Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > NSPRO
Old 07-19-2013, 12:16   #1 (permalink)
Member: 971036
i9300 Imei repair problem and 0049
Hello I have a samsung i9300 with s7070 uart cable. I can't repair imei and this is the screen of my nspro log. I forgot to backup EFS from the phone. Is this the problem? Any solution? I have the phone without network. I check the cable schematics and it is the same, I have rooted the phone with file of support area and I flash I9300_IMEI_Baseband_Repair of support area. What can I do ??? Thx.
Old 07-20-2013, 19:32   #2 (permalink)
Member: 153893
Thanks Meter: 222
same problem always failed with uart cable cable av change like 3 working cables but still same failed error
Old 07-20-2013, 19:59   #3 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 9,781
Hello, Ns Pro, from 1 year is working ONLY whith "Ns Pro S7070 Uart Cable" if you have other cable, how Z3X, can forgot of send in Uart Mode New Android like S3-I9300, S4-I9505, N7000, N7100 itc....,
Yesterday have restored in only 2 min.s a NEW NOTE 2-N7100, w/o any issue, rootted in one moment from same Sw 6.5.5 and Imei 0049xxxxx repaired,
Max
Tips: put phone in good Dial Window,
1) *#9090# and set to 115200 speed
2) *#7284# USB/PDA and MODEM/PDA when Save and Reset button,
Old 07-20-2013, 20:05   #4 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 9,781
I9300, whith Correct S7070 Ns-Pro Cable Imei Restored
Hi, loock here whith Good Ns-Pro S7070 Cable, I9300 whith Imei 0049xxxxxx, restored whith Successfully:
Max
Old 07-23-2013, 11:37   #5 (permalink)
Member: 971036
Max
I must save and reset button when require ns pro or first to connect???
Old 07-23-2013, 11:55   #6 (permalink)
Member: 971036
Max
Can you explain step by step what do you do to repair imei. The cable is s7070 ns pro cable. Thx
Old 07-23-2013, 12:41   #7 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 9,781
Bro, is all explained Step by Step, and in mode very Easy and Clear.
If u not have any base over Samsung Phone and Box, please ceck in the Sticky Thread or use Serach Button, i cannot u explain more of how have just wrote, if u ASK to me what is "Save and Reset", if have need of to do First or later connect to box itc..., pardon but use a little of reader in Ns-Pro function,
Max
Ripgsm
Old 07-23-2013, 21:20   #8 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 9,781
@25gianni25,
Please STOP SPAM IN PM !!!!
Never have used Report button, not to be the first..... when not know anythingh over Box or Samsung phones, please use Search Button, Read in Ns-Pro Forum, search in the Web, but not continue whith u request continue, if aren't good to repair a phone, please not damage the marketing, send to repair in serious Laboratory or technician,
Excuseme Elco, but this man has passed any limit,
Max
Old 07-23-2013, 21:25   #9 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 9,781
@ godwin, open u thread, i want to try help u, but post Log complete and pictures of the cable u are using, when connect S7070 MicroUart Cable, version of this I9300 and Device Mahager pictures whith phone connected,
Max
Old 07-25-2013, 19:05   #10 (permalink)
Member: 971036
This is my s7070 nspro cable:
It is as the schematics of support area. The pin are connected one by one and the resistor value is 530k. the cable is ok. Any suggestion?
Old 07-26-2013, 15:12   #11 (permalink)
Member: 687113
Thanks Meter: 31
Successfully repaired i9300 with imei 0049*
Just connect phone with debugging mode enabled, write down imei and SN.
Waiting for phone...
Checking if phone is Rooted...
Root Access Granted!
Resetting IMEI...
Setting efs permissions...
Preparing Phone...
Connecting to phone UART...
Using Advanced MSL...
Bypasing Security...
Reading Security Confirmation...
Writing IMEI...
Setting Serial Number...
Resetting Phone...
Operation successfully completed
Old 07-26-2013, 17:23   #12 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 9,781
Hi,
Not is one new it!!!
Always and for All Samsung "Debug Usb" needed abilitation, for PC/BOX operation,
Max
Old 08-24-2013, 16:48   #13 (permalink)
Member: 1669920
Sonork: altamash
Thanks Meter: 3
PLESE HELP SIR I9300 IMEI 0049 UNLOCK DONE
IAM USED CABLE RJ45 C3303K SPT BOX CABLE C3300
HEAI IS LOG
Selected model: I9300
Selected port: COM9 Z3X BOX Serial Port
Selected port speed: 115200
File analysis... OK
Total file size: 0x4B138028
Searching USB Flash Interface... detected COM8
Setup connection... OK
Reading PIT from phone... OK
Saved to C:\Program Files\Z3X\Samsung\SamsungTool\Pit\I9300_24-8-2013_17-11-31.pit
Sending sboot.bin... Error
Done with Samsung Tool v.15.3
File analysis... OK
Searching USB Flash Interface... not found
File analysis... OK
Saved to C:\Program Files\Z3X\Samsung\SamsungTool\Pit\I9300_24-8-2013_17-11-51.pit
File analysis... OK
Total file size: 0x4F3BD1CC
Saved to C:\Program Files\Z3X\Samsung\SamsungTool\Pit\I9300_24-8-2013_17-12-14.pit
Sending tz.img... OK
Sending sboot.bin... OK
Sending system.img... OK
Sending boot.img... OK
Sending recovery.img... OK
Sending cache.img... OK
Sending hidden.img... OK
Sending modem.bin... OK
Flashing done (time - 00:04:50)
Searching Samsung modem... not found
Searching Samsung modem... detected COM7
Reading phone info...
Software version: I9300XXEMD2/I9300XXEMC2/I9300OXXEMD1
IMEI: 004999010640000
Product code: GT-I9300RWDATO
Searching ADB device...
Phone not found
Searching ADB device... OK
Model: GT-I9300
Android version: 4.1.2
Product code: GT-I9300RWDCYO
Phone version: I9300XXEMC2
PDA version: I9300XXEMD2
CSC version: I9300OXXEMD1
IMEI: Unknown
Checking Super user right... false
Rooting phone, please wait... OK
Checking Super user right... true
Reading data from phone... OK
Repairing network settings... OK
Writing data to phone... OK
Rebooting phone... OK
Now connect phone to UART cable
Checking phone at COM9
No answer from phone
Phone not found
Phone not found
Model: GT-I9300
Product code: Not Active
IMEI: Unknown
Operation aborted
Selected port: COM24 USB Serial Port
Phone not found
Model: GT-I9300
IMEI: Unknown
Checking phone at COM24
Old 08-24-2013, 18:58   #14 (permalink)
.:Ripgsm:.'s Avatar
Member: 125945
Thanks Meter: 495
HEAI IS LOG
File analysis... OK
File analysis... OK
File analysis... OK
File analysis... OK
Phone not found
Model: GT-I9300
IMEI: Unknown
Phone not found
Phone not found
Model: GT-I9300
IMEI: Unknown
Operation aborted
Phone not found
Model: GT-I9300
IMEI: Unknown
Hi, u are in WRONG SECTION,
Max
Page generated in 0.62540 seconds with 7 queries
