Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > n-Box
Old 09-16-2010, 08:09   #1 (permalink)
agent_lia's Avatar
Member: 291404
Thanks Meter: 58
e2120 hang done by ufs micro hwk
sharing lang...
Samsung e2120
hang sa logo
toolz:
ufs micro hwk
e210 cable by dits
reprogram:
MCU File: E2120XFIK1.cla CRC32: 9A3FF307
TFS File: E2120XFIK1.tfs CRC32: 7196BB17
CFG File: E2120XFIK1.cfg 15563 byte(s)
Connect Cable to Switched Off Mobile (with battery)
Preloader Ok 08, 921600 Baud
Flashloader Ok
FLASH Id: SEC, K5N5629ATA [NOR 256Mb]
Erase Done, 120 sector(s), Time: 00:43
MCU MSL Patched Ok, Time: 00:03
File CRC: 0x5B9581C7
MCU Write Done, 15692060 byte(s), Time: 05:50
File CRC: 0x7196BB17
TFS Version : TFS4.0_CORONA_01
Directories : 78
Max_Files   : 176
Directory : /customer
Directory : /customer/nvmgr
Directory : /dir_vfp_temp
Directory : /drm
Directory : /drm/temp
Directory : /fm
Directory : /fm/Images
Directory : /fm/Music
Directory : /fm/Music/FM radio clips
Directory : /fm/Other files
Directory : /fm/Sounds
Directory : /fm/Sounds/Voice clips
Directory : /fm/temp
Directory : /fm/Videos
Directory : /images
Directory : /images/fm
Directory : /images/fm/unified player
Directory : /images/idle
Directory : /images/idle/menu
Directory : /images/keyvolume
Directory : /images/LargeClock
Directory : /images/menu
Directory : /images/message
Directory : /images/org
Directory : /images/org/set01
Directory : /images/org/set02
Directory : /images/power
Directory : /images/streaming
Directory : /images/streaming/UCS
Directory : /images/UCS
Directory : /images/UCS/Default
Directory : /images/UCS/Default/Cfg
Directory : /images/UCS/Default/Thumb
Directory : /images/voice
Directory : /images/wap
Directory : /images/widget
Directory : /images/widget/IdleTime
Directory : /java
Directory : /java/java_Appl
Directory : /java/java_Down
Directory : /java/java_Embd
Directory : /mms
Directory : /mms/camera
Directory : /mms/camera/image
Directory : /mms/camera/thumb
Directory : /mms/draft
Directory : /mms/inbox
Directory : /mms/myfaves
Directory : /mms/myfolder
Directory : /mms/myfolder2
Directory : /mms/outbox
Directory : /mms/owtest
Directory : /mms/sentbox
Directory : /mms/temp
Directory : /mms/template
Directory : /mms/updwload
Directory : /multimedia
Directory : /multimedia/binary
Directory : /multimedia/mp
Directory : /multimedia/mp/mpa
Directory : /multimedia/playlist
Directory : /multimedia/temp
Directory : /multimedia/test_mp3
Directory : /netinfoset
Directory : /sms
Directory : /snsf
Directory : /sounds
Directory : /sounds/default
Directory : /sounds/function
Directory : /sounds/keypad
Directory : /sounds/keytone
Directory : /test
Directory : /user
Directory : /user/images
Directory : /user/sounds
Directory : /vobject
Directory : /vobject/temp
Directory : /vobject/vnote
Files_Count: 176/176
File: /customer/nvmgr/NvData.dat, Size: 12939
File: /customer/nvmgr/NvInit.dat, Size: 12939
File: /customer/nvmgr/NvOrig.dat, Size: 12939
File: /customer/nvmgr/nvSize.dbg, Size: 426
File: /customer/nvmgr/VariantVersion.dat, Size: 2
File: /fm/Music/Beyond Samsung.mp3, Size: 412165
File: /images/14_side_down.ifg, Size: 134
File: /images/14_side_up.ifg, Size: 116
File: /images/15_bt_print_frame_off_preview_bg_horizontal.ifg, Size: 1866
File: /images/15_bt_print_frame_off_preview_bg_vertical.ifg, Size: 2194
File: /images/22_print_preview_bg_horizontal.ifg, Size: 1862
File: /images/22_print_preview_bg_vertical.ifg, Size: 2204
File: /images/greeting_01.ifg, Size: 3616
File: /images/insert_sim.ifg, Size: 558
File: /images/idle/idle_011.ifg, Size: 13940
File: /images/idle/idle_021.ifg, Size: 13138
File: /images/idle/idle_031.ifg, Size: 11772
File: /images/idle/idle_041.ifg, Size: 11966
File: /images/idle/idle_051.ifg, Size: 14950
File: /images/idle/idle_wallpaper_white.ifg, Size: 426
File: /images/idle/wpaper.ani, Size: 491820
File: /images/idle/menu/idle_011.ifg, Size: 13940
File: /images/idle/menu/idle_021.ifg, Size: 13138
File: /images/idle/menu/idle_031.ifg, Size: 11772
File: /images/idle/menu/idle_041.ifg, Size: 11966
File: /images/idle/menu/idle_051.ifg, Size: 14950
File: /images/idle/menu/idle_random_white.ifg, Size: 7416
File: /images/LargeClock/icon.ifg, Size: 324
File: /images/LargeClock/idle_large_clock_lock.ifg, Size: 142
File: /images/LargeClock/num.ifg, Size: 3056
File: /images/menu/00_mainmenu_01_focus.ifg, Size: 868
File: /images/menu/00_mainmenu_02_focus.ifg, Size: 844
File: /images/menu/00_mainmenu_03_focus.ifg, Size: 1044
File: /images/menu/00_mainmenu_04_focus.ifg, Size: 1416
File: /images/menu/00_mainmenu_05_focus.ifg, Size: 832
File: /images/menu/00_mainmenu_06_focus.ifg, Size: 1140
File: /images/menu/00_mainmenu_07_focus.ifg, Size: 1112
File: /images/menu/00_mainmenu_08_focus.ifg, Size: 896
File: /images/menu/00_mainmenu_09_focus.ifg, Size: 1716
File: /images/menu/00_mainmenu_bg.ifg, Size: 8576
File: /images/menu/00_mainmenu_focus_bg_01.ifg, Size: 336
File: /images/menu/00_mainmenu_focus_bg_02.ifg, Size: 228
File: /images/message/07_sms_sending.ifg, Size: 420
File: /images/org/11_organizer_arrow01_dim.ifg, Size: 62
File: /images/org/11_organizer_arrow02_dim.ifg, Size: 58
File: /images/org/set01/01_sympopup_bg_128X128.ifg, Size: 908
File: /images/org/set01/01_sympopup_input tab.ifg, Size: 122
File: /images/org/set01/01_sympopup_input_tab.ifg, Size: 122
File: /images/org/set01/set02_organizer_arrow01.ifg, Size: 62
File: /images/org/set01/set02_organizer_arrow02.ifg, Size: 58
File: /images/org/set02/01_sympopup_bg_128X128.ifg, Size: 908
File: /images/org/set02/01_sympopup_input_tab.ifg, Size: 122
File: /images/org/set02/set02_organizer_arrow01.ifg, Size: 62
File: /images/org/set02/set02_organizer_arrow02.ifg, Size: 58
File: /images/power/pwroff01.ifg, Size: 6332
File: /images/power/pwron01.ifg, Size: 6332
File: /images/streaming/UCS/11_videoplayer_buffering.ifg, Size: 582
File: /images/streaming/UCS/11_videoplayer_connecting.ifg, Size: 942
File: /images/streaming/UCS/11_videoplayer_download.ifg, Size: 636
File: /images/streaming/UCS/11_videoplayer_soundonlyEQ.ifg, Size: 1096
File: /images/UCS/Default/Cfg/Default-1.thm, Size: 324
File: /images/UCS/Default/Cfg/Default-2.thm, Size: 324
File: /images/UCS/Default/Cfg/Default-3.thm, Size: 324
File: /images/UCS/Default/Thumb/Default-1.jpg, Size: 2292
File: /images/UCS/Default/Thumb/Default-2.jpg, Size: 2185
File: /images/UCS/Default/Thumb/Default-3.jpg, Size: 2233
File: /images/voice/11_eqani_01_01.ifg, Size: 242
File: /images/voice/11_eqani_01_02.ifg, Size: 378
File: /images/voice/11_eqani_01_03.ifg, Size: 570
File: /images/voice/11_sound_eq01.ifg, Size: 308
File: /images/voice/11_sound_eq02.ifg, Size: 428
File: /images/voice/11_sound_eq03.ifg, Size: 602
File: /images/wap/18_Connecting.ifg, Size: 11764
File: /images/wap/18_Connecting_01.ifg, Size: 492
File: /images/wap/18_Connecting_02.ifg, Size: 484
File: /images/wap/18_Connecting_03.ifg, Size: 564
File: /images/wap/18_Connecting_04.ifg, Size: 492
File: /images/wap/18_Connecting_05.ifg, Size: 484
File: /images/wap/18_openwave_128_129.icn, Size: 16186
File: /images/wap/18_openwave_128_129.ifg, Size: 2590
File: /images/wap/18_openwave_128_97.ifg, Size: 2510
File: /images/wap/18_openwave_about_128_108.icn, Size: 26827
File: /images/wap/18_openwave_about_128_108.ifg, Size: 4380
File: /images/wap/18_openwave_about_128_120.icn, Size: 27746
File: /images/wap/18_openwave_about_128_120.ifg, Size: 4530
File: /images/wap/18_openwave_about_128_76.ifg, Size: 4392
File: /images/wap/18_receiving_01.ifg, Size: 584
File: /images/wap/18_receiving_02.ifg, Size: 584
File: /images/wap/18_receiving_03.ifg, Size: 584
File: /images/wap/18_receiving_04.ifg, Size: 584
File: /images/wap/18_receiving_05.ifg, Size: 584
File: /images/wap/18_secure_off.ifg, Size: 188
File: /images/wap/18_secure_on.ifg, Size: 174
File: /images/wap/18_sending_01.ifg, Size: 432
File: /images/wap/18_sending_02.ifg, Size: 578
File: /images/wap/18_sending_03.ifg, Size: 578
File: /images/wap/18_sending_04.ifg, Size: 578
File: /images/wap/18_sending_05.ifg, Size: 578
File: /images/wap/18_waiting.ifg, Size: 216
File: /images/wap/myriad_128_99.ifg, Size: 1506
File: /images/wap/myriad_about_128_97.ifg, Size: 2842
File: /images/wap/myriad_logo_128x99.ifg, Size: 1506
File: /images/widget/IdleTime/03_idle_clock_am.ifg, Size: 100
File: /images/widget/IdleTime/03_idle_clock_num_00.ifg, Size: 72
File: /images/widget/IdleTime/03_idle_clock_num_01.ifg, Size: 64
File: /images/widget/IdleTime/03_idle_clock_num_02.ifg, Size: 80
File: /images/widget/IdleTime/03_idle_clock_num_03.ifg, Size: 88
File: /images/widget/IdleTime/03_idle_clock_num_04.ifg, Size: 88
File: /images/widget/IdleTime/03_idle_clock_num_05.ifg, Size: 76
File: /images/widget/IdleTime/03_idle_clock_num_06.ifg, Size: 84
File: /images/widget/IdleTime/03_idle_clock_num_07.ifg, Size: 68
File: /images/widget/IdleTime/03_idle_clock_num_08.ifg, Size: 92
File: /images/widget/IdleTime/03_idle_clock_num_09.ifg, Size: 80
File: /images/widget/IdleTime/03_idle_clock_num_colon.ifg, Size: 64
File: /images/widget/IdleTime/03_idle_clock_pm.ifg, Size: 100
File: /java/_main.ks, Size: 7067
File: /java/_policy.txt, Size: 3322
File: /java/alarmlist.txt, Size: 0
File: /java/pushlist.txt, Size: 0
File: /java/java_Appl/suites.utf, Size: 0
File: /java/java_Down/suites.utf, Size: 0
File: /java/java_Embd/#Digital#Chocolate_#Brick#Breaker#Revolution_CA.utf, Size: 114
File: /java/java_Embd/#Digital#Chocolate_#Brick#Breaker#Revolution_jadUrl.utf, Size: 28
File: /java/java_Embd/#Digital#Chocolate_#Brick#Breaker#Revolution_jarUrl.utf, Size: 28
File: /java/java_Embd/#Digital#Chocolate_#Brick#Breaker#Revolution_settings.bin, Size: 98
File: /java/java_Embd/#Digital#Chocolate_#Brick#Breaker#Revolution_suite.jad, Size: 2149
File: /java/java_Embd/#Digital#Chocolate_#Brick#Breaker#Revolution_suite.jar, Size: 231364
File: /java/java_Embd/#Digital#Chocolate_#Brick#Breaker#Revolution_suite.mf, Size: 316
File: /java/java_Embd/#Digital#Chocolate_#Pyramid#Bloxx_CA.utf, Size: 114
File: /java/java_Embd/#Digital#Chocolate_#Pyramid#Bloxx_jadUrl.utf, Size: 18
File: /java/java_Embd/#Digital#Chocolate_#Pyramid#Bloxx_jarUrl.utf, Size: 18
File: /java/java_Embd/#Digital#Chocolate_#Pyramid#Bloxx_settings.bin, Size: 98
File: /java/java_Embd/#Digital#Chocolate_#Pyramid#Bloxx_suite.jad, Size: 2114
File: /java/java_Embd/#Digital#Chocolate_#Pyramid#Bloxx_suite.jar, Size: 217088
File: /java/java_Embd/#Digital#Chocolate_#Pyramid#Bloxx_suite.mf, Size: 300
File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#Crazy%0020#Penguin%0020#Catapult_CA.utf, Size: 114
File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#Crazy%0020#Penguin%0020#Catapult_jadUrl.utf, Size: 28
File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#Crazy%0020#Penguin%0020#Catapult_jarUrl.utf, Size: 28
File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#Crazy%0020#Penguin%0020#Catapult_settings.bin, Size: 98
File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#Crazy%0020#Penguin%0020#Catapult_suite.jad, Size: 2136
File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#Crazy%0020#Penguin%0020#Catapult_suite.jar, Size: 273704
File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#Crazy%0020#Penguin%0020#Catapult_suite.mf, Size: 329
File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#J#C%0020#Does%0020#Texas_CA.utf, Size: 114
File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#J#C%0020#Does%0020#Texas_jadUrl.utf, Size: 19
File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#J#C%0020#Does%0020#Texas_jarUrl.utf, Size: 19
File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#J#C%0020#Does%0020#Texas_settings.bin, Size: 98
File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#J#C%0020#Does%0020#Texas_suite.jad, Size: 2116
File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#J#C%0020#Does%0020#Texas_suite.jar, Size: 168846
File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#J#C%0020#Does%0020#Texas_suite.mf, Size: 319
File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#Minesweeper_CA.utf, Size: 114
File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#Minesweeper_jadUrl.utf, Size: 17
File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#Minesweeper_jarUrl.utf, Size: 17
File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#Minesweeper_settings.bin, Size: 98
File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#Minesweeper_suite.jad, Size: 2130
File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#Minesweeper_suite.jar, Size: 169857
File: /java/java_Embd/#Digital%0020#Chocolate%002c%0020#Inc%002e_#Minesweeper_suite.mf, Size: 326
File: /java/java_Embd/suites.utf, Size: 391
File: /multimedia/binary/701FW_CAMERA_090717.BIN, Size: 12288
File: /multimedia/binary/701FW_USB_090723.BIN, Size: 16384
File: /multimedia/binary/701FW_VCOM_090710.bin, Size: 16384
File: /multimedia/binary/fakecall_dumy.amr, Size: 48000
File: /multimedia/binary/fakecall_dumy2.amr, Size: 48000
File: /multimedia/playlist/1.albm, Size: 32700
File: /multimedia/playlist/2.albm, Size: 32700
File: /multimedia/playlist/3.albm, Size: 32700
File: /multimedia/playlist/4.albm, Size: 32700
File: /multimedia/test_mp3/1_1kHz_0dB.mp3, Size: 81463
File: /multimedia/test_mp3/Left.mp3, Size: 129398
File: /multimedia/test_mp3/Right.mp3, Size: 129398
File: /netinfoset/E2120XF_v16_20091016.nis, Size: 87674
File: /snsf/basic.a, Size: 72
File: /snsf/njcon.a, Size: 18813
File: /test/cfg.txt, Size: 15477
File: /vobject/vnote_dummy_file.df, Size: 409600
File: /vobject/vnote_manage.vm, Size: 7212
File: /vobject/vnote_mng_backup.bak, Size: 7212
Files Closed
TFS Unmounted
TFS Write Done, 3506698 byte(s), Time: 01:18
done...
note: mild re heat first flash ic before you program...
The Following 3 Users Say Thank You to agent_lia For This Useful Post:
Old 09-18-2010, 08:16   #2 (permalink)
ru_dee's Avatar
Member: 911645
Thanks Meter: 19
correct sir, nice solution..i tested it, and it worked
The Following User Says Thank You to ru_dee For This Useful Post:
Old 09-22-2010, 07:13   #3 (permalink)
nacer aouadi's Avatar
Member: 871499
Thanks Meter: 654
Old 09-22-2010, 07:19   #4 (permalink)
MMDEBILI's Avatar
Member: 360073
Thanks Meter: 2,181
after 2 days same prob hahahaah
Old 10-13-2010, 17:18   #5 (permalink)
Member: 889313
Sonork: 14102522
Thanks Meter: 26
Old 10-13-2010, 17:23   #6 (permalink)
adi sukmono's Avatar
Member: 695310
Thanks Meter: 144
off caurse....but how long...4 day,5,day or 1 week...
Old 04-09-2014, 12:48   #7 (permalink)
Member: 1155149
Thanks Meter: 3
good solution
thanks brother
Old 04-09-2014, 13:38   #8 (permalink)
Member: 1155149
Thanks Meter: 3
im flash then ok but after 1day same problem,please long time solution
I have 5.28 unlocker by cable. GreEn Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 15 07-13-2000 21:57
5.28 working solution by eeprom 24x16 SLO/EU Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 06-22-2000 15:55
nokia nse-spv8 by zulea rothmanns Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-12-2000 07:52
have nokia lock 2 solution by cable oskarcore Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 11-29-1999 22:49
Page generated in 0.25164 seconds with 9 queries
