Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > NSPRO
Old 11-26-2009, 10:34   #1 (permalink)
svchost's Avatar
Member: 841080
Thanks Meter: 175
How to enter unlock codes in samsung s3650, not accept codes when i enter,why?
read unlock codes sucessfully but when i enter codes not accept allways phone frezzed, how to unlock?
Old 11-26-2009, 10:51   #2 (permalink)
sharef's Avatar
Member: 568521
Thanks Meter: 239
i will help you you have all redy the code ok put diferrenz sim kart insaid the phone the pone will give you 2chance sos or call press call den put the master code from nspro den the phone will ask you abaut the network code den put the network code your phone is unlocked
The Following 17 Users Say Thank You to sharef For This Useful Post:
Old 11-26-2009, 11:42   #3 (permalink)
svchost's Avatar
Member: 841080
Thanks Meter: 175
thnx friend this method works like charm
The Following User Says Thank You to svchost For This Useful Post:
Old 12-09-2009, 21:54   #4 (permalink)
Member: 89326
Thanks Meter: 6
hi...same problem my s3650..phone is freeze!! And do not enter net lock!!.
sos and call only.. how to enter master code ? #7465625*638#Code# ?? or different method??
please help me!!
The Following User Says Thank You to gunesalakan For This Useful Post:
Old 12-10-2009, 05:28   #5 (permalink)
Amir-SkillZ's Avatar
Member: 91045
Thanks Meter: 8,691
Hi no need to enter Code like that
When U Get SOS and CALL option press call then enter master code (as it is) then netlock code will be asked and enter Only Code
Your Phone will be Unlocked Unfreezed
The Following 12 Users Say Thank You to Amir-SkillZ For This Useful Post:
Old 12-10-2009, 06:05   #6 (permalink)
Member: 89326
Thanks Meter: 6
yesss phone is now unfreezed!! and enter unlock code all okk thanksssss!!!
Old 01-20-2010, 18:27   #7 (permalink)
Member: 109996
Thanks Meter: 9
s3650 telcel
hi friend
problem with s3650 from telcel mexico is that do not accept this method to input codes
inmediately after you press sos call it gots locked and prompt to keep unlock buton to allow call functions, when you do so, it just go back to sos call screen
i guess solution is to flash phone, but there is no flash in support
any idea?
regards
The Following 2 Users Say Thank You to mgcelulares For This Useful Post:
Old 01-30-2010, 19:49   #8 (permalink)
Member: 1223321
hi guys! how can I unlock a samsung corby?? I found a site that talked about the same codes you do, but how/where can I find one? How can I unlock it? :O
I know nothing about these things xD
Old 02-10-2010, 20:57   #9 (permalink)
Member: 756806
Sonork: julii
thx to amir-skillZ
u halp very max
Old 02-10-2010, 21:59   #10 (permalink)
Member: 1122648
Sonork: monster
Thanks Meter: 5
HI,
NSPRO should readed Master Code if u noticed...
Then power on the phone with any unaccepted sim card inside.
The phone will show "Phone freezed" and will give you 2 options: "CALL" and "SOS"
Select "CALL"
Then type in the Master Lock code readed by nspro and tap OK
after that if asked u can enter the Lock code (NETLOCK)
*eso s ehace y d euna
The Following 4 Users Say Thank You to monster1276 For This Useful Post:
Old 02-11-2010, 09:21   #11 (permalink)
Member: 549214
Thanks Meter: 4
you cannot do unlock yourself. you need to go to a gsm service center.
Old 02-15-2010, 21:06   #12 (permalink)
Member: 396605
Thanks Meter: 8
telcel
I have the same problem from telcel not call option displayed, how put master code????
Old 04-28-2010, 11:53   #13 (permalink)
Member: 177381
Sonork: 100.162218
Thanks Meter: 16
thank u man ***** bless u
Old 07-13-2010, 22:08   #14 (permalink)
Member: 1098336
Thanks Meter: 2
Unhappy
after i insert net lock code 8 digit phone do nothing display stay whit code and donīt give any keyboard to touch
Old 07-13-2010, 22:11   #15 (permalink)
sharef's Avatar
Member: 568521
Thanks Meter: 239
hi
you must first enter the master code to unfreze the phone lik writen above den the the lock code
br sharef
How to activate line 1? in samsung a737 -luigi- NSPRO 0 08-03-2009 22:45
How to remove contact service in samsung b320 JKKB HWK 4 02-15-2009 13:53
how to change color scheme in samsung z170 syms Samsung Media, Games, Ringtones 0 12-21-2008 18:29
How to write unlock map in C70 v43? janos6662000 S-Gold Based Phones 5 11-09-2005 22:02
Page generated in 0.44036 seconds with 8 queries
