01-01-2013, 13:49 | #2 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Romania
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | If the phone is in "baseband unknown" state and no imei, you must fix the baseband unknown problem, then you can write imei by nspro. Use factory efs file from nspro support area to repair the baseband. After flashing that file to phone, the IMEi will become 00499... Then you can write imei on the phone by NsPro. |
01-01-2013, 17:37 | #3 (permalink) | |
Freak Poster Join Date: Apr 2005 Age: 39
Member: 138926 Status: Offline Thanks Meter: 0 | Quote:
01-01-2013, 17:58 | #4 (permalink) | |
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | Quote:
I will fix it on next version. Anyway, if the communication with the phone is OK, you should NOT get that message. If you get that message, then there is a problem on your NsPro S7070 cable or on the phone. PLZ make sure that you use NsPro S7070 cable., NsPro work ONLY with NsPro cables. Will not work with cables made for other models. | |
01-03-2013, 16:15 | #5 (permalink) | |
thanks | |
01-03-2013, 17:26 | #6 (permalink) | |
or by skype: elco_nsdongle and I will help you to solve that problem in real time. | |
01-10-2013, 05:49 | #7 (permalink) | |
Initialising connection... Checking if protocol is initialised... Protocol is not initialised. Initialising protocol... Handshaking with Loke... Beginning session... Session begun Reading PIT from device... PIT read successfully WARNING: Partition corresponding to file could not be located Ending session... Rebooting device... Press NEXT to continue... | |
01-10-2013, 06:23 | #8 (permalink) |
Member: 138926 Status: Offline Thanks Meter: 0 | Waiting for phone... Checking if phone is Rooted... Root Access Granted! Resetting IMEI... Waiting for phone... Setting efs permissions... Connecting to phone UART... Operation failed! |
01-10-2013, 23:58 | #9 (permalink) | |
PLZ contact me by yahoo messenger and i will help you to fix it. | |
01-21-2013, 22:24 | #10 (permalink) |
Insane Poster Join Date: Jul 2008 Location: Belgrade
Member: 823073 Status: Offline Thanks Meter: 3 | i have to this problem... Waiting for phone... Sending Exynos Exploit... Setting initial permissions... Running Exynos Exploit... Exploit Success! Waiting for phone... Checking if phone is Rooted... Root Access Granted! Resetting IMEI... Waiting for phone... Setting efs permissions... Connecting to phone UART... Using Advanced MSL... Operation failed! |
01-23-2013, 08:57 | #11 (permalink) | |
Make sure you are using NsPro v6.5.5 | |
01-23-2013, 10:52 | #12 (permalink) |
Member: 823073 Status: Offline Thanks Meter: 3 | i flash with N7000XXLS2_N7000OXXLS2_OXX ( Android v4.1.1 Jelly Bean ) and use 6.5.5 http://www.image-share.com/ijpg-2037-133.html http://www.image-share.com/ijpg-2037-134.html http://www.image-share.com/igif-2037-135.html |
07-05-2014, 16:58 | #13 (permalink) |
Junior Member Join Date: Dec 2007
Member: 659033 Status: Offline Thanks Meter: 0 | Hello I do have following problem: Initialising connection... Checking if protocol is initialised... Protocol is not initialised. Initialising protocol... Handshaking with Loke... Beginning session... Session begun Reading PIT from device... PIT read successfully Uploading EFS ERROR: Failed to confirm end of file transfer sequence! EFS upload failed! Error flashing file D: \N7000_ EFS. tar. md5 Ending session... Rebooting device... Press NEXT to continue... Are there any sugestions? |
