Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > NSPRO
Old 06-30-2013, 15:55   #1 (permalink)
Thorenzz's Avatar
Member: 1176876
Sonork: 100.1607051
Thanks Meter: 154
Galaxy S3 LTE i9305 IMEI repair DONE! Guide inside!
i9305 IMEI repair done:
Well done NSPRO! After i repaired imei with other boxes, i had no 3g/4g working. Phone was only working on 2G. But with NSPRO everything works as it should. Thanks NSPRO.
Settings used:
ONLY USB CABLE
Phone rooted manualy with CF-AUTO-ROOT
USB debuging on.
*#7284# - USB -> PDA,,,,,UART -> PDA
qualcomm usb settings -> DM+MODEM+ADB
*#9090# - DM over HS-USB, reboot
The Following 2 Users Say Thank You to Thorenzz For This Useful Post:
Old 07-13-2013, 02:11   #2 (permalink)
Member: 123581
Thanks Meter: 19
hulp plz
Settings used:
ONLY USB CABLE
USB debuging on.
hi br
i felow all thik only problem is when i type *#9090# i am not getting any options have you solustion for this plz thanks
Old 07-13-2013, 02:37   #3 (permalink)
Thorenzz's Avatar
Member: 1176876
Sonork: 100.1607051
Thanks Meter: 154
Originally Posted by abdel- View Post
hi br
Are u sure that phone is i9305 not i9300? If yes then flash the phone with different firmware. Some firmwares have this menu disabled.
Sent from my GT-I9505 using Tapatalk 2
Old 07-13-2013, 03:20   #4 (permalink)
Member: 123581
Thanks Meter: 19
sur
yes i me sure is one i9305
one mor thin i tape *#1234# to see the version the midel one i meen CP the modem is unknow
Old 07-13-2013, 09:17   #5 (permalink)
Thorenzz's Avatar
Member: 1176876
Sonork: 100.1607051
Thanks Meter: 154
In that case tgis may be hw problem. Reflash phone with 3parts fw and pit file and check repartition in odin. And see if u get modem part working again. If no, then sorry but no sw solution for u.
Old 07-16-2013, 09:52   #6 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
Thanks Meter: 25,395
Select T889 on NsPro and write IMEI on the phone.
That will solve the unknown baseband (CP) problem on your phone
The Following User Says Thank You to Elco For This Useful Post:
Old 07-16-2013, 16:03   #7 (permalink)
Member: 123581
Thanks Meter: 19
is other option to put the phone on DM/DUN in place for *#9090# bcs is empty
thanks for hulp
Old 07-20-2013, 15:40   #8 (permalink)
Member: 23661
Thanks Meter: 29
thanks for hulp
Have same problem. nothing on screen after *#9090#. plus CP unknown.
here log with T889 options
Waiting for phone...
Checking if phone is Rooted...
Root Access Granted!
Waiting for Phone...
Preparing phone...
Preparing Baseband...
Processing Baseband...
Processing Factory Mode...
Finishing preparation...
Rebooting phone...
Writing IMEI...
Operation failed!
Old 07-20-2013, 22:18   #9 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
If you use nspro on win 7, run nspro as administrator and try again.
Old 02-05-2014, 14:53   #10 (permalink)
Member: 1618416
Thanks Meter: 27
thanks this one work for me thans u saved my life
Page generated in 0.19463 seconds with 8 queries
