Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > NSPRO
Old 04-04-2013, 18:21   #1 (permalink)
Member: 908175
Thanks Meter: 314
elco sir need help on i8190 mini
i have glaxy mini i8190N i have roted the phone about 10 times with file from support but dosnot work always says phone not rooted plz upload new file on support for i8190n
Old 04-05-2013, 00:36   #2 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
Thanks Meter: 25,395
PLZ download and install NsPro v6.6.1 again from : : NsPro Downloads: :
Then try to unlock the phone again.
This should solve your problem.
No need to root the phone to unlock it by NsPro...
Old 04-05-2013, 14:15   #3 (permalink)
Member: 908175
Thanks Meter: 314
It doesn't work always says need root the phone has 4.2.1 version but already rooted the phone manuly and its done
Old 04-05-2013, 20:53   #4 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
DOWNLOAD AND INSTALL THE SOFTWARE AGAIN!!!!!!!!!!!!!!!!!!
NO ROOT REQUIRED!!!
If you fallow my instructions, you will not get that root prompt on NsPro
Old 04-08-2013, 18:45   #5 (permalink)
jamal2010's Avatar
Member: 243827
Sonork: 100.1583557
Thanks Meter: 247
Phone NOT ROOTED!!! or unexpected response!
Waiting for phone...
Sending Rootkit...
Checking if phone is Rooted...
Operation failed!
I use 6.6.1
Old 04-08-2013, 22:43   #6 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
Sending Rootkit...
Operation failed!
I use 6.6.1
if you read my post above, you will find the answer
Old 04-09-2013, 10:37   #7 (permalink)
Member: 908175
Thanks Meter: 314
With new version u need root phone first then u can unlock if phone has old android version then u can unlock with out problem
Old 04-09-2013, 12:25   #8 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
NO ROOT REQUIRED!!!!!!!!!!!
Just fallow my instructions above and i8190/i8190n will be unlocked in maximum 5 seconds.
Old 04-09-2013, 16:07   #9 (permalink)
Member: 1202098
Sonork: none
Thanks Meter: 19
use 6.6.1, turn on adb, connect phone to usb install drivers then press unlock when software asks connect phone to uart. must work, in these days I've unlocked 4 pieces. Worked well... check ifyou work with 6.6.1 version. easy as 123
Page generated in 0.19223 seconds with 8 queries
