, Size: 2204 File: /images/greeting_01.ifg, Size: 3616 File: /images/insert_sim.ifg, Size: 558 File: /images/idle/idle_011.ifg, Size: 13940 File: /images/idle/idle_021.ifg, Size: 13138 File: /images/idle/idle_031.ifg, Size: 11772 File: /images/idle/idle_041.ifg, Size: 11966 File: /images/idle/idle_051.ifg, Size: 14950 File: /images/idle/idle_wallpaper_white.ifg, Size: 426 File: /images/idle/wpaper.ani, Size: 491820 File: /images/idle/menu/idle_011.ifg, Size: 13940 File: /images/idle/menu/idle_021.ifg, Size: 13138 File: /images/idle/menu/idle_031.ifg, Size: 11772 File: /images/idle/menu/idle_041.ifg, Size: 11966 File: /images/idle/menu/idle_051.ifg, Size: 14950 File: /images/idle/menu/idle_random_white.ifg, Size: 7416 File: /images/LargeClock/icon.ifg, Size: 324 File: /images/LargeClock/idle_large_clock_lock.ifg, Size: 142 File: /images/LargeClock/num.ifg, Size: 3056 File: /images/menu/00_mainmenu_01_focus.ifg, Size: 868 File: /images/menu/00_mainmenu_02_focus.ifg, Size: 844 File: /images/menu/00_mainmenu_03_focus.ifg, Size: 1044 File: /images/menu/00_mainmenu_04_focus.ifg, Size: 1416 File: /images/menu/00_mainmenu_05_focus.ifg, Size: 832 File: /images/menu/00_mainmenu_06_focus.ifg, Size: 1140 File: /images/menu/00_mainmenu_07_focus.ifg, Size: 1112 File: /images/menu/00_mainmenu_08_focus.ifg, Size: 896 File: /images/menu/00_mainmenu_09_focus.ifg, Size: 1716 File: /images/menu/00_mainmenu_bg.ifg, Size: 8576 File: /images/menu/00_mainmenu_focus_bg_01.ifg, Size: 336 File: /images/menu/00_mainmenu_focus_bg_02.ifg, Size: 228 File: /images/message/07_sms_sending.ifg, Size: 420 File: /images/org/11_organizer_arrow01_dim.ifg, Size: 62 File: /images/org/11_organizer_arrow02_dim.ifg, Size: 58 File: /images/org/set01/01_sympopup_bg_128X128.ifg, Size: 908 File: /images/org/set01/01_sympopup_input tab.ifg, Size: 122 File: /images/org/set01/01_sympopup_input_tab.ifg, Size: 122 File: /images/org/set01/set02_organizer_arrow01.ifg, Size: 62 File: /images/org/set01/set02_organizer_arrow02.ifg, Size: 58 File: /images/org/set02/01_sympopup_bg_128X128.ifg, Size: 908 File: /images/org/set02/01_sympopup_input_tab.ifg, Size: 122 File: /images/org/set02/set02_organizer_arrow01.ifg, Size: 62 File: /images/org/set02/set02_organizer_arrow02.ifg, Size: 58 File: /images/power/pwroff01.ifg, Size: 6332 File: /images/power/pwron01.ifg, Size: 6332 File: /images/streaming/UCS/11_videoplayer_buffering.ifg, Size: 582 File: /images/streaming/UCS/11_videoplayer_connecting.ifg, Size: 942 File: /images/streaming/UCS/11_videoplayer_download.ifg, Size: 636 File: /images/streaming/UCS/11_videoplayer_soundonlyEQ.ifg, Size: 1096 File: /images/UCS/Default/Cfg/Default-1.thm, Size: 324 File: /images/UCS/Default/Cfg/Default-2.thm, Size: 324 File: /images/UCS/Default/Cfg/Default-3.thm, Size: 324 File: /images/UCS/Default/Thumb/Default-1.jpg, Size: 2292 File: /images/UCS/Default/Thumb/Default-2.jpg, Size: 2185 File: /images/UCS/Default/Thumb/Default-3.jpg, Size: 2233 File: /images/voice/11_eqani_01_01.ifg, Size: 242 File: /images/voice/11_eqani_01_02.ifg, Size: 378 File: /images/voice/11_eqani_01_03.ifg, Size: 570 File: /images/voice/11_sound_eq01.ifg, Size: 308 File: /images/voice/11_sound_eq02.ifg, Size: 428 File: /images/voice/11_sound_eq03.ifg, Size: 602 File: /images/wap/18_Connecting.ifg, Size: 11764 File: /images/wap/18_Connecting_01.ifg, Size: 492 File: /images/wap/18_Connecting_02.ifg, Size: 484 File: /images/wap/18_Connecting_03.ifg, Size: 564 File: /images/wap/18_Connecting_04.ifg, Size: 492 File: /images/wap/18_Connecting_05.ifg, Size: 484 File: /images/wap/18_openwave_128_129.icn, Size: 16186 File: /images/wap/18_openwave_128_129.ifg, Size: 2590 File: /images/wap/18_openwave_128_97.ifg, Size: 2510 File: /images/wap/18_openwave_about_128_108.icn, Size: 26827 File: /images/wap/18_openwave_about_128_108.ifg, Size: 4380 File: /images/wap/18_openwave_about_128_120.icn, Size: 27746 File: /images/wap/18_openwave_about_128_120.ifg, Size: 4530 File: /images/wap/18_openwave_about_128_76.ifg, Size: 4392 File: /images/wap/18_receiving_01.ifg, Size: 584 File: /images/wap/18_receiving_02.ifg, Size: 584 File: /images/wap/18_receiving_03.ifg, Size: 584 File: /images/wap/18_receiving_04.ifg, Size: 584 File: /images/wap/18_receiving_05.ifg, Size: 584 File: /images/wap/18_secure_off.ifg, Size: 188 File: /images/wap/18_secure_on.ifg, Size: 174 File: /images/wap/18_sending_01.ifg, Size: 432 File: /images/wap/18_sending_02.ifg, Size: 578 File: /images/wap/18_sending_03.ifg, Size: 578 File: /images/wap/18_sending_04.ifg, Size: 578 File: /images/wap/18_sending_05.ifg, Size: 578 File: /images/wap/18_waiting.ifg, Size: 216 File: /images/wap/myriad_128_99.ifg, Size: 1506 File: /images/wap/myriad_about_128_97.ifg, Size: 2842 File: /images/wap/myriad_logo_128x99.ifg, Size: 1506 File: /images/widget/IdleTime/03_idle_clock_am.ifg, Size: 100 File: /images/widget/IdleTime/03_idle_clock_num_00.ifg, Size: 72 File: /images/widget/IdleTime/03_idle_clock_num_01.ifg, Size: 64 File: /images/widget/IdleTime/03_idle_clock_num_02.ifg, Size: 80 File: /images/widget/IdleTime/03_idle_clock_num_03.ifg, Size: 88 File: /images/widget/IdleTime/03_idle_clock_num_04.ifg, Size: 88 File: /images/widget/IdleTime/03_idle_clock_num_05.ifg, Size: 76 File: /images/widget/IdleTime/03_idle_clock_num_06.ifg, Size: 84 File: /images/widget/IdleTime/03_idle_clock_num_07.ifg, Size: 68 File: /images/widget/IdleTime/03_idle_clock_num_08.ifg, Size: 92 File: /images/widget/IdleTime/03_idle_clock_num_09.ifg, Size: 80 File: /images/widget/IdleTime/03_idle_clock_num_colon.ifg, Size: 64 File: /images/widget/IdleTime/03_idle_clock_pm.ifg, Size: 100 File: /java/_main.ks, Size: 7067 File: /java/_policy.txt, Size: 3322 File: /java/alarmlist.txt, Size: 0 File: /java/pushlist.txt, Size: 0 File: /java/java_Appl/suites.utf, Size: 0 File: /java/java_Down/suites.utf, Size: 0 File: /java/java_Embd/#Digital#Chocolate_#Brick#Breaker#Revolution_CA.utf, Size: 114 File: /java/java_Embd/#Digital#Chocolate_#Brick#Breaker#Revolution_jadUrl.utf, Size: 28 File: /java/java_Embd/#Digital#Chocolate_#Brick#Breaker#Revolution_jarUrl.utf, Size: 28 File: /java/java_Embd/#Digital#Chocolate_#Brick#Breaker#Revolution_settings.bin, Size: 98 File: /java/java_Embd/#Digital#Chocolate_#Brick#Breaker#Revolution_suite.jad, Size: 2149 File: /java/java_Embd/#Digital#Chocolate_#Brick#Breaker#Revolution_suite.jar, Size: 231364 File: /java/java_Embd/#Digital#Chocolate_#Brick#Breaker#Revolution_suite.mf, Size: 316 File: /java/java_Embd/#Digital#Chocolate_#Pyramid#Bloxx_CA.utf, Size: 114 File: /java/java_Embd/#Digital#Chocolate_#Pyramid#Bloxx_jadUrl.utf, Size: 18 File: /java/java_Embd/#Digital#Chocolate_#Pyramid#Bloxx_jarUrl.utf, Size: 18 File: /java/java_Embd/#Digital#Chocolate_#Pyramid#Bloxx_settings.bin, Size: 98 File: /java/java_Embd/#Digital#Chocolate_#Pyramid#Bloxx_suite.jad, Size: 2114 File: /java/java_Embd/#Digital#Chocolate_#Pyramid#Bloxx_suite.jar, Size: 217088 File: /java/java_Embd/#Digital#Chocolate_#Pyramid#Bloxx_suite.mf, Size: 300 File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#Crazy%0020#Penguin%0020#Catapult_CA.utf, Size: 114 File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#Crazy%0020#Penguin%0020#Catapult_jadUrl.utf, Size: 28 File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#Crazy%0020#Penguin%0020#Catapult_jarUrl.utf, Size: 28 File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#Crazy%0020#Penguin%0020#Catapult_settings.bin, Size: 98 File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#Crazy%0020#Penguin%0020#Catapult_suite.jad, Size: 2136 File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#Crazy%0020#Penguin%0020#Catapult_suite.jar, Size: 273704 File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#Crazy%0020#Penguin%0020#Catapult_suite.mf, Size: 329 File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#J#C%0020#Does%0020#Texas_CA.utf, Size: 114 File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#J#C%0020#Does%0020#Texas_jadUrl.utf, Size: 19 File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#J#C%0020#Does%0020#Texas_jarUrl.utf, Size: 19 File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#J#C%0020#Does%0020#Texas_settings.bin, Size: 98 File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#J#C%0020#Does%0020#Texas_suite.jad, Size: 2116 File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#J#C%0020#Does%0020#Texas_suite.jar, Size: 168846 File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#J#C%0020#Does%0020#Texas_suite.mf, Size: 319 File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#Minesweeper_CA.utf, Size: 114 File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#Minesweeper_jadUrl.utf, Size: 17 File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#Minesweeper_jarUrl.utf, Size: 17 File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#Minesweeper_settings.bin, Size: 98 File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#Minesweeper_suite.jad, Size: 2130 File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#Minesweeper_suite.jar, Size: 169857 File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#Minesweeper_suite.mf, Size: 326 File: /java/java_Embd/suites.utf, Size: 391 File: /multimedia/binary/701FW_CAMERA_090717.BIN, Size: 12288 File: /multimedia/binary/701FW_USB_090723.BIN, Size: 16384 File: /multimedia/binary/701FW_VCOM_090710.bin, Size: 16384 File: /multimedia/binary/fakecall_dumy.amr, Size: 48000 File: /multimedia/binary/fakecall_dumy2.amr, Size: 48000 File: /multimedia/playlist/1.albm, Size: 32700 File: /multimedia/playlist/2.albm, Size: 32700 File: /multimedia/playlist/3.albm, Size: 32700 File: /multimedia/playlist/4.albm, Size: 32700 File: /multimedia/test_mp3/1_1kHz_0dB.mp3, Size: 81463 File: /multimedia/test_mp3/Left.mp3, Size: 129398 File: /multimedia/test_mp3/Right.mp3, Size: 129398 File: /netinfoset/E2120XF_v16_20091016.nis, Size: 87674 File: /snsf/basic.a, Size: 72 File: /snsf/njcon.a, Size: 18813 File: /test/cfg.txt, Size: 15477 File: /vobject/vnote_dummy_file.df, Size: 409600 File: /vobject/vnote_manage.vm, Size: 7212 File: /vobject/vnote_mng_backup.bak, Size: 7212 Files Closed TFS Unmounted TFS Write Done, 3506698 byte(s), Time: 01:18 note: mild re heat first flash ic before you program... |
The Following 3 Users Say Thank You to agent_lia For This Useful Post: |
I have 5.28 unlocker by cable. | GreEn | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 15 | 07-13-2000 21:57 |
5.28 working solution by eeprom 24x16 | SLO/EU | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 06-22-2000 15:55 |
nokia nse-spv8 by zulea | rothmanns | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-12-2000 07:52 |
have nokia lock 2 solution by cable | oskarcore | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-29-1999 22:49 |
