01-17-2009, 19:40 | #1 (permalink) |
Freak Poster Join Date: Sep 2005
Member: 177088 Status: Offline Thanks Meter: 15 | D900i EEPROM FILE - Not a NsPro Swift EEPROM file! Downloaded the d900i eeprom.nsf file from support but get this error when trying to write: Not a NsPro Swift EEPROM file! Does anyone have the correct eeprom file for the d900i please? Also there are no repair flash files for the d900i in support. Thanks |
01-17-2009, 21:02 | #2 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Romania
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | 1. download eeprom file from nspro support area. Use internet explorer to access the nspro support area. Unzip the file. Open NsPro, select D900i and click FLASHING Select flashing mode EEPROM Select the unziped file on NsPro File section Click WRITE In few seconds the eeprom will be writen on the phone. |
01-18-2009, 01:36 | #3 (permalink) | |
Member: 177088 Status: Offline Thanks Meter: 15 | Quote:
Hi..as mentioned in the first post the eeprom file was downloaded from the nspro support area. The zip was downloaded and then unzipped. But it does not work. This is the error: Powering on mobile... Target detected! Speed successfully changed Flash Type Detected [ SAMSUNG : KAP29SN00M ] Not a NsPro Swift full flash file! Does anyone else have a d900i eeprom that could be used please? | |
01-18-2009, 01:58 | #4 (permalink) |
Freak Poster Join Date: Nov 2006 Location: PL
Member: 384541 Status: Offline Thanks Meter: 101 | Did you select like Elco said: Select flashing mode EEPROM From that what you wrote, you checked fullflash. Anyway this eeprom file for d900i was many time used with success. BR |
01-18-2009, 02:20 | #5 (permalink) | |
Powering on mobile... Target detected! Speed successfully changed Flash Type Detected [ SAMSUNG : KAP29SN00M ] Not a NsPro Swift EEPROM file! | |
all eeprom NSPRO in one files | MMDEBILI | NSPRO | 6 | 09-05-2010 18:05 |
Alcatel S120 Flash File not found in support [SOLVED] | surin | PolarBox 3 | 16 | 03-30-2010 10:57 |
X670 eeprom file not supported | Codes | NSPRO | 3 | 11-14-2008 15:56 |
Cannot get a signal on D900i after flashing / unlocking using NSpro | samaraki | NSPRO | 9 | 10-25-2008 05:40 |
Swift Flex Files Where | yousaf22us | Multi-Box | 2 | 08-09-2006 09:48 |
