04-20-2013, 20:24 | #1 (permalink) |
Junior Member Join Date: Apr 2013
Member: 1913849 Status: Offline Thanks Meter: 0 | 3G/4G problems T999 after IMEI repair Repair was successful but the phone works only in Edge "E" I'm using the latest software 6.6.1, I tried re doing again and still the same. Please help. |
04-22-2013, 02:05 | #5 (permalink) |
No Life Poster Join Date: Jun 2008
Member: 803622 Status: Offline Thanks Meter: 41 | I have same problem with N7105, after repair ime phone never work on 3g/4g always on edge network. after so many try still same problem. at the end i have to use Z3x box to repair the ime again and now the phone work perfectly. I think NSPro stuff up the 3g/4g network with ime repair service. Good luck guys |
04-23-2013, 00:45 | #6 (permalink) |
No Life Poster Join Date: Jul 2009 Location: Los Angeles, CA
Member: 1081371 Status: Offline Thanks Meter: 720 | Here are custom NV Items for the T999 Use CDMA Workshop or any NV Item writter to load them up... NV Item.txt Thank me later .... |
04-23-2013, 19:53 | #7 (permalink) |
No Life Poster Join Date: Oct 2007 Location: South Africa/Pakistan
Member: 619308 Status: Offline Sonork: 100.1591829 Thanks Meter: 243 | i use to have this problem with i9305 and n7105 but now its work perfect with 6.6.0.mostly nspro update have bugs. i dont know about 6.6.1. but 6.6.0 work perfect. |
06-27-2013, 10:22 | #9 (permalink) |
Junior Member Join Date: Jun 2013
Member: 1967480 Status: Offline Sonork: xarchenemy Thanks Meter: 0 | Hİ PLS HELP ME HAVE ONE İ9305 octopus İMEİ REPAİR mod emergency SPT NOT HAVE PROBLEM WORKING NETWORK AND NOT WORKING 4G ONLY WORK 3G NOT GOOD İNTERNET... EGDE E CAMİNG.. İ WANT CAMİN H HELP ME PLS SKYPE: DWT-ARCHENEMY |
02-26-2014, 02:15 | #10 (permalink) | |
Junior Member Join Date: Oct 2006
Member: 374177 Status: Offline Thanks Meter: 22 | Quote:
thanx alot bro. you made my day. i have searched many forums with no luck till i found your topic which helped me immediatly thanxxxxxxxxxxxxxxxxxxxxxx | |
09-20-2014, 12:48 | #11 (permalink) | |
Freak Poster Join Date: Jan 2009 Location: Lithuania
Member: 957052 Status: Offline Thanks Meter: 52 | Quote:
12-11-2014, 22:19 | #14 (permalink) |
Junior Member Join Date: Sep 2014
Member: 2265057 Status: Offline Thanks Meter: 2 | i have the same problem. successfully repaired imei on t999 4.3 but now only 2g internet. i see some info about NV Items above which seem to fix the problem. Unfortunately i do not know what that means. Could someone please give more detailed instructions on how to do this. i am a beginner with the software side of phones. thanks |
The Following User Says Thank You to ronsten56 For This Useful Post: |
12-12-2014, 02:13 | #15 (permalink) | |
Member: 1081371 Status: Offline Thanks Meter: 720 | Quote:
2. Connect phone [old software] *#7284# [New Software] *#0808# select "DM+MODEM+ADB" let the drivers install, If you cant see your phone PORT unplug and plug in .. 3. Download NV item file ... 4. Load NV item file ... Reboot phone ...DONE... | |
The Following 2 Users Say Thank You to jusmejose For This Useful Post: |
