08-21-2014, 16:11 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: JAMAICA
Member: 293299 Status: Offline Thanks Meter: 264 | I747 4.3 |
08-21-2014, 21:25 | #3 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 57
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Br | |
08-22-2014, 00:07 | #4 (permalink) |
Member: 293299 Status: Offline Thanks Meter: 264 | no I didn't downgrade the modem, i flash the phone with 4.3 file from support but before that i tried to flash with the other file from support which failed,the NV file was backed up NSPRO, i will try to do that |
08-22-2014, 16:50 | #8 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ALBANIA(Tirana) Age: 51
Member: 3617 Status: Offline Thanks Meter: 572 | Flash the phone i747UCUEMJB_ATTEMJB 4.3 with this flash file you can use after flashing yor Imei go !00 root your phone after can change imei |
The Following User Says Thank You to Unlocker AL For This Useful Post: |
08-23-2014, 14:47 | #9 (permalink) |
Member: 293299 Status: Offline Thanks Meter: 264 | Initialising connection... Checking if protocol is initialised... Protocol is not initialised. Initialising protocol... Handshaking with Loke... Beginning session... Session begun Uploading PITPIT upload successful Uploading PERSIST PERSIST upload successful Uploading RECOVERY RECOVERY upload successful Uploading SYSTEM SYSTEM upload successful Uploading BOOT BOOT upload successful Uploading ABOOT ABOOT upload successful Uploading RPM RPM upload successful Uploading SBL1 SBL1 upload successful Uploading SBL2 SBL2 upload successful Uploading SBL3 SBL3 upload successful Uploading TZ TZ upload successful WARNING: Partition corresponding to D2_USA_ATT_16G.pit file could not be located Uploading CACHE CACHE upload successful Ending session... Rebooting device... Press NEXT to continue... IMEI still null/null |
08-23-2014, 22:22 | #10 (permalink) |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Man after flash phone you need root phone manualy and after with nspro latest version repair imei without this how imei should fix ?? I never see that after flashing miracle will come and fix for you IMEI. |
08-24-2014, 01:55 | #11 (permalink) |
Member: 293299 Status: Offline Thanks Meter: 264 | Waiting for phone... Checking if phone is Rooted... Root Access Granted! Resetting IMEI... Waiting for phone... Searching for Phone... Operation failed! |
08-29-2014, 15:01 | #13 (permalink) | |
No Life Poster Join Date: Jul 2011 Location: montreal
Member: 1612872 Status: Offline Sonork: 1613495 Thanks Meter: 178 | Quote:
uses Z3X and you will solve this problem just need to repair the imei with Z3X I have already decided that | |
