Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2001 Age: 31
Member: 4597 Status: Offline Thanks: 5
| The problem is that just the one or the other works when I install the "NSPRO CONVERTER" driver, then the nsbox works, but when I install the „JAF FLASHER INTERFACE” driver, then the jaf box works and can’t flash with NS, the problem is that the "JAF FLASHER INTERFACE" diver uses the same type of files as "NSPRO CONVERTER"! How can I solve this problem? THXXX |
| | #3 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: May 2006
Member: 279555 Status: Offline Thanks: 2
| what do you mean change port settings in nspro??? need more info please. are you talking in device manager where i see nspro port (comxx)? should i have both device attached to computer at the same time, cause i've tried and when i launch jaf i don't see the dct option . |
| | #6 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Jul 2004
Member: 73565 Status: Offline Thanks: 397
| Hi, im working at most usb>com ftdi chip based. So far so fine. Hope this picture can explain you. All we need is to manage port setting and drivers. When you asked "overwrite new file" please answer "YES" Regards |
| | #9 (permalink) | ||
| Quote:
@all; good luck ![]() Best Regards | ||
| | #11 (permalink) | |
| Hi, please read carefuly my post above Quote:
| | #13 (permalink) |
| Remove device first (by show hidden device), you dont need to plug it when you do it. After that: run ns installation pack first, then jaf. good luck |
| | #15 (permalink) |
| Not connected. Remove both ns and jaf from device manager by show hidden device (Like the pic attached above). All port and usb device should be cleaned up from those two things. Next; >install latest NSPro pack >install latest JAF pack. >Plug NS, select driver. >Plug JAF, select driver. "overwrite newer file?" YES. In order to get the soft work correctly, please set JAF port assignment not more than 10 and NS port not more than 20. (already described clearly on pic above) *OMG* i dont believe it, is it too difficult for you? Regards |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| JAF Box vs Cyclone Box ??? | vmin81 | Cyclonebox | 75 | 04-07-2009 22:40 |
