03-18-2009, 11:04 | #1 (permalink) |
Freak Poster Join Date: Jul 2005 Location: Manchester Age: 43
Member: 160666 Status: Offline Thanks Meter: 7 | G800 unlock problem If i plug my E210 cable in the box i get this USB Hub power exceeded Checking serial communication... Operation failed! If i use the adaptor and plug the E210 i get this Checking serial communication... Operation failed! I know the Cable is fine as i just got it replaced and i can do J700i, G600, U900 with NO problem I have got no error on the drivers side, they are install propelly as far as iam aware A little bit of help would be apreciated |
03-24-2009, 08:14 | #7 (permalink) | |
No Life Poster Join Date: Oct 2006 Location: pakistan
Member: 373786 Status: Offline Sonork: 100.1601935 Thanks Meter: 130 | Quote:
05-08-2009, 04:53 | #10 (permalink) |
Freak Poster Join Date: Oct 2005 Location: perth aust.
Member: 188959 Status: Offline Thanks Meter: 7 | Not sure if this helps , but i could not get the handset to connect for over an hour , with about 50 attempts to connect. The next day I set the software to flash , changed back to unlock WITHOUT pressing change jobs , then i went back to change jobs /unlock, and it connected first time ,and unlocked very quickly . it was so quick I had doubted that it was even unlocked , but on checking, it was. In other words , KEEP TRYING! [oh , and clean the port and data cables too ] |
10-23-2009, 09:23 | #12 (permalink) |
Member: 188959 Status: Offline Thanks Meter: 7 | After reading my own instructions , I found it failed on me this time! Another way to do it to fire up nspro , press unlock. It will ask to enter *#726872#, which you do. When you press ok , it cannot find the handset . NOW turn off nspro , switch off the phone , and repower nspro. You press unlock , and when asked to press the pc mode code, just press ok , then power on the phone as it is searching for the phone. Have done a number of them now , and seems to work ok! .Give it a try |
The Following User Says Thank You to fonegeeks For This Useful Post: |
05-23-2010, 10:47 | #13 (permalink) | |
No Life Poster Join Date: Apr 2005 Age: 37
Member: 141164 Status: Offline Thanks Meter: 36 | Quote:
09-06-2010, 10:58 | #14 (permalink) |
Registered User Join Date: Oct 2007
Member: 620883 Status: Offline Thanks Meter: 38 | Count supported models - 203 Searching Samsung USB interface... not found Searching Samsung USB interface... not found ----------------------------- Model: U900G CountryCode: DTM Factory SW: U90GBOHL1 UniqueNumber: 80250000143239 MemoryPhone: K5R2G1GACM(U900) IMEI: 35524302581280/8 Phone S/N: RVIS140980 Build: M6281A-KLRZ-4.0.9530 Reading SysInfo... OK Calculating... OK Calculating codes... OK (time - 00:00:57) Freeze code: 17580406 NET lock: #7465625*638*68293603# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# ----------------------------- No answer from phone Error read info ----------------------------- Model: U900G CountryCode: DTM Factory SW: U90GBOHL1 UniqueNumber: 80250000143239 MemoryPhone: K5R2G1GACM(U900) IMEI: 35524302581280/8 Phone S/N: RVIS140980 Reading SysInfo... OK Calculating... OK Searching Samsung USB interface... not found Unlocking... OK (time - 00:00:03) good work z3x teem |
G800 Unlock Problem | .:Morpheus:. | UST Pro II | 24 | 03-02-2009 15:01 |
g800 unlock problem | accurate | UST Pro II | 2 | 03-05-2008 18:24 |
pantech G800 unlock problem | gsm_enggine | Infinity-Box | 2 | 08-24-2007 03:54 |
