09-11-2005, 19:48 | #1 (permalink) |
Insane Poster Join Date: Jul 2005 Location: Sudan-Khartoum Age: 46
Member: 157834 Status: Offline Thanks Meter: 1 | 6600 Dose not open gallery!!!! (app.closed screenSaver) iam using format user area, upgrate software erase flash and reflashing phone but still problem there... can any budy help me? |
09-11-2005, 22:59 | #3 (permalink) | |
No Life Poster Join Date: Apr 2003
Member: 25806 Status: Offline Sonork: 100.78148 Thanks Meter: 2,915 | Quote:
This solution only for the timebeing after restart ur phone. The phone have same condition no open Gallery . This is Hardware Problem . But i , not found its proper solution yet. Try to Repair Bluetooth. or change then Reflash the phone. br tahir | |
09-12-2005, 11:02 | #4 (permalink) | |
Member: 157834 Status: Offline Thanks Meter: 1 | Quote:
Hi for all i change UPP it was set OK, the gallery was open 100% | |
10-11-2005, 20:10 | #7 (permalink) | |
No Life Poster Join Date: May 2005 Location: In Heaven
Member: 145000 Status: Offline Thanks Meter: 20 | Quote:
thanx | |
10-11-2005, 21:14 | #8 (permalink) |
No Life Poster Join Date: Apr 2004 Location: Skopje , Macedonia Age: 40
Member: 61851 Status: Offline Sonork: 100.1604862 Thanks Meter: 117 | that was the next step you should make it to have galery work.The UPP is also known as main,power processor,it is responsiblle for sound,lcd,power up.At him is stored almost all adresses from the flash files you use when you flash phone.If UPP is bad soldered,damadged your phone will not turn on,no sound,will power up but when you press a litle hard on the keys it will shut down,no lcd,sometimes no network etc. |
10-13-2005, 18:11 | #11 (permalink) |
Freak Poster Join Date: Mar 2004 Location: C:\windows\system32 Age: 45
Member: 57738 Status: Offline Thanks Meter: 18 | its 1000000000000000000000000% blue tooth ic problem just rehot it and fls it if thing goes ok then phone will be ok it not done just change the blue tooth dongel works 10000000000000000000000000% for me in 20 pcs. wbr |
The Following User Says Thank You to shankarbrd For This Useful Post: |
10-16-2005, 05:40 | #13 (permalink) | |
Freak Poster Join Date: Aug 2005 Age: 46
Member: 168352 Status: Offline Thanks Meter: 18 | 6600 sch. Quote:
it is shown in the pic. | |
Mobimb 3.5 Not Open Gallery ? | wasim_mobile200 | Nokia Multimedia | 12 | 03-02-2008 10:51 |
6600 changed BT twice but not work BT and not open gallery!!! | majidjony | WD2 & APE (Symbian Phones) | 7 | 09-10-2006 14:29 |
nokia 6600 gallary not open | GHOST_GSM | WD2 & APE (Symbian Phones) | 6 | 06-19-2006 00:40 |
6600 gallary not open | aravindraghu | Nokia Hardware & Hardware Repair | 8 | 12-05-2005 08:59 |
6600 galley not open | atashius | WD2 & APE (Symbian Phones) | 7 | 08-02-2005 02:04 |
