Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > NSPRO
Old 11-03-2012, 15:32   #1 (permalink)
Member: 1048476
Sonork: nkjn
Thanks Meter: 15
Thumbs up I9300 4.1.1 repair signal successfully
first,repair signal on 4.0.4
second,backup efs by Ns pro
thord,update system to 4.1.1
forth,restore efs backup
firth,now IMEI is 0049......
sixth,repair signal again.....everything will be ok.
good luck,guys.Great team,Ns Pro
The Following 6 Users Say Thank You to Eric_cn For This Useful Post:
Old 11-03-2012, 15:51   #2 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
Thanks Meter: 25,391
you dont need such complicated steps.
Dont matter if the phone is 4.0.4 or 4.1.1
Just root it then write IMEi again.
The phone will be OK with signal and everything...
The Following 7 Users Say Thank You to Elco For This Useful Post:
Old 11-03-2012, 16:41   #3 (permalink)
Member: 1795462
Thanks Meter: 4
Would you have to write the imei every time the phone is updated?
JZK
The Following User Says Thank You to rufnafuk For This Useful Post:
Old 11-03-2012, 22:43   #4 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
if the update is by OTA, no. If the update is by Kies or Odin, yes.
The Following User Says Thank You to Elco For This Useful Post:
Old 11-04-2012, 02:05   #5 (permalink)
Member: 1048476
Sonork: nkjn
Thanks Meter: 15
but after update to 4.1.1 by odin,signal was gone,and IMEI/SN all normal.I tried to fix it again successfully,signal same....so I restore efs backup.then fix it and work.
The Following User Says Thank You to Eric_cn For This Useful Post:
Old 11-05-2012, 06:58   #6 (permalink)
Member: 779470
Sonork: Waseem mobile
Thanks Meter: 93
any one have , 19300 EFS Backup working phone,
my cell no network after imei repair
Old 11-05-2012, 06:58   #7 (permalink)
Member: 779470
Thanks Meter: 93
Old 11-05-2012, 10:04   #8 (permalink)
Member: 1048476
Sonork: nkjn
Thanks Meter: 15
I9300 EFS backup here,good luck.
https://hotfile.com/dl/178556602/211...124efs.7z.html
Old 11-05-2012, 11:58   #9 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
Make sure you write the original S/N on the phone when repairing IMEI.
Also the IMEI must be a VALID IMEI.
If you write IMEI 123456789012.. the GSM provider network wont accept the phone to register.
Old 11-06-2012, 12:04   #10 (permalink)
Member: 1441172
Thanks Meter: 2
hi i downgraded 4.1.1 to 4.0.4 but not picking up on nspro??? i have done a couple of these phones before and all been fine. just stays on "preparing phone"
Old 11-06-2012, 12:29   #11 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
Make sure you enable debug mode on the phone, and the phone is rooted.
Old 11-06-2012, 12:44   #12 (permalink)
Member: 1441172
Thanks Meter: 2
yes the phone is rooted and usb debugging enabled, and computer picks up drivers but still no response from nspro?
Old 11-06-2012, 12:53   #13 (permalink)
Member: 1441172
Thanks Meter: 2
also tried this on 2 phones still same result, no response from nspro
Old 11-06-2012, 12:58   #14 (permalink)
Member: 1441172
Thanks Meter: 2
im using version 6.4.2, but i have also tried with version 6.5.0. pls help as i have 2 phones waiting
Old 11-06-2012, 14:58   #15 (permalink)
Elco's Avatar
Member: 19254
Sonork: 100.72990
you definetly have a problem on that pc (samsung drivers not installed correctly) or the phones are not rooted properly.
Contact me by yahoo messenger: [email protected]
And i will help you to solve that problem.
Page generated in 0.39069 seconds with 7 queries
