06-24-2007, 12:08 | #2 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Romania
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | The phone is D900? or D900i? Do you connect the phone without battery according to Assistant instructions? The NsPro drivers are correctly installed? If the NsPro drivers are not correctly installed, autoignition feature will not work and you wont be able to use NsPro properly. For more information, check official NsPro support forum: www.nsdongle.com/forum |
06-24-2007, 16:07 | #4 (permalink) | |
No Life Poster Join Date: Feb 2004 Age: 44
Member: 52956 Status: Offline Thanks Meter: 49 | Quote:
autoignition system is worked and phone without baterry goes to tat mode but cant change imei... my phone is D900 after that use ustpro at first time imei not changed but at second time imei is changed but again I test it with nspro but """opration failed" I tested it several times but not sucssess.... any sloution br GSMLOVER | |
06-24-2007, 17:17 | #5 (permalink) | |
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | Quote:
If the eeprom was damaged on that phone, flash the phone with eeprom from NsPro support area then try again. I just tested D900 IMEI change with last NsPro version and here are the results: The phone before writing IMEI: IMEI was changed on D900 phone in less than 5 seconds with last NsPro version: And finaly, the result: So... you must be doing something wrong... because NsPro is working PERFECTLY with D900 | |
07-28-2007, 22:03 | #8 (permalink) |
No Life Poster Join Date: Jun 2004 Location: MACEDONIA
Member: 67805 Status: Offline Thanks Meter: 364 | elco for me also not working. After I write eeprom in d900 and I cant change imei to original and remain 000000.... I have good instalation of nspro/drivers (blue led goes ON) I can unlock every phone d500,d600,d900,f300,Zxxx...but imei changing not work. Maybe on some firmwares dont work, because I belive you that work for you and many others but in some cases not work. I try on 3 pc. wbr. |
07-29-2007, 02:33 | #9 (permalink) | |
No Life Poster Join Date: Jun 2004 Age: 44
Member: 69305 Status: Offline Thanks Meter: 128 | Quote:
L7 imei change failed set dead | mughalG | Ultima Box Light | 7 | 06-19-2007 12:48 |
V3i(r3443H3-G) IMEI changing failed!!!!!!!!! | GSMLover2010 | Ultima Box Light | 4 | 06-16-2007 09:35 |
LG KG800 IMEI change fail | rajSE | VygisToolbox | 10 | 03-04-2007 20:08 |
D900 IMEI Change? | carfuller | Samsung Flashers, Software, Firmware. | 0 | 12-08-2006 09:28 |
D900 imei change problem | safeshop | NSPRO | 2 | 11-02-2006 15:39 |
