GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   NSPRO (https://forum.gsmhosting.com/vbb/f286/)
-   -   (error 0X01) When try to run software (https://forum.gsmhosting.com/vbb/f286/error-0x01-when-try-run-software-1515082/)
curtisbcm 08-02-2012 23:11
Dear support,
I have installed latest version of Nspro software on Win7 32bit, but when I try to run nspro software I get this message, 'error 0x01'. How do I fix this? :confused::confused::confused:
unlock.mk 08-02-2012 23:12
install this: think is driver problem
http://www.nsteam.org/e-gate_3.0.6_xp2k.zip
or:
http://forum.gsmhosting.com/vbb/f286...5/#post8259807
Elco 08-03-2012 22:46
Originally Posted by curtisbcm (Post 8640504)
Dear support,
Use windows update to install the Smartcard driver.
That will solve the problem.
soctia 08-03-2012 23:46
Elco be careful of windows update sometimes it install a driver that conflic and cause NSPRO not to work
Elco 08-04-2012 14:11
i always use windows 7 smart card drivers from windows update.
Microsoft provide a generic smart card driver that work with most of the smart cards available at the moment.
So just let the windows 7 search for drivers online and will solve the smart card drivers problem for you.
Windows 7 update will also install and start smart card service.
curtisbcm 08-08-2012 22:56
None of this worked. Right now am installing XPPRO. NsPro please get your box drivers up to date and stop the trial and error information with your customers.
Thank you.
Elco 08-09-2012 02:04
1 Attachment(s)
Thank you.
the drivers are up to date.
Your problem are the smartcard drivers.
On win7 you must use Microsoft smartcard drivers. If your windows is genuine, windows will download and install the drivers automaticly from microsoft servers.
Anyway, if you have problems using microsoft update, here i attached the drivers...
idriscop 08-09-2012 03:07
solution
make sure you install your nsprobox very well then follow this proccess
Right click on nspro icon then click properties then click on compatibility
compatibility mode
tick run this program in compatibility mode for
then choose window xp(service pack2)
1000% tested
don't forget to click thanks
winits 08-17-2012 20:40
Hey guys, once again my nspro is being awkward & wont let me run the software, the wise words from Elco last time sorted the issue, but its started again, it says i have the "Gemalto" drivers version 4.0.0.2 even after uninstalling everything & deleting the nspro folder from program files then restarting the pc, then re-installing nspro software & restarting the pc again then plugging in the box & installing the drivers and then using win update for smartcard driver and i still get this error 0x01 smartcard missing or corrupt!
Help please.
winits.
Elco 08-17-2012 22:43
Solution 1:
Delete NsPro folder from \Program Files then reinstall latest NsPro version
If that dont work, go to next solution.
Solution 2.
Right click on "My computer" go to Manage->Services and Applications->Services
Search for "Smart Card" service Make sure is STARTED.
If not started, right click on it and select START.
If still having problems, feel free to leave me a message on yahoo messenger or sonork.
You can find my yahoo messenger id on my forum profile.
Page generated in 0.14315 seconds with 6 queries
