05-16-2013, 17:48 | #1 (permalink) |
Freak Poster Join Date: Sep 2005 Location: Manchester, UK
Member: 180873 Status: Offline Thanks Meter: 80 | i9505 imei repair issue Code: Waiting for phone... Checking if phone is Rooted... Root Access Granted! Waiting for phone... Checking if phone is Rooted... Root Access Granted! Resetting IMEI... Waiting for phone... Writing IMEI... Operation failed! What should I do? my sonork if anyonce can help is 100.1603257 |
05-16-2013, 21:10 | #2 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Romania
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | PLZ check your NsPro S7070 cable. The error you get indicate that NsPro cant communicate correctly with the phone on S7070 cable. The NsPro S7070 cable you use on IMEI Write process is bad or is not made for NsPro. |
05-17-2013, 14:11 | #4 (permalink) | |
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | Quote:
If your cable is made according to S7070 cable schematic from nspro support area, it will work. C3300K cable is NOT the same as S7070 cable. The difference is the resistor value from the cable. Download the NsPro S7070 cable schematic from NsPro support area and check if your cable corespond to that schematic. i9505 IMEi write is tested and 100% WORKING on NsPro. The only condition is to use the CORRECT cables indicared by NsPro and to fallow the NsPro software instructions. If you can unlock i9505 with that cable, will work for IMEi write too. If it don't work for unlock too, the cable is wrong. | |
The Following 2 Users Say Thank You to Elco For This Useful Post: |
05-17-2013, 14:51 | #5 (permalink) | |
Member: 180873 Status: Offline Thanks Meter: 80 | Quote:
Thanks for your help, just one last question, im not at work today but what is the value of the resistor on the s7070 cable? Thanks | |
