i8160 flashing failed help me hi i got i8160 from coustmer and he tried to update jellybin now screen is not coming but if i go to doenload mod screen appear i tried to flash with nspro support firmware I8160XXLD8_I8160OXXLD3_HOME.tar.md5 but its giving me error log is here [code:] Initialising connection... Initialising protocol... Handshaking with Loke... Beginning session... Session begun Reading PIT from device... PIT read successfully WARNING: Partition corresponding to cache.img.md5 file could not be located WARNING: Partition corresponding to hidden.img.md5 file could not be located WARNING: Partition corresponding to kernel.bin.md5 file could not be located WARNING: Partition corresponding to modem.bin.md5 file could not be located WARNING: Partition corresponding to system.img.md5 file could not be located Ending session... Rebooting device... Press NEXT to continue... [/code:] plz help me thanks |
Luck's like your phone is not a regular i8160, since it don't use normal i8160 partitions. You have 2 options: 1. Flash the phone with the original firmware and will be back to life. 2. Enable advanced flashing on NsPro and use pit file+firmware to flash the phone. This way nspro will repartition the phone for regular i8160 firmware. The second solution is not 100% guarantee'd, but is more than nothing, if you can't use the first solution. |
but i tried both solution and it still same i tried with odian and it says fail plz help me |
sir you are offline in yahoo messenger |
you managed to solve this problem? |
