Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > NSPRO
Old 01-24-2013, 19:23   #16 (permalink)
Member: 703800
Thanks Meter: 13
Same problem- NO TAT MODE- even when using all the methods prescribed above.
Old 01-27-2013, 20:36   #17 (permalink)
kenjatech's Avatar
Member: 1299439
Thanks Meter: 73
It doesn't list the master code, making it impossible to lock if the phone has hone freeze.
Old 01-28-2013, 09:26   #18 (permalink)
Member: 421485
a157 unlock with z3x
for unlocking a157 with z3x select b7722 and press unlock
Old 01-28-2013, 17:31   #19 (permalink)
kenjatech's Avatar
Member: 1299439
Thanks Meter: 73
You are in the wrong section of the forum. The product we are referring to is NSPRO.
Old 02-01-2013, 10:47   #20 (permalink)
Member: 71464
Thanks Meter: 19
its just a matter of timing
put battery into phone but not connected to contacts
insert s7070 cable and click get info then insert battery all the way in
Old 02-22-2013, 21:40   #21 (permalink)
Member: 277790
Thanks Meter: 42
NsPro 6.5.8 supports A157....
Old 02-22-2013, 22:12   #22 (permalink)
Sheriff Bah's Avatar
Member: 1251015
Sonork: 1620303
Thanks Meter: 10
samsung A187 AT&T is supported on z3x or nspro {in case supported which model sould i silet}????????
Old 02-27-2013, 19:33   #23 (permalink)
Member: 703800
Thanks Meter: 13
Stiil no luck with phone going into TAT mode. Please help
Old 04-18-2013, 07:50   #24 (permalink)
Member: 1638066
Thanks Meter: 163
select B7722_m click read codes insert com cable without battery then insert battery and keep pressing 4-5 second power button then phone goes to tat mode
Old 04-20-2013, 00:38   #25 (permalink)
Member: 680755
Thanks Meter: 8
This is the 100% solution. Unlocked 20 handsets of A157 in the last 3 weeks with this method.
1. Select A157
2. Cable in.
3. Battery in holder NOT touching contacts.
4. Press Read Info.
5. As soo as you see Entering Tat mode insert battery fully into phone.
Absolutely works 100%
Old 12-19-2015, 05:38   #26 (permalink)
Member: 1755479
SGH-A157 Network unlock procedure:
Step 1: Remove sim card from phone and turn the phone on.
Step 2: Dial *2767*3855# This will initiate a Full reset for Samsung A157
Step 3: Once the phone restarts, dial #*7337# This will remove sim lock and reset phone
Step 4: Now insert your sim card. and restart the phone.
Old 12-21-2015, 01:45   #27 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 749
Very good now your phone has imei cleared to 0000000000000 and no more connect to network.
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-23-2015 14:21
FAQ about unlock n0kia man0n Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 18:06
Page generated in 0.31841 seconds with 8 queries
