03-11-2009, 20:10 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: HEAVEN
Member: 285345 Status: Offline Thanks Meter: 324 | How to remove F480 phone lock code I m trying to flash it but it say press volume key down+camera key+power button. set enter into boot mode but when I press ok it say set not connected. while when I change its imei and unlock its all process done properly,means cable is ok.what could I have to do now |
03-11-2009, 20:38 | #2 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Romania
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | Phone powered off. Press Volume down+Camera+Power on And the phoner will enter in download mode Then connect the phone to NsPro and flash it. |
The Following 3 Users Say Thank You to Elco For This Useful Post: |
03-11-2009, 20:44 | #3 (permalink) |
Freak Poster Join Date: Feb 2007
Member: 451464 Status: Offline Thanks Meter: 5 | power on the phone use rj45+usb conjunction cable conect phone to cable and go to servises and check reset option and press next button it will 100% reset the phone i done 1PC with this methode after that power off the phone and turn it on again the lock code will now by default (00000000) enter this code and enjoy man |
03-12-2009, 09:55 | #7 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Pinas Age: 45
Member: 91411 Status: Offline Sonork: 100.1584444 Thanks Meter: 372 | actually i just resolved 1 problem like this awhile ago....thanks to elco for the advice....check here http://forum.gsmhosting.com/vbb/showthread.php?t=697848 |
03-12-2009, 09:55 | #8 (permalink) |
03-12-2009, 09:58 | #9 (permalink) |
Member: 285345 Status: Offline Thanks Meter: 324 | when I press volume +camera+power key,set enter into boot loader mode.but in such condition when I connect cable and try to flash it ,it doesnt start flashing and says phone not detected,reconnect phone and try again. |
03-12-2009, 10:09 | #11 (permalink) | |
Member: 285345 Status: Offline Thanks Meter: 324 | Quote:
I check it after entering in to boot loader mode. also check in normal condition not entering in to boot loader mode. also check power off condition,and power on condition too. also check 1st enter into boot loader mode then connect cable, also check 1st connect cable and then enter in to boot loader mde, also check to change the cable. | |
03-12-2009, 10:30 | #12 (permalink) |
Member: 91411 Status: Offline Sonork: 100.1584444 Thanks Meter: 372 | ok now try this 1.turn off the phone 2.load your flash file to nspro 3.turn on your phone normally by just pressing power on and without any sim 4.connect your e210 nspro cable 5.click write flash button and a msg box will appear telling you to plug phone in boot mode 6.disconnect phone and turn it off 7.hold down volume button + camera button + power button simultaneously 8.you will have now boot mode 9.connect the phone to cable and press ok on the mgs box earlier and wait for process to finish. 10.smile hope that helps you.that all i did after all my other gadgets failed with direct lock code removal.... |
03-12-2009, 11:00 | #13 (permalink) | |
No boss I check ur method 3 time and read it and act upon very carefully. but no luck | |
Is there any chances to remove the phone lock code from S5233a.. | harim_1981 | Ultimate-Sam | 1 | 08-11-2009 15:57 |
how to reset U310 phone lock code ? | preshaust | FuriousGold | 10 | 10-12-2008 14:15 |
how to unlock w200i phone lock code | nirma | Cruiser Suite | 3 | 05-05-2008 18:27 |
how to unlock t250i phone lock code??? | Siemens man | Smart-Clip | 1 | 12-15-2007 11:47 |
how to remove VK mobile lock code? | Burnt Cobba | Various | 0 | 10-09-2003 20:39 |
