Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > NSPRO
Old 02-08-2013, 11:43   #1 (permalink)
OXB
Member: 1109469
Thanks Meter: 2
Help me to fix Samsung galasy Note 2 N7100 unknown baseband and Imei null
Hi all u guys!
I tried to fix samsung galaxy note 2 n7100 baseband corrupted, and imei is null, i tried with latest of nspro v6.5.7 but not work.
here log : when done with restored esf file from working phone.
Waiting for phone...
Checking if phone is Rooted...
Root Access Granted!
Restore started
Preparing Device...
Sending Toolkit...
Setting Toolkit Permissions...
Checking EFS location...
Pushing file to phone...
Setting permissions...
Running restore. This will take a while!
Restarting Phone...
Operation successfully completed
But the second step i tried to change imei but not work
I think as i used *#9090# to change speed to 115200 not go on just appeared "ServiceMode"? determine the cable Rj45 is work fine with another phone like N7000,...
how do i do?, please help me all u guys?
here the logs the second step:
Preparing Phone...
Resetting IMEI...
Setting efs permissions...
Connecting to phone UART...
Operation failed!
Old 02-08-2013, 13:27   #2 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
Thanks Meter: 25,391
PLZ use SEARCH function on this forum before posting.
Other peoples had the same problems before and they already got the answer:
Glaxy Note2 n7100 Imei Damaged...
Old 02-09-2013, 11:33   #3 (permalink)
OXB
Member: 1109469
Thanks Meter: 2
Hi brother i tried it already, after i flashed "N7100_IMEI_Baseband_Repair" from latest version nspro and flashed with it successfully, then just still unknown baseband and imei still null.
here the result just shown yellow text on the SCREEN after i flashed:
PDA:N7100XXALIE
Phone:Unknown
CSC:N7100LBALI9
H/W:Not active
RF Cal Date: Unknown
Band:Unknown
Memory:16G
Sorry i just typed following it because cannot upload image.
how do i go it on?
Old 02-20-2013, 10:38   #4 (permalink)
OXB
Member: 1109469
Thanks Meter: 2
now i know how to upload image for u.
This is the result when i flashed with "N7100_IMEI_Baseband_Repair" downloaded from Nspro support with the nspro v6.5.8
Now how do I do it again brother?
Old 02-20-2013, 13:17   #5 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
as i can see, the baseband still "unknown" on the phone.
Most likely the phone have a hardware problem.
Anyway... if you whant to get rid of that yellow info screen, write imei on the phone using nspro v6.5.8.
Even if the operation fail, the yellow info screen will dissapear after reboot.
The Following User Says Thank You to Elco For This Useful Post:
Old 10-08-2013, 22:04   #6 (permalink)
Member: 908175
Thanks Meter: 296
It is 10000% nspro soft wear problem as soon we flash the file from support yellow writing come I have search fourm who has flash the ns file they had this problem so plz delet that file from support it's bug
The Following User Says Thank You to qasi786 For This Useful Post:
Old 10-29-2013, 00:59   #7 (permalink)
ali42's Avatar
Member: 60701
Sonork: 100.1623285
Thanks Meter: 121
Yellow
You need to have a rooted device.
Using a root explorer ON PLAY STORE
Systemroot/efs/FactoryApp
Then open "Factorymode" using a text editor and change from OFF to On and then save and reboot.
SOURCE GSM69
Old 11-22-2013, 21:23   #8 (permalink)
Member: 2069362
I have the same problem after IMEI repair "Connecting to phone UART...
Operation failed!" Please help me because i don't know how i can bring my N7100 to live, i was checked many methods any nothing
Old 11-23-2013, 06:10   #9 (permalink)
Member: 1138694
Thanks Meter: 66
Smile
Friends.
I encountered same problem with note ii n7100.
First of all downgrade from 4.1.2 to 4.1.1
after downgrade phone will stuck at samsung logo.
Dont panic.keep pressing vol.up+home button+power key release after few seconds.now select wipe/factory data reset.phone will reboot .now baseband must be ok.
Write imei now and phone will display imei and android version 4.1.1. Network will be fine now.
4.1.2 version will not allow to write imei.
Jaideep mehta.
India.
The Following 2 Users Say Thank You to mehta jaideep For This Useful Post:
Old 11-26-2013, 16:14   #10 (permalink)
Member: 1781155
Hi,
mehta jaideep Big Thanks,
Works, tested 100% on 2 pcs.
Old 11-27-2013, 20:09   #11 (permalink)
Member: 2069362
Now i have android 4.1.2 (N7100XXDME2_N7100PRTDME2_N7100XXDLK7_HOME) and everything is ok, but when i write Android Revolution HD 19.0 to my n7100 my IMEI is changing to null/null and i lost my baseband, i must go back to previous stock rom and repair my IMEI, why i can't use Revolutio HD ROM?
Old 12-22-2013, 09:25   #12 (permalink)
Member: 97242
Thanks Meter: 12
i've problem with 4.1.1 too, no uart connection, how to solve?
Old 01-29-2017, 11:57   #13 (permalink)
campus's Avatar
Member: 568843
Thanks Meter: 46
REPAIR INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or
tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Fill values what you need to repair.
5. Press 'Repair' button.
6. Press 'Reset EFS' if you need to reset it.
Be carefully, do not perform this without necessity and make backup before.
7. Press 'Disable Factory Mode' or 'Patch Certificate' if needed.
Operation: Repair
Selected model: GT-N7100
Software version: 20.5
Waiting ADB device... OK
Reading phone info...
Model: GT-N7100
Android version: 4.4.2
Product code: Not Active
Phone version: N7100XXUFOA1
PDA version: N7100XXUFNL1
CSC version: N7100OJVFOD1
CSC country code: UAE
CSC sales code: XSG
HW version: Unknown
Phone S/N: 00000000000
Modem board: XMM6262
RF cal date: Unknown
IMEI: 004999010640000
Checking Super user right... true
Reading nv data... OK
Checking magic... OK
Running zTool, please wait... OK
Detected new type of security version 0
Calculating... OK
Writing nv data... OK
Rebooting phone... OK
Repair done
Done with Samsung Tool v.20.5
Old 02-09-2017, 00:35   #14 (permalink)
krisu0007's Avatar
Member: 1670851
Thanks Meter: 242
firstly this post is 4yr old
secondly u used diff tool (not to mention u used last free version of that tool) :P
Old 02-12-2017, 00:40   #15 (permalink)
Member: 293299
Thanks Meter: 220
he used Z3X BOX and is posting in NSPRO section no respect!
Page generated in 0.41584 seconds with 7 queries
