03-09-2009, 07:25 | #1 (permalink) |
Freak Poster Join Date: Jan 2007 Location: India.Pin.629001
Member: 433257 Status: Offline Thanks Meter: 43 | b520 dead after flash again i repeat it could be flashed with 5.01 only.why is it happening ? i tried two flash file from support B520BUHI1_binary.s3 and B520XXHG5.s3 0pls help me |
03-09-2009, 08:20 | #2 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Romania
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | Uninstall nspro from ypur PC. Delete NsPro folder from Program Files Download and install latest nspro version from www.nsteam.org/download.html Then flash your phone. |
03-09-2009, 10:22 | #3 (permalink) |
Member: 433257 Status: Offline Thanks Meter: 43 | sorry no luck i cannot flash with 5.08 version i tried all ur ideas the exe shows an error and just goes off plsss help i repeat it could be flashed with 5.01 only |
03-30-2009, 17:57 | #6 (permalink) | |
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | Quote:
Select NO RETRIES on flashing menu. Connect the phone without battery to NsPro when flashing in DEFAULT mode. Disconnect any other box from PC when using NsPro. Make sure that you are using latest nspro version from www.nsteam.org/download.html | |
03-30-2009, 18:07 | #7 (permalink) |
No Life Poster Join Date: Aug 2004 Location: Sofia Age: 43
Member: 77941 Status: Offline Thanks Meter: 120 | @Elco please rewrite box drivers - evry time conflict with other boxes, errors on connect etc., you made great soft and box and it's not normal to have so many driver conficts with your hardware BR |
04-24-2009, 15:44 | #9 (permalink) |
Registered User Join Date: Dec 2004 Location: largest democratic country
Member: 100376 Status: Offline Sonork: 100.1591842 Thanks Meter: 150 | thanks elco sir i did exactly u said here & able to revive the above hs after first flashing in default it very easily taking the flashing smoothly & now set is working perfectly |
b520 dead after flash | rakesh15 | NSPRO | 0 | 08-24-2009 14:25 |
b520 dead after flash | rakesh15 | UST Pro II | 0 | 08-24-2009 14:24 |
samsung B520 dead after flash | himanshu taldar | HWK | 8 | 07-30-2009 09:18 |
"***B520 dead after flash***" | blackid | UST Pro II | 0 | 04-22-2009 05:17 |
b520 dead after flash | soki | UST Pro II | 2 | 12-17-2008 12:57 |
