07-11-2011, 18:15 | #77 (permalink) |
Junior Member Join Date: Jul 2006 Location: Thailand
Member: 313781 Status: Offline Thanks Meter: 1 | Help me please!!! Everytime, I tried to install HWK_Support_Suite_Setup_ v02.02.000, it failed at UFSx driver installer stage as shown on picture Someone please advise how to fix the above error. Thanks in advance |
07-12-2011, 16:49 | #79 (permalink) |
Member: 313781 Status: Offline Thanks Meter: 1 | Thanks you so much for your kindly advise. What I've done are as follows; (1) Install HWK Support Suite on other PC (Windows7), with successfully install then make a copy of USFx USB driver. (2) Attached the original HWK+Tornado box to my PC (WindowsXP), Device manager has detected them and then manually install USFx USB driver that I've got from (1). (3) Install HWK Support Suite on my PC, with succesfully install. (4) Run Client Update, with successfully processes, look like it's work fine. (5) Install HWK Major Suite setup after that get in trouble again with another problem as shown. (6) Uninstall HWK softwere and Restore system, turn my PC back to a point before install HWK softwere. (7) Re-proceed (2) to (6), probably 3-4 times and then get into another problem as shown. Please help me to fix the above problem. Thanks in advance. (Picture removed due to serial number show in the log) Last edited by MicrostarGSM®; 08-21-2011 at 06:48. |
07-12-2011, 17:10 | #80 (permalink) |
No Life Poster Join Date: Jun 2011 Location: earth
Member: 1591394 Status: Offline Thanks Meter: 552 | must wait now usually 24/48h for one log about alien registry, looks like you used some cracks and that steyed in registry look for saras emergency clean up should be all ok |
The Following User Says Thank You to kikas112 For This Useful Post: |
07-14-2011, 09:13 | #81 (permalink) | |
Member: 313781 Status: Offline Thanks Meter: 1 | Quote:
But I've never used any cracked HWK softwere, form day one that I've started to use the original HWK. After saras emergency clean up has completed remove all alien registry keys, It would be OK then I've run the HWK Client Update again with successfully. When I've install HWK Major Suite, the same message was repeat shown again and again. Until it stucked in the lastest problem (contact reseller) as shown. Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Server reported error:No more upgrade logs. Please contact your reseller. Could you please advise the right procedures to install HWK softwere. Thanks in advance. | |
07-17-2011, 17:27 | #85 (permalink) |
Freak Poster Join Date: Jul 2009 Location: ksa
Member: 1081268 Status: Offline Thanks Meter: 73 | Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Connection Closed Gracefully please Help Me................. |
07-17-2011, 20:03 | #86 (permalink) |
Insane Poster Join Date: Aug 2010 Location: India
Member: 1379392 Status: Offline Thanks Meter: 10 | Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Connection Closed Gracefully. Is it serve prblm or box prblm |
07-17-2011, 21:20 | #87 (permalink) | |
Freak Poster Join Date: Oct 2007 Location: Armenia, Armavir
Member: 616204 Status: Offline Thanks Meter: 26 | Quote:
07-21-2011, 16:11 | #89 (permalink) |
Junior Member Join Date: Apr 2011
Member: 1554552 Status: Offline Thanks Meter: 0 | HWK Update client is failing to update pls help Sir, i am getting following message while trying to set up.pls anyone can help me? Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Error: Server returned unrecognized reply |
Hwk Suite Setup v02.07.000.exe.torrent | bebenatower | HWK | 7 | 11-13-2008 06:36 |
UFS Release 18/10/2006 - Discussion | Odia The Ultimate | HWK | 207 | 10-18-2008 14:29 |
ufs suite installer 3.03 needed | dompezvicky | UFS2 + UFS3-Tornadoflasher | 1 | 07-26-2007 16:24 |
ufs hwk 2.0.3 on 18/10/2006 | ashrafcell | Nokia Hardware & Hardware Repair | 1 | 10-29-2006 20:23 |
