01-25-2013, 11:07 | #1 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Somewhere in Spacetime Age: 48
Member: 168364 Status: Offline Thanks Meter: 174 | I9070 hang on Samsung Logo after root 1. The phone was rooted with the original rootkernel.tar.md5 file that was found on NsPro support area. 2. Tha file was written via NsPro flashing module. (No advanced mode was selected - only one file mode.) 3. After the root file was successfully written the phone rebooted and then hung on Samsung logo. 4. No other result after flashing the whole firmware with original 3 Samsung firmmware including the I9070XXLD1_I9070XXLD1_I9070OXFLC2_HOME.tar.md5 file on the NsPro support. 5. I have made a mistake, that I haven't read PIT file from the phone. DOES ANYONE HAVE A PIT FILE FOR I9070 THAT WAS READ VIA NSPRO? PLEASE UPLOAD FOR ME/US MR. ELCO ! The phone's initial firmware was : I9070XXLK2_I9070TMHLK1_TMH . ANdroid version was 2.3.6. . Does anyone have an idea to resurrect this unit? The phone goes in download mode smoothly , but still hangs after flashing done. Best Regards! |
01-25-2013, 12:18 | #2 (permalink) |
Member: 168364 Status: Offline Thanks Meter: 174 | By the way, the Android version was 4.1.2. . I might be wrong when I thought 2.3.6. . The phone was flashed with HOME_I9070XXLPY_I9070SERLPY_660490_REV00_user_low_ ship.tar.md5 and works properly again. The readed PIT file is here : http://rapidshare.com/files/22059867...5113552_OK.pit So we need a new (rootkernel.tar) file to root the 4.1.2. Android versions or proper Exynos Exploiter for no root unlock! Best Regards |
01-25-2013, 18:37 | #3 (permalink) | |
No Life Poster Join Date: Dec 2002 Location: Romania
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | Quote:
Anyway, if that firmware is original from Samsung, i can make a solution for unlocking. | |
The Following User Says Thank You to Elco For This Useful Post: |
01-27-2013, 12:37 | #4 (permalink) |
Member: 168364 Status: Offline Thanks Meter: 174 | I9070 Android 4.1.2. Unlocked successfully (Probably World First using NSPRO) After reviving the unit, a method was found to debrand the phone to Android 2.3.6. . [ Solved ] How to Downgrade JB 4.1.2 to GB 2.3.6 - xda-developers So here are the steps. (1) Backup PIT file from Your untouched phone first using NSPRO. Store it in a safe place. (2) Downgrade it using the method described above. Don't forget to check Re-Partition , Auto Reboot, and F. Reset Time and uncheck all other options. (Odin SW) (3) Upload rootkernel.tar md5 file from Support Area using NSPRO or Odin. Write as PDA. (NSPRO advanced mode.) That's good for Android 2.3.6. . (4) Insert a MicroSD Card into the phone, which contains this file ; SuperSU-v0.96.zip . (5) Press Phone's Volume Up + Home + Power. After Vibrating release the Home and the Power keys but keep Volume Up pressed. Phone enters special menu. (6) Wait until SuperSU-v0.96.zip finish (1-2 minutes) then choose reboot Phone. (7) Allow all SuperUser rights appearing on the touch screen after phone fully powered up. Can also take few minutes. (8) Now the phone is ready. Connect to USB and get the job done by NSPRO software. (You will also need UART cable for the last step.) Notifications : -This will work only 8G models only. -You can reflash now phone to 2.3.6. version or 4.1.2. version which language pack corresponds to Your own region now. Make Your choice. -If You choose to upgrade the Android back to 4.1.2. , then You will need the PIT file readed in the (1)st step. In this case check Re-Partion again! -After (2)nd step You can make a PIT backup again. (Optional.) -You can test phone after (2)nd and (3)rd step just for security. IMEI, SW version, SL status. -Theoretically all flashing procedures can be done via NSPRO. (Not tested by me.) Here's a working PIT file (I9070 8G - Android 4.1.2.); http://rapidshare.com/files/22059867...5113552_OK.pit And SU activator file; http://rapidshare.com/files/873418522/SuperSU-v0.96.zip A file to reflash 4.1.2. Hotfile.com: One click file hosting: Samsung-Updates.com-GT-I9070-SER-I9070XXLPY-1355808918.zip Enjoy! Make it on Your own risk! This method is NOT for dummies! Thanks for Elco, bakl, chonthipak, and the writer of the SuperSU-v0.96.zip This is for proof; Uploaded with ImageShack.us Sometimes I feel like I am talking only to the Software Developer and myself. Last edited by Demongsm; 01-27-2013 at 12:46. |
The Following User Says Thank You to Demongsm For This Useful Post: |
04-21-2013, 06:18 | #6 (permalink) |
Member: 168364 Status: Offline Thanks Meter: 174 | (Android 4.1.2. ) I9070_nspro_20130125113552_OK.pit (4 KB) letöltése SU activator file for root. SuperSU-v0.96.zip (669 KB) letöltése Factory flash files can be found on tsar3000.com. Don't forget to read pit. Check the phone's android & flash version before any operations and write down somewhere. (For safety and for yourself.) B R |
