01-15-2010, 02:09 | #1 (permalink) |
Freak Poster Join Date: Jan 2009
Member: 960183 Status: Offline Thanks Meter: 33 | Samsung I6220 Unlock???????? I have read network code but it says Phone freezed or something like that... What can i do? i can insert code manualy or i can make it by nspro? Thanks! |
01-15-2010, 06:38 | #2 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | Hi, for this model Use Get INFO button Press Get INFO and connect to NSPRO Powered OFF Phone If drivers asked Point to NSPRO Root Folder of Drivers... If firstly Process failed its OK... Repeat process as drivers were installed Now all should went fine code will be readed enter as needed , |
The Following User Says Thank You to Amir-SkillZ For This Useful Post: |
01-15-2010, 15:03 | #3 (permalink) | |
Member: 960183 Status: Offline Thanks Meter: 33 | Quote:
01-15-2010, 17:11 | #4 (permalink) |
No Life Poster Join Date: Nov 2008 Location: UK NETWORK SOURCE
Member: 908175 Status: Offline Thanks Meter: 314 | put the wrong sim card and it will says phone freez then press cal button it typ master code then it will ask for net then typ net code jobe don good luck |
The Following User Says Thank You to qasi786 For This Useful Post: |
01-15-2010, 17:53 | #5 (permalink) | |
Codes are... Master Lock 29593824 Net Lock 68595262 The others codes are "00000000" When i try to enter #7465625*638*68595262# it says something but cant read coz message dissapear realy fast, but phone is in same condition... Masterlock how to enter? i try with some codes but same at net lock :S | |
01-15-2010, 18:16 | #6 (permalink) | |
Member: 908175 Status: Offline Thanks Meter: 314 | helo Quote:
Power on the phone with any unaccepted sim card inside. The phone will show "Phone freezed" and will give you 2 options: "CALL" and "SOS" Select "CALL" Then type in the Master Lock code readed by nspro and tap OK Then, the phone will ask for net lock code. Just type in the net lock code then tap OK The phone will be unfreezed and unlocked. | |
01-15-2010, 18:20 | #7 (permalink) | |
Member: 91045 Status: Offline Thanks Meter: 8,696 | Quote:
If still have problem contact me on Sonork I will help u instant.. Master u might not saw it typed but keep on typing complete code until phone auto ask for net lock code entering.. | |
Samsung i6220 problem | evaldosantos | Z3X-Team Products | 1 | 02-09-2010 16:39 |
Warning samsung I6220 dont unlock | marcio.bsb | UST Pro II | 1 | 01-06-2010 15:23 |
Samsung 3G UNLOCK - EASY UNLOCKER BOX IN STOCK WITH NEW FEATURES | aErOm | Main Sales Section | 0 | 12-14-2006 20:58 |
Samsung Qxxx Unlock and Imei Reset Soft, Samsung T10x Unlock and Imei Reset Softb | AlexG | Main Sales Section | 0 | 10-07-2002 18:52 |
