08-06-2007, 11:22 | #4 (permalink) |
No Life Poster Join Date: Jul 2006
Member: 315550 Status: Offline Thanks Meter: 110 | Use Zxxxxx Cable! and try this! UNLOCK SGH-A707 Type *#0002*28346# on the phone and press "Back" several times till you see main test menu. Then go to Common settings on test menu, USB Configand select Sasmung USBUse the original sim card ( Cingular sim card ) change the connection to PC Suite mode, unlock again with sim inside for A707 to detect as modem please follow the instruction type *#0002*28346# press 2 times back go to common(press 9 ) >>>> USB (press 6)>>>> presss 1 good luck! i hope it is not a707c!!! |
08-12-2007, 08:35 | #5 (permalink) |
Temporary banned !! Join Date: Mar 2006 Location: Dhaka, Bangladesh Age: 37
Member: 243500 Status: Offline Sonork: 100.1590322 Thanks Meter: 584 | i have tryed but the cdma modem can't parform power........................ i think i need Zxxx power adapter. am i right??? |
02-08-2008, 01:10 | #11 (permalink) |
No Life Poster Join Date: Jul 2006 Location: DAVIE FLORIDA
Member: 309299 Status: Offline Thanks Meter: 259 | you need to use Z adapter to fix that usb problem then is easy to work with phone read post in oficial ns pro forum we talk about is 10000 times on that forum |
02-08-2008, 21:56 | #12 (permalink) |
Junior Member Join Date: Aug 2007
Member: 576297 Status: Offline Thanks Meter: 0 | I am in the same situation, I don't understand of where to discharge the special flash to be able to unblock the one A 707c, of At&t which is the name of the file, where I find it, as I load it, etc. Needs information but he/she specifies. Thank you to help |
02-20-2008, 23:50 | #14 (permalink) |
Member: 309299 Status: Offline Thanks Meter: 259 | come on this question have been made like 100000 times and this times was answered, my friend just flash phone with file in support that got the name a707 unfrezee use modem code to flash phone and all will be ok |
03-21-2008, 13:50 | #15 (permalink) | |
Freak Poster Join Date: Sep 2006 Location: "" I N D I A ""
Member: 349089 Status: Offline Thanks Meter: 112 | Quote:
working sure shot file located in 3g patch folder at support A TO Z | |
A707 instructions | vermsky | UST Pro II | 98 | 03-21-2011 15:39 |
A707 Cingular Rebooting After flashed A707 Unfreezed File | gsmtime | UST Pro II | 2 | 09-08-2008 21:30 |
cingular A707 | ferdie138 | UST Pro II | 9 | 01-24-2007 20:13 |
A707 How To Unlock In Ust Pro11 | CHAPRAN | UST Pro II | 1 | 12-24-2006 07:45 |
Does NSdonglle Support Cingular Samsung A707 3G yet ?? | Cell_site | NSPRO | 4 | 12-15-2006 12:05 |
