01-19-2015, 10:58 | #1 (permalink) |
No Life Poster Join Date: Dec 2008
Member: 934255 Status: Offline Thanks Meter: 63 | How to resolve Nspro card not found or corrupted (error 0x01)! There is any final solution for this error???? i try all solutions.... with old versions the box works with the new versions i get this error... is not a box reader problem... i try unistalll and install again many version... and i always get this error... with version 6.0.6 the box works... and on windows 7 also... with windows xp i get the error... is a driver problem because befor i format the pc the software works ok.... |
01-19-2015, 12:23 | #2 (permalink) |
Freak Poster Join Date: May 2001 Location: Spain
Member: 4571 Status: Offline Thanks Meter: 20 | I had solve a problem like these in these way: I had removed card from NSPro box, and i had put these card in old JAF card reader pen dongle, i install the drivers of the dongle and now everything works perfec, try and say something. |
02-03-2015, 13:46 | #7 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 57
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Read good in Card/Box drivers and you find also for XP, try installing these from Manually Directory. Remember that XP must need the other type of Driver Reader like Axalto and PC neede to configured right from "My PC>Control Pannel>Card Reader". It's a very old history, there are almoust 1000 post about this problem in this section, use Search button and you can find all procedure possible, sorry but i think that this problem is very easy and solved from many time, problem are only You Pc with XP, Drivers right installed and PC configureted right, (not use other 4/5 Card Reader for other Box becouse is clear you have conflict), seen that with Win 7 work perfectament. BR allumts |
03-05-2015, 02:41 | #8 (permalink) |
Member: 934255 Status: Offline Thanks Meter: 63 | hello, yes is a old story but i read many post and there isn't a solution... i use the drivers that came with the nspro... i think the drivers that came with the nspro isn't correct for xp... and at least in server should be correct xp drivers because many people as the same problem... |
03-07-2015, 21:59 | #9 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
BR allumts | |
