i8262 imei repair problem im flashing with this frimwear before imei repair I8262_Special_Firmware_For_IMEI.zip \ log hier but imei after repair is the same before Waiting for phone... Processing... Rebooting phone... Waiting for phone... Checking Security... Authenticating... Writing Master IMEI... Writing Slave IMEI... Restarting phone... Operation successfully completed |
no answear from support |
why in new version on ns pro this functions is disable ? please for ansewar me. |
Ns pro not work imei repair for this model. Please wait next update. After new update will be possible imei repair. |
pls add i8262 model in nspro for imei repair |
bro if you have z3x box try it..... |
no box in market to support i8262 imei repair |
Octopus support it plzzzzzzzzzzzzzzzzzzzzz check it |
Use NsPro v6.7.0 to write imei on the phone and post the results. |
After repair with new version phone only vibrates after reset. After reflash with stock firmware imei is 0/00. |
I've tried to change imei with original firmware: I8262XXAMJ2_I8262MTLAMJ1_I8262XXAMJ2_HOME.tar.md5 result was: Waiting for phone... Checking if phone is Rooted... Root Access Granted! Waiting for phone... Preparing phone. This may take a while... Resetting IMEI... Rebooting phone... Waiting for phone... and phone not powering on. After flash with the same firmware phone power up, but both imeis are: 0/01 0/01 After that I've tried flashing: I8262 Special Firmware For IMEI.tar.md5 phone powered up and I proceed to change imei, same situation again, nspro stops at: Resetting IMEI... Rebooting phone... Waiting for phone... and phone doesn't power up. So I flashed it again with: I8262XXAMJ2_I8262MTLAMJ1_I8262XXAMJ2_HOME.tar.md5 Phone powered up and voila - both imeis are changed correctly ;) P.S. All these test are done with latest nspro version: 6.7.0 If you need more info or tests, pls don't hesitate to contact me. Regards! |
Pls info phone registered on the network! All work or not? |
Ok, sorry - didn't test network after repair. So - now - SIM card accepted, network bar is ok, but when try to make cal get: "Not registered on network" message. |
same problemmmmmmmmmm |
