12-09-2009, 13:35 | #2 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Donkey world
Member: 712832 Status: Offline Thanks Meter: 290 | if you use original cable E210 (rg45) by nspro make sure nspro com port in 20, and you have a correct drivers for s5230 if not you can t unlock any phone with other cable from other tool good luck br |
12-10-2009, 06:38 | #3 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | Quote:
Phone should be connected Powered OFF At first... Then will be auto turned on when needed install correct drivers from S5230 folder in NSPRO root directory ...if operation failed at first...repeat procedure this time all should went fine | |
Help me to Delete Mo Hi Speed data | rakz123 | PalmOS /HP and others | 0 | 12-18-2009 19:18 |
Dear Zulea,How D750 IMEI can be changed to W800 with usb-smart? | zyairsnow | SonyEricsson (USB-Smart) | 4 | 01-12-2006 01:46 |
How can i change the language to C30? | DupleX | x1x to x45/x50 | 6 | 07-29-2002 04:19 |
How can i change IMEI to C35? | DupleX | x1x to x45/x50 | 1 | 06-20-2002 00:09 |
How can I change from 240101 to 210306? | GrAnD | x1x to x45/x50 | 1 | 06-10-2002 02:01 |
