11-05-2009, 13:59 | #1 (permalink) |
Junior Member Join Date: Nov 2009
Member: 1154322 Status: Offline Thanks Meter: 11 | Easy Remove phone code F480,F480V,F490,F490V... Put Phone In Flash Mode Press - volume up -Camera button -power button Select file Needed From Folder in link And Press write For Users who no have any box can also use MultiLoader link: http://www.megaupload.com/?d=2HGTITTJ |
The Following 10 Users Say Thank You to BouMezioued For This Useful Post: |
11-08-2009, 12:43 | #3 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | NO When User lock is on u cannot Take INFO ...notthing will be shown (as USb connection wont get established) Flashing is Needed Must That trick is with download mode where only flashing possible instead of flashing all only flash as been Shown in PIC |
11-08-2009, 16:34 | #6 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: U-A-E Dubai---->Pak
Member: 315789 Status: Offline Thanks Meter: 3,428 | Quote:
smells to me working solution... let me try it first, BR | |
11-08-2009, 17:33 | #7 (permalink) |
Member: 1154322 Status: Offline Thanks Meter: 11 | yes Just flash the Filesystem and not all the Files to remove User Code and i have put 4 files in folder for 4 model F480 F480V F490 F490V this better to downlod all flash files to remove only user code from phone |
12-06-2009, 15:15 | #10 (permalink) | |
No Life Poster Join Date: Apr 2005 Age: 37
Member: 141164 Status: Offline Thanks Meter: 36 | Quote:
very usefull info thanks for that and thanks for link as well, worked liked charmed. Writing Filesystem file Formatting file system (this might take a while) Proceeding with file... Writing file done Operation successfully completed | |
12-07-2009, 07:12 | #12 (permalink) |
Member: 91045 Status: Offline Thanks Meter: 8,696 | If User Knows the FW version And have or able to get the Firmware of that version Its a Time Saver..Flashing FS took little time... Offcourse last solution is Full Flashing...but still this Solution worth |
12-07-2009, 08:17 | #15 (permalink) |
No Life Poster Join Date: Sep 2007 Location: iran-shushtar
Member: 592636 Status: Offline Thanks Meter: 674 | im tested this solotion service job then select 2 win 1. reset phone lock 2. reset simlock 2times tested and worked perfect i think dont need to wriiting any flash file |
Easy Remove phone code F480,F480V,F490,F490V... | BouMezioued | QUALCOMM Models (3G) | 0 | 11-05-2009 13:56 |
how to remove frezee code F480 | mrphuc | Easy-Unlocker | 5 | 12-04-2008 18:09 |
Phone Codes - F480, u900 | TeepeeUnlock | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 2 | 09-15-2008 20:51 |
need master code to remove phone code on sx1* | infogsm | Phone Unlocking Codes & Maps | 2 | 04-22-2005 02:52 |
Removing Phone Code | GSMBlade | Motorola Old Legacy (EMMI) | 7 | 05-15-2001 01:49 |
