Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > NSPRO
Old 02-14-2006, 12:46   #1 (permalink)
cobra02a's Avatar
Member: 175671
Thanks Meter: 40
BAD Dongle BAD Elco BAD Support
HELLO
FIRST THING , THIS FORUM IS FOR HELPING USE FOR OUR PROBLEMS FROM ELCO , BUT WHY ELCO DON'T HELP ME ???????????????
I HAVE POST MY PROBLEM MANY TIMES BUT NO RESPONCE FROM ELCO
problem on flashing d500
Post here any problem with Nsdongle v3.11.6
ALL THE OTHER BOXES AND THE FREE SOFTWARE WORK VERY GOOD WITH D500 , WHY NSDONGLE ALWAYS HAVE A PROBLEM WITH THIS PHONE
Old 02-14-2006, 13:00   #2 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
Thanks Meter: 25,392
Originally Posted by cobra02a
HELLO
You can find older posts about this problem. Also the solution. You can try with different firmware. Or select Repair mode flashing.
Old 02-14-2006, 13:22   #3 (permalink)
FU_Too's Avatar
Member: 55766
Thanks Meter: 333
GOOD Support, GOOD Elco, GOOD Dongle.
Thread Starter has BAD eyesight, BAD search technique, BAD attitude.
Rather than look to solve problem prefers to blame others. IF All you say was true then Elco's software and dongle wouldnt be the best in the market as 100s of users will tell you.
Old 02-14-2006, 13:26   #4 (permalink)
Member: 39069
Sonork: 100.1606677
Thanks Meter: 190
Sometime new update have some bug, you just report to Elco he will fix it. I have some problem also but after new update problem solve. Now never problem with nsdongle for me.I never use one soft, one dongle, so I can test and compare wich one is the best.
Now if possible I need Elco add function read & write EEPROM. Thanks
Old 02-14-2006, 15:59   #5 (permalink)
cobra02a's Avatar
Member: 175671
Thanks Meter: 40
Elco
it's not a software problem ( firmware ) , i have do repair then flash and the same , the same firmware used with the other boxes on the same phone and it's ok .
IT IS YOUR SOFTWARE PROBLEM OF NSDONGLE , please repair it
Old 02-14-2006, 16:04   #6 (permalink)
EMINEMGSM's Avatar
Member: 57652
Thanks Meter: 1,849
Elco
Man are u programmer or what?
Nsdongle software work perfectly for me no bugs on flashing
and i know this man he work very hard on samsung
Old 02-14-2006, 16:48   #7 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
1.Use flash with Repair mode checked.
2.After flashing, power on the phone with sim inside.
3.Power off the phone and rebuild IMEI.Rebuild IMEI.
Is much better than read/write EEprom.
Old 02-15-2006, 16:58   #8 (permalink)
Bolin's Avatar
Member: 6786
HELLO
Hold a second, I have no idea what size the user base of NSdongle and BOX are, however, you do not have to be a genius to be able to read the posts from many people who are more than happy with the dongle, the box and the support.Me included
If 99% if the people using nsdongle do npt have any major problems then that would suggest that any problems are not with nsdongle "perse".
Perhaps you should first consider how many developers there are for the other software and OS and hardware that you are trying to us NSdongle on and with, and maybe complain to them. One thing is for sure, you dont get the level of support from Mickysoft that we get from Elco.
I for one, have been more than happy and continue to be more than happy with nsdongle and with the support kindly offered by Elco and Crew (keep it up guys) sure i have had 1 or 2 minor problems, most of which have been ironed out in the next release, but that is the nature of complicated software.
So Cobra02a i suggest rather than ranting, you actually look around in the forum for the answer to the problems you may have, rather than having a go at Elco and crew, that you politely ask for there help, and be grateful that you have the support.
bad response MR. elco ali_imran NSPRO 12 07-31-2009 14:25
Bad Dongle Bad Resseler in Algeria mus67 Typhoon Dongle 3 02-17-2008 10:42
SW for DCT-4 BAD DONGLE.... Ivos Nokia Digital Core Technology 4 ( DCT-4 ) 10 07-29-2002 21:11
Page generated in 0.29748 seconds with 8 queries
