11-03-2009, 18:57 | #1 (permalink) |
No Life Poster Join Date: Jan 2003 Location: Hong Kong. Age: 47
Member: 19979 Status: Offline Thanks Meter: 116 | Dead M620 with NSPRO Flashing. Log was all OK and ended with usual ALL IS WELL ! message i flashed phone with a full backup from another phone as well, still no power and now phone doesnt connect in USB mode, (*+USB cable), so cant be flashed with Optiflash as well. phone can still be flashed in "Default" mode, but not in USB do you have any idea what could be wrong? i wrote NVM also, still nothing. WBR Syed |
11-04-2009, 05:15 | #3 (permalink) |
Member: 19979 Status: Offline Thanks Meter: 116 | Tried flashing in repair mode also only works in DEFAULT mode, not in USB and it didnt help either. Mr. Elco, i hope you know why NSPro kills M620 WBR Syed |
11-04-2009, 06:54 | #4 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | am not sure..about lang u try to install try this version with this Optiflash to revive Your Phone for NOw M620ASIA1+cts.zip M620XXHF1.zip M620_optiflash_Alto_20080115.zip |
11-04-2009, 11:27 | #5 (permalink) |
Member: 19979 Status: Offline Thanks Meter: 116 | thanks Amir, problem is that phone isnt detected on USB anymore when i connect using *+USB, so Opti cant flash it, and i only flashed with NSPro, using files downloaded from NSPro support. i can only flash it on DEFAULT mode. WBR Syed |
11-04-2009, 12:52 | #6 (permalink) |
Member: 19979 Status: Offline Thanks Meter: 116 | OK, Update After flashing with your M620ASIA file i can again connect with USB and flash again, but phone still dead, any more ideas ? WBR Syed |
11-04-2009, 12:56 | #7 (permalink) |
No Life Poster Join Date: Jul 2009 Location: philippines now here in U.A.E Age: 38
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | dead you flash with eeprom i think that problem is solve with write eeprom i also incounter that write this http://www.4shared.com/file/13978095...M620XEHE3.html this file is tested 100% write this if not work chick the hardware problem make sure write eepprom and write this file good lock with best regards: lilong lee |
11-04-2009, 13:12 | #8 (permalink) | |
Member: 91045 Status: Offline Thanks Meter: 8,696 | Quote:
Good to know that Syed.! Ok mean after flashing my File Your Phone Become Alive or Only USB Connectable ? u did flashing retry with OptiFlash I know u need to change Language Badley.. @lilong Mate EEPROM cannot be flashed with NSPRO Check First then POST | |
11-04-2009, 13:13 | #9 (permalink) |
Member: 19979 Status: Offline Thanks Meter: 116 | any Link for EEPROM ? or you mean NVM ? i wrote NVM from support area, didnt help. also i already flashed with file you posted, it didnt help. WBR Syed |
11-04-2009, 13:17 | #10 (permalink) |
Member: 19979 Status: Offline Thanks Meter: 116 | @Amir It is still dead, but i can now connect with USB and can flash with Opti. i dont need to change language now :-) i just need to revive it, that would be saving grace for today :-) |
dead 7610 with difficulty flashing with MT-Box and JAF | Phantom | Nokia Hardware & Hardware Repair | 2 | 03-28-2007 18:12 |
dead 6280 with usb flash ! now ok | singhdeep | MT-BOX | 1 | 03-06-2007 02:00 |
Dead L7 with Chinese flash, Need help. | mobile_2003 | Motorola P2k | 2 | 09-30-2006 08:22 |
Calculate *.ldb to *.lc for DEAD ME45 with CE20 flash | Karateka | Phone Unlocking Codes & Maps | 3 | 09-22-2002 22:20 |
Help me restore dead C35 with AMD Flash (flash HC B701)!!!!!Please!!!!!! | razor | x1x to x45/x50 | 0 | 11-29-2001 09:13 |
