12-18-2008, 11:51 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Donkey world
Member: 712832 Status: Offline Thanks Meter: 290 | E250 problem Powering on mobile... Target detected! Speed successfully changed Flash Type Detected [ SAMSUNG : KAP29SN00M ] Starting binary uploading... UPLOAD : 0x20000000 ~ 0x2001FFFF ... OK UPLOAD : 0x20020000 ~ 0x2003FFFF ... OK UPLOAD : 0x20040000 ~ 0x2005FFFF ... OK UPLOAD : 0x20060000 ~ 0x2007FFFF ... OK UPLOAD : 0x20080000 ~ 0x2009FFFF ... OK UPLOAD : 0x200A0000 ~ 0x200BFFFF ... OK UPLOAD : 0x200C0000 ~ 0x200DFFFF ... OK UPLOAD : 0x200E0000 ~ 0x200FFFFF ... OK UPLOAD : 0x20100000 ~ 0x2011FFFF ... OK UPLOAD : 0x20120000 ~ 0x2013FFFF ... OK UPLOAD : 0x20140000 ~ 0x2015FFFF ... OK UPLOAD : 0x20160000 ~ 0x2017FFFF ... OK UPLOAD : 0x20180000 ~ 0x2019FFFF ... OK UPLOAD : 0x201A0000 ~ 0x201BFFFF ... OK UPLOAD : 0x201C0000 ~ 0x201DFFFF ... OK UPLOAD : 0x201E0000 ~ 0x201FFFFF ... OK UPLOAD : 0x20200000 ~ 0x2021FFFF ... OK UPLOAD : 0x20220000 ~ 0x2023FFFF ... OK UPLOAD : 0x20240000 ~ 0x2025FFFF ... OK UPLOAD : 0x20260000 ~ 0x2027FFFF ... OK UPLOAD : 0x20280000 ~ 0x2029FFFF ... OK UPLOAD : 0x202A0000 ~ 0x202BFFFF ... OK UPLOAD : 0x202C0000 ~ 0x202DFFFF ... OK UPLOAD : 0x202E0000 ~ 0x202FFFFF ... OK UPLOAD : 0x20300000 ~ 0x2031FFFF ... OK UPLOAD : 0x20320000 ~ 0x2033FFFF ... OK UPLOAD : 0x20340000 ~ 0x2035FFFF ... OK UPLOAD : 0x20360000 ~ 0x2037FFFF ... OK UPLOAD : 0x20380000 ~ 0x2039FFFF ... OK UPLOAD : 0x203A0000 ~ 0x203BFFFF ... OK UPLOAD : 0x203C0000 ~ 0x203DFFFF ... OK UPLOAD : 0x203E0000 ~ 0x203FFFFF ... OK UPLOAD : 0x20400000 ~ 0x2041FFFF ... OK UPLOAD : 0x20420000 ~ 0x2043FFFF ... OK UPLOAD : 0x20440000 ~ 0x2045FFFF ... OK UPLOAD : 0x20460000 ~ 0x2047FFFF ... OK UPLOAD : 0x20480000 ~ 0x2049FFFF ... OK UPLOAD : 0x204A0000 ~ 0x204BFFFF ... OK Checksum error during bin upload Press NEXT to continue... can you help me but customers is very crazy, phone dead (no power on) |
12-18-2008, 23:11 | #2 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Romania
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | Connect the phone with battery for flashing or use a shorter USb cable to connect nspro to PC. Usualy that problem is caused by insufficient power on NsPro box. PS. If you read the E250-E250D documentation from support area, you will NEVER get such problems wile unlocking E250 phones. Just check and select the CORRECT model on NsPro. |
12-21-2008, 09:43 | #7 (permalink) |
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | If you read the documentation from support area regarding E250-E250D, U600-U600B/G, U700-U700B, etc... you will never get such problems. That documentation contain simple and easy to understand method to recognise the specific phone model (hardware) that you get in your hand. So when you will recieve an E250D phone in your hand, you will know how to check the EXACT phone model and select the CORRECT phone model on NsPro. All this problems are caused by peoples LAZYNES to READ a documentation. Everyone who enter on NsPro support area can see that documentation with a big tittle there "ATTENTION!!!" but only few take attention on them. So is user fault when they damage the phone because they selected WRONG model on NsPro |
12-21-2008, 09:52 | #8 (permalink) |
No Life Poster Join Date: Sep 2005 Location: algeria BBA BELIMOUR Age: 46
Member: 184351 Status: Offline Thanks Meter: 263 | and as an advice always use read info before any operation (for unlock) and enter codes manually and if phone dead ,look to the mother board if it is blue it is e250d if green it is e250 the same for direct unlock (always put this in your mind) for not crying afterwards |
06-24-2009, 19:24 | #9 (permalink) |
Crazy Poster Join Date: May 2004 Age: 54
Member: 66972 Status: Offline Thanks Meter: 14 | i have same problem try to erase everything with hwk but nothing happend , same situation . i try to change speed same thing , and i try and i try about 2 hours after that phone succefuly flashed one by one bin and after that tfs and phone working now. i was flashed with ns pro |
06-29-2009, 14:56 | #12 (permalink) | |
Freak Poster Join Date: May 2006
Member: 277720 Status: Offline Thanks Meter: 5 | If you find the solution - let me know i have 20-30 pcs here with same problem ....i bet that your e250d is from t-mobile uk blossom colour Quote:
E250 problem. Flashed with E250 and also E250D!! Please help? | .ALDAGSM. | NSPRO | 4 | 05-23-2008 07:30 |
E250 problems | dthang8 | Samsung Flashers, Software, Firmware. | 3 | 07-19-2007 05:56 |
E250 Problem | saeed-gsm | NSPRO | 1 | 07-02-2007 17:06 |
E250 problem with imei change | cellularman | NSPRO | 1 | 04-06-2007 20:12 |
E250 problem | schwantz | NSPRO | 10 | 02-15-2007 07:25 |
