Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > NSPRO
Old 08-26-2009, 09:51   #1 (permalink)
Member: 2899
M8800 flashing problem!
hi
i try to flash a m8800 with ns,but it keeps saying fone not found,i put the hand set into the boot loader mode,then i plug in the e210 rj45 cable,can anyone help please,thnx
farry
Old 08-26-2009, 10:35   #2 (permalink)
heramiah's Avatar
Member: 819396
hi, it could be a cable fault, i had same problems with cables till i replaced them. also use nspro for most flashing, but sometimes prefer to use mulitiloader thats what i used to flash m8800 and worked perfect, u can flash with original USB cable and just connect to pc.
hope this helps
Old 08-26-2009, 11:07   #3 (permalink)
Member: 2899
hi
thanx for reply buddy,can you provide a link,or the name for the samsung downloader,thx again,i think the cable is ok ,cos i can unlock the fone with ns,but when i click on user reset,it says fone not found,cheers.
farry
Old 08-26-2009, 15:10   #4 (permalink)
heramiah's Avatar
Member: 819396
hi, you just nned to download the correct flashfile from nspro support and in the folder you should have multiloader
Old 08-26-2009, 17:04   #5 (permalink)
Member: 235703
there is no multi loader in the folder,where can i get it?
Old 08-26-2009, 17:07   #6 (permalink)
Member: 1024839
Sonork: 100.1592057
all of u remember any phone which u need to download mode to be flash use usb cable install driver and thats it do ur jobs
E52 RM-469 Flashing problem.Flash ID not supported for this loader (RAPUv11_algo_xsr1 rafik2533 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 04-04-2010 20:38
Samsung M8800 Camera Problem citifone NSPRO 4 11-11-2009 05:07
samsung m8800 unlock problem johnlee007 NSPRO 11 09-09-2009 15:18
m8800 flash problem - please help heramiah NSPRO 15 08-26-2009 12:26
pixon M8800 unlock problem!!! samirr Easy-Unlocker 4 01-29-2009 18:32
Page generated in 0.30276 seconds with 11 queries
