How to enter unlock codes in samsung s3650, not accept codes when i enter,why? read unlock codes sucessfully but when i enter codes not accept allways phone frezzed, how to unlock? |
hi...same problem my s3650..phone is freeze!! And do not enter net lock!!. sos and call only.. how to enter master code ? #7465625*638#Code# ?? or different method?? please help me!! |
Hi no need to enter Code like that When U Get SOS and CALL option press call then enter master code (as it is) then netlock code will be asked and enter Only Code Your Phone will be Unlocked Unfreezed :) |
yesss phone is now unfreezed!! and enter unlock code all okk thanksssss!!! |
s3650 telcel Quote:
problem with s3650 from telcel mexico is that do not accept this method to input codes inmediately after you press sos call it gots locked and prompt to keep unlock buton to allow call functions, when you do so, it just go back to sos call screen i guess solution is to flash phone, but there is no flash in support any idea? regards |
hi guys! how can I unlock a samsung corby?? I found a site that talked about the same codes you do, but how/where can I find one? How can I unlock it? :O I know nothing about these things xD |
thx to amir-skillZ u halp very max |
NSPRO should readed Master Code if u noticed... Then power on the phone with any unaccepted sim card inside. The phone will show "Phone freezed" and will give you 2 options: "CALL" and "SOS" Select "CALL" Then type in the Master Lock code readed by nspro and tap OK after that if asked u can enter the Lock code (NETLOCK) *eso s ehace y d euna |
telcel I have the same problem from telcel not call option displayed, how put master code???? |
you must first enter the master code to unfreze the phone lik writen above den the the lock code br sharef |
