Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Unibox
Unibox The Universal Box By Teleway
Old 10-19-2004, 10:54   #1 (permalink)
Multi-COM's Avatar
Member: 43823
Arrow HOT: eXtreme USB Box...soon available for sell !
Extreme USB Box it’s advanced hardware working only on USB port and enable you to transfer data from PC to phone and vice-versa with speed up to 0,5 Mbit./s ! By this Box are 4x faster that normal COM cable but it’s not only advantage of this item. It has build on USB HUB for connection other USB devices to this box as USB HASP and build on full support modules for S2GSM and Vygis software on full speeds up to 460800 kb/s !!! It’s great especially for people that have Universal Box v3.0 or v2.0 or UltraLOGIC since they can use cables from these Boxex to work with this unit. By buying this item you can work with all softwares for over 300 phones and support such standards as S2GSM for new Alcatel or Vygis for Mitsubishi, LG, Alcatel and others at 0,5 Mbit/s speed. We have added special feature for change logic from 3V to 5V since it’s useful for some phones – by this you can change by using only one dip switch logic from 3V as normal MAX3232 or 5V as normal MAX232. As you can see there are many advantages of this small Box so you can use it everywhere since no additional connection cables are needed, power supply etc – you need only one free USB port in your computer.
AVAILABLE ON SELL FROM 10.11.2004 IN GOOD GSM ACCESSORIES SHOP's
General information:
- advanced hardware working on USB port in v1.1 standard allows to transfer data up to 460800 kb/s !
- work without any problems under all operatign systems as Win95/98/Me/2000/Xp
- work with full speed 460800 kb/s at such phones as Alcatel, Mitsubishi, Siemens, LG on all PC’s
- abbility to flash Siemens with cutted tracks using normal SWUP’s due build in AutoIgnition mode
- easy change mode of S2GSm/Vygis/Normal by 3 position switch on back cover of device
- Box connect to PC using 1 USB cable – no need to have LPT, COM, power supply so it’s totally movable between your area
- to one computer you may connect up to 127 eXtreme Box – you can flash up to 127 phones at once !!
- profesionally maked PCB in fabric with ISO9001 with full electrical tests
- possible to change mode to work from 3V to 5V logic – by this device will work as MAX3232 3V standards or MAX232 5V standard. This is needed for most newest phones such as OT756
How it works in practic:
Box works as a virtual port using Windows API – when you connect device for first time to your PC it will first recognise USB HUB and install it automatically. Since drivers for HUB controller are build into Windows shell then it will not request any drivers from you. After this will be finished your system will find device called S2GSM cable or Vygis Box or eXtreme. The type of device that it will recognise first depends on position of switch that are on back cover of hardware. If it’s set to S2GSm first found device will be S2GSM cable, if it’s set to Vygis first device will be Vygis, if to Normal first found device will be eXtreme Box. Driver are installed only once so we suggest to switch to all position at first runing to install all drivers – in future system will not request any drivers and load them automatically when it will only found proper device. After this your equipment are ready to work – in complete you will find small software that enable to change association for COM ports. Now just chosen software and you can start servicing phones.
NOTE: Some phones such as newest OT756 requires 3V logic so you need to change switch to 3V
Technical data:
- transfer up to 460800 kb/s via USB port
- build using chips FTDI FT232BM + USB HUB Alc. MIc. 925
- easy logic voltage change mode from 3V to 5V by just moving a dip switch
- easy change mode of working type device by three position dip switch - S2GSM, VYGIS, NORMAL
- LED’s of PWR (USB power supply), Rx (data from phone), Tx (data to phone), 5V (LED that gives information that 5V are powered on so device works in 5V logic state)
- build on USB HUSB using Alc. MIC. AU925 chipset
- max. Power take by Box (USB standards) - 100 mA
- working on all cables from Universal Box v2.0, v3.0 or UltraLOGIC
- aluminium casing
Advantages over other products:
- don’t need to buy other USB devices with full complete set of cables if you already got Universal Box v2.0, v3.0 or UltraLOGIC – all cables from these Box will fits to this unit
- full mobility – don’t need external power supply
- full hardware support for S2GSM and Vugis hardware like also normal softwares
- free support
Package contains:
- Extreme USB BOx
- drivers on CD (Extreme/S2GSM/Vygis)
- instruction in EN/PL on CD
- software for association of COM port on CD
- warranty card
More photos of this device and specificaiton in PDF - click here
INFORMATION:
* DOS based softwares will not work under this device since it’s usign Windows API virtuall port for emulate COM – due this some programs may also have problem using this device and there are need to use Universal Box v2.0, v3.0 or UltralOGIC
Old 10-28-2004, 19:27   #2 (permalink)
garutech's Avatar
Member: 65222
Sonork: 100.65030
what phone model does this support
Old 11-02-2004, 20:34   #3 (permalink)
Multi-COM's Avatar
Member: 43823
garutech: simply writes all No cables are attached but it's support all phones on market working that uses communication by TTL so workign udner Max232/MAX3232. Since there can be buyed small converter from converting USPIU, UDK so in totall CHINA standard cables it's great for all users of old COM Universal Boxex
Old 11-21-2004, 10:46   #4 (permalink)
TWISTER_FLasher's Avatar
Member: 64382
Sonork: 100.1577130
what types of phones work with it ?
Old 11-22-2004, 16:20   #5 (permalink)
Multi-COM's Avatar
Member: 43823
@Twister_Flasher: All that will work on standard COM cables but of course at higher speed rate so Alcatel (support S2GSm adn Vygis modules), Bosch, Eriscsson, SonyEricsoon(flashing K700 with 16 Mb flash takes only 6-7 minutes instead of 30 minutes by normal COM cables), Mitubishi, Toshiba, motorola acer, Siemens, Sony, Nokia (F/Mbus only), LG, Maxon, Vitel, NEC etc.....
Old 11-24-2004, 04:11   #6 (permalink)
andrew14's Avatar
Member: 78367
its support many phones, 4 hw long? site nothin 2 be found 4 support?
Old 11-24-2004, 19:34   #7 (permalink)
Multi-COM's Avatar
Member: 43823
ansrew14: eXtreme it's kidn of universal Box - as far as author of sofware will create aaplciation that works on COM ports so fars eXtreme will work...additional are s2GSM and Vygis softwares support but rest are acting liek normal universal com Box but with faster due USB transsmission
Old 11-29-2004, 15:23   #8 (permalink)
Multi-COM's Avatar
Member: 43823
@all: New resseelr updated:
Bulgaria: Westerna.org
Netherland: Hurricane (Mr. J-L Otten)
Spain : Murphy Movitel Spain
Resselers are welcoem - please wrte at info@extremeusbox.com
Also we have addedd some comparision -please check below:
K700i MCU+LP (20 Mb) - by eXtreme USB BOx
K700i MCU+LP (20 Mb) - by normal T28 cable
Also some screenshot of softwares workgin with it:
Dejan BB5 SL2 Logs Sever accounts available for sell gsm-traders Main Sales Section 0 12-25-2008 03:12
Crazzy NEC Unlocker, eXtreme USB Box, Smart-CLIP, Griffin, Tiwsters Multi-COM Main Sales Section 0 12-10-2004 13:55
-= ONLY 59 EUR for eXtreme USB BOX - STOCK AVAILABLE =- Multi-COM Main Sales Section 0 11-13-2004 21:54
Page generated in 0.43390 seconds with 11 queries
