03-13-2013, 19:50 | #1 (permalink) |
Crazy Poster Join Date: Feb 2013
Member: 1877522 Status: Offline Thanks Meter: 0 | issue on T989D 4.0.4 unlocking. Operation fail I fail on T989d 4.0.4 from Koodo. Use s7070 cable When I click unlock, it asks for "*#9090# - UART Diag - Reboot - ok " After dialing *#9090#", there is no UART Diag. Only UART[*]. So, I choose it. The reboot this phone. Then ok. Several attempt but operation failed. Can you advise any steps I go wrong? Thx. |
03-13-2013, 20:09 | #2 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Romania
Member: 19254 Status: Offline Sonork: 100.72990 Thanks Meter: 25,395 | PLZ type *#7284# on the phone and select UART->MODEM, USB-PDA on *#9090# select UART If still don't work, check/clean the phone connector. Also PLZ check your NsPro S7070 cable. |
03-13-2013, 20:22 | #3 (permalink) |
Member: 1877522 Status: Offline Thanks Meter: 0 | You mean after *#7284# on the phone and select UART->MODEM, USB-PDA then *#9090# select UART? Or you mean either *#7284# on the phone and select UART->MODEM, USB-PDA? Or *#9090# select UART? After, Should I click "back" or "end" Or does not matter? Should I reboot phone? ( Necessary? ) should I ? Does it matter if I plug s7070 before or after all steps ( I plug it before all steps). Sorry. New to NSPro, 1st time on T989D...sorry for tedious question |
03-14-2013, 20:12 | #5 (permalink) |
Member: 1877522 Status: Offline Thanks Meter: 0 | Successful after Elco's advice Elco, Thx. It is First trail not successful after the reboot the phone, as the voice tap pop up automatically. I exit voice tap & do steps again without reboot the second time, it works. Thanks for your prompt support. I will continue to share successful screenshot. |
