Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > NSPRO
Old 01-17-2010, 11:35   #1 (permalink)
maxpizza's Avatar
Member: 125945
How unlock s5230 whith request lock code to power on?
Please, i have one piece of S5230, this phone is locked for one code thath ask when i power on the phone, i not remember this code, and not is possible to enter in the phone.
Have one solution whith NS Pro for read or unlock this code that i have forgot?
i think was are clear, power on the phone and immeditly ask to me the code for enter, i not remember, have solution whith NS PRO?
Thank You
Max
The Following 2 Users Say Thank You to maxpizza For This Useful Post:
Old 01-17-2010, 12:33   #2 (permalink)
Amir-SkillZ's Avatar
Member: 91045
Sonork: 100.1577222
Hi,
When Code is ON Needed Phone mode cannot be SET (mostly u need to select manually when asked) ....so cannot proceed
Else only the way is flashing here u can get flash flasher and Video Demo about HOW TO
..:: VideoFlashing S5230 - Unlock Telcel - Reser User Code ::..
Old 01-17-2010, 13:02   #3 (permalink)
maxpizza's Avatar
Member: 125945
Originally Posted by Amir-SkillZ View Post
Hi,
But is possible Flash the PHONE whith this code that i not remember?, because i have other program for flash, (ns Pro not have this phone if not in Ns pro advisor, how put in modality Flash if not want enter?
Thank you for u answere
Old 01-17-2010, 13:06   #4 (permalink)
maxpizza's Avatar
Member: 125945
Hi,
This Fw have ITALIAN language or no, because i have the downloader 5.60 and the talian FW
MAX
The Following User Says Thank You to maxpizza For This Useful Post:
Old 01-17-2010, 13:09   #5 (permalink)
Member: 91045
Sonork: 100.1577222
if u have it then u can proceed to flash with your needed language
not needed to flash with specific fw as i posted in link....only flash is needed
Presss and hold VolumeDown+camera and power button to put in download mode and connect USb cable
Old 01-17-2010, 13:54   #6 (permalink)
maxpizza's Avatar
Member: 125945
Yes, thankx, i haved all FW whith no-brand S5230XXIE7, now i not have the USB cable, arrived to me tomorrow, but i have lock that whith tasto VOLUME-DOWN+CAMERA+POWER enter in Download mode whith no problem, unique thath not i understand, is this:
in the field RSRC2, i have 2 files, RSRC2_Player-One(Low)rc2 and RSRC2_s5230(Low)rc2, which put in the field the first or the second,
thankx
p.s. the field BOOT not Flash?
Old 01-17-2010, 14:53   #7 (permalink)
Member: 91045
Sonork: 100.1577222
Yes u can load any of RSRC2_Player-One(Low)rc2 and RSRC2_s5230(Low)rc2 files..
About boot yes no needed to flash until it really matters ...seen the video friend ?
i wish u good luck
Old 01-17-2010, 15:19   #8 (permalink)
maxpizza's Avatar
Member: 125945
i wish u good luck
Thankx for your answere, but not import if i put the first or the second?, excuseme, where is the difference?, Why have 2 files?, yes i have loock the video but i knowed this video or procedure, i have video from this and of S8000, thath are similar.
Excuseme because GOOD LUCK?, is danger this flash?
Max
Old 01-17-2010, 17:09   #9 (permalink)
Member: 91045
Sonork: 100.1577222
notthing is danger until u touched boot
2 files those contains Mid (ringtones etc) one is for S5230 Player One other is S5230 normal u can use both
in normal archive for flash files these same files have name with low and mid does not make difference..
Again br,
Old 01-18-2010, 10:23   #10 (permalink)
maxpizza's Avatar
Member: 125945
Again br,
Ok, ser, but my question was other, which file from this 2 i have need inserted?, the first or thesecond, which is the more good way?, i not speack perfectament the ENGLISH, but for me do u was important, i have need only these ultime answere for i flash this phone,
Thank you
Max
Old 01-18-2010, 10:30   #11 (permalink)
Member: 91045
Sonork: 100.1577222
use this one RSRC2_s5230(Low)rc2
Ok
Will work fine...
Old 01-18-2010, 10:54   #12 (permalink)
maxpizza's Avatar
Member: 125945
Ok
Will work fine...
OK, thank you, today or tommorow i have the cable and flash the phone, when finish i write the esit,
MAX
8700c how to turn off mass storage and to disable the personal lock code to UNLOCK? mymiela0419 FuriouS TeaM Products 3 10-02-2009 09:10
How To Power On N91-1 On Scheme? Unlocker_001 Nokia Base Band 5 ( BB-5 ) 0 06-28-2008 18:52
how to power on nokia 7390 within unlock Naseerjako BB5BOX 1 01-22-2008 15:31
6131 how to power on for unlock? louischara BB5BOX 13 10-13-2007 04:45
HEPL!!!! How unlock Telit t250! enyone know code to unlock? patiko84 Trash 2 03-29-2007 16:35
Page generated in 3.11905 seconds with 11 queries
